R56 MFSW (without Nav) - Voice commands?
Old May 17, 2007 | 09:26 AM
BritBoy's Avatar
BritBoy
The MFSW has a button on it with a picture of a head, which is used for voice commands. Does anyone know what voice commands should be available, as the manual is vague on the subject.
I read in another thread that those with Nav can use voice commands to turn the radio on, for example, but they needed a software download to enable it.
Old May 17, 2007 | 12:43 PM
djam43's Avatar
djam43
I think that you have NAV or Bluetooth for this system to work. I know that there are about 200 commands that it recognises. My NAV doesnt talk to me at the moment as I have to bring it back for a software upgrade.
Old May 17, 2007 | 12:52 PM
Loony2N's Avatar
Loony2N
Yeah. The software was supposed to be loaded already.
Old May 17, 2007 | 01:05 PM
Coffeeman's Avatar
Coffeeman
Does anyone know if recent production cars with nav are coming through with working voice recognition? Mine is due in N.Y on the 21st, and the thought of an initial dealer software "upgrade" scares me to death...having experienced BMW software "upgrades" before.
Old May 17, 2007 | 01:27 PM
TheBigNewt's Avatar
TheBigNewt
If you push the head button and say HELP it'll tell you what commands you can use. It's all phone stuff for bluetooth if you don't have the Nav.
Old May 17, 2007 | 01:29 PM
Loony2N's Avatar
Loony2N
I saw a post from someone saying his worked.
Old May 17, 2007 | 05:06 PM
Sowellman's Avatar
Sowellman
It hasn't been a problem for everyone. My car went into production at the end of the first week in March. I haven't had any problems with the voice navigation.
I haven't seen an explanation of why some people's systems haven't worked, but the problem seems to be spotty.
Old May 17, 2007 | 07:32 PM
celljay's Avatar
celljay
I have the MFSW and the bluetooth feature and the voice recognition works great!You can program numbers into a voice activated address book and have the car dial by name. Very useful hands free feature. There are a number of available commands, you can even say help and it will list the available commands.I do not have the navigation system but I'm sure there are more voice acitvated features with NAV.
celljay
Old Jun 28, 2007 | 07:48 PM
emtrey's Avatar
emtrey
celljay
I am having trouble getting numbers into the phone book for voice recognition. When I try--it says adress book is empty. Can you lead me to what I am doing wrong...(ps phone is MOTO RAZR)
Old Jun 28, 2007 | 10:46 PM
Sowellman's Avatar
Sowellman
Originally Posted by emtrey
I am having trouble getting numbers into the phone book for voice recognition. ... Can you lead me to what I am doing wrong...(ps phone is MOTO RAZR)
I don't understand the process. Have you paired your phone with the car's bluetooth system? I also have a Razr and tried to find instructions for importing my address book into the car's system. And had no luck.
Then I started trying to search the car's functions and I found that my address book had already been imported. I'm not sure how it happened, but whatever it was, it did it automatically.
I'm on T-Mobile, not sure if all Razrs are the same with different carriers. Good luck.
Old Jun 28, 2007 | 11:31 PM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
I would think as long as the bluetooth pairs up this should be an automagic process. I've paired up a couple of LG 8600 cel phones with a Garmin Nuvi unit before and it transfers everything automatically.
Old Jun 29, 2007 | 06:15 AM
JeffreyC's Avatar
JeffreyC
Once my Cingular Razr paired, it imported the addy book automatically.
Old Jun 29, 2007 | 09:55 AM
emtrey's Avatar
emtrey
not having any problem w/ phonebook ---its there. However, using the MSFW, it will not accept a voice command to dial a name ( will accept a called out number) as per book--tells me phone book is empty and will not allow me to add a voice command with a nmae tied to a phone number. Very frustrating.
Old Jun 29, 2007 | 01:22 PM
Sowellman's Avatar
Sowellman
Then I completely misunderstood your problem. As soon as my car system imported the cell phone's address book, I was able to dial by voice command. I'm not sure why it won't allow you to do it.
Old Jun 29, 2007 | 01:51 PM
TheBigNewt's Avatar
TheBigNewt
It will import your phone address book so you can dial with the buttons in Audio. It will not import the book into the voice dial so you can dial names. You have to do that yourself. You can dial numbers by voice ("dial number" asks for number, say the number). Check the manual, it will guide you through it. You have to set each name with a number individually. You don't even need the phone hooked up to do it. Until you do that the address book in the car voice dial is empty, whereas the address book you see in the audio system with the phone hooked up is stored on the phone. Make sense? I forget the sequence, something like "store number" or "store name" and it goes from there. I got it to work, but it took some messing around with.
RoadRacer's Avatar
RoadRacer
In order to dial by name with the voice command from the MFSW you must first record the name in the car. If I recall correctly, you press the 'voice command' button on the wheel spoke, and the prompt is "SAVE NAME" (or "STORE NAME") - check the manual to be sure. The Bluetooth link doesn't use the stored voice dialing from the phone - it has to be stored in the vehicle. It does however import the address list from the phone as others have stated.
I use the voice dial function a lot, and it works great.
Old Jun 30, 2007 | 04:17 PM
emtrey's Avatar
emtrey
I HAVE TRIED THAT AND ALL I GET IS..PHONE BOOK IS EMPTY..AM I MISSING SOMETHING. PHONE IS RAZR WITH CINGULAR.
PS I HAVE A SEAL GREY 06 CARRERA S TOO...GRT CAR
Old Jun 30, 2007 | 04:21 PM
emtrey's Avatar
emtrey
HOW DO YOU ASSIGN A NUMBER TO STORED NAMES...most of those in my top 8 are the ones I want to use for voice dialing?
Old Jun 30, 2007 | 05:16 PM
Sowellman's Avatar
Sowellman
Mine did. When the address book from my phone was imported into the car's system, it allowed to dial by name, "Dial Joey," for example. I did not have to program it at all for it to respond that way.
Old Jul 1, 2007 | 07:09 AM
emtrey's Avatar
emtrey
OK---finally go it to work...First command is Save Name NOT Store Name as in manual...then you must be very deliberate..wait for it to say SPEAK ...DO NOT talk when it says continue...wait for it to say SPEAK NOW...Last command is SAVE.
I wrote out a list with numbers 1-10 and then proceeded.
It take a while for each entry...be patient (not usually a virtue with ME).
Perhaps certain phones and software do this automatically but my Cing. RAZR did not. It had to be programmed into the car manually.
Hope this helps for anyone who had as much trouble as I did gettting this function programmed.
Old Jul 1, 2007 | 12:16 PM
SimpsonGI's Avatar
SimpsonGI
Glad to hear you got it working. And thanks for posting the instructions for getting it programmed!
PelicanParts.com
May 14, 2026 04:59 AM
Filmy
15
Jun 6, 2023 06:27 AM
PelicanParts.com
Accessory Products
Oct 1, 2015 01:23 PM
quality_sound
Sep 12, 2015 05:55 PM
