R55 Horn won't work! Help
Old Nov 2, 2018 | 02:45 PM
Erdelke's Avatar
Erdelke
Checked the horns, fuse, did a check on the clock spring, all seem fine.
Can't seem to locate a relay. Removed the fuse panel in kick board and found nothing that looked like a relay
Old Nov 3, 2018 | 05:44 AM
Capt_bj's Avatar
Capt_bj
MINI horns ARE on a relay ... in this diagram see relay K2a ... it connects to H2b and H3b which are the two horns ...
https://www.newtis.info/tisv2/a/en/r...ule/1VnYNZIYZx
Old Nov 3, 2018 | 07:45 AM
Erdelke's Avatar
Erdelke
I can't find a relay. Looked under the fuse box in the passenger side kick panel, couldn't find anything serviceable
Old Nov 3, 2018 | 08:03 AM
DneprDave's Avatar
DneprDave
I haven't used my horn in about eight years, I suppose I should check and see if it still works.
Old Nov 3, 2018 | 11:19 AM
Capt_bj's Avatar
Capt_bj
https://www.newtis.info/tisv2/a/en/r...fares/CkYxY37b
did you check the box under the bonnet
btw ... it IS possible that the horn(s) themselves have failed. I just had that on my ST .... alto on a MINI with two horns they are in sep' locations so less likely. BUT they are low and can get drown and then they corrode a 'freeze' .... you might want to pull the connector on one and use a meter to verify they get no juice .....
Old Nov 3, 2018 | 11:33 AM
Capt_bj's Avatar
Capt_bj
good habit to get in to
it is a bummer when you discover it don't work when you NEED IT!
with the 79 I developed the habit of checking the horn and turn signals b4 I hit the main road on any outing . . .
Old Nov 5, 2018 | 06:35 AM
Erdelke's Avatar
Erdelke
Bench tested horns one was bad and replaced.
i have no power to the horns. Suspicious of a relay, but can't find one, looked behind passenger fuse panel, no luck. All the ones under the bonnet seem to be dedicated to engine functions. I do not hear a click when horn is engaged.
Old Nov 5, 2018 | 08:02 AM
Capt_bj's Avatar
Capt_bj
what can I tell ya
the wiring diagram in the link clearly shows a relay and earlier cars GEN1 and GEN2 hardtop had relay
systems without a physical relay have the main computer serve the function (headlamps, fogs etc) ... you could try the 'reset' procedure
seems like no one with the gen2 bentley wants to help out
Old Nov 5, 2018 | 08:17 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
http://www.alldata.com/blog-entry-op...ni-cooper-horn
Old Nov 5, 2018 | 08:21 AM
DneprDave's Avatar
DneprDave
https://www.specr53.com/blog/diy/mini-horn-repair-diy/
Old Nov 5, 2018 | 12:23 PM
Erdelke's Avatar
Erdelke
Thanks. Guys.
Called mini of St. Louis, great guy said the relay is indeed behind the fuse panel in the kickboard, and is not serviceable. If anyone has one let me Know
Jtrick
Electrical
15
May 1, 2018 07:56 AM
Fir3Chi3f
Dec 16, 2013 05:58 AM
EHDaniel
Jan 18, 2011 02:34 PM
The MINITOR
Feb 1, 2006 11:16 AM
