R55 How
Old Apr 6, 2016 | 08:15 PM
chav's Avatar
chav
How
I have a 2009 clubby and I want to get low. I had a 2007 r56 and put on H&R springs on and the car looked great and I had some camber with any problems. I was wondering if I can still do the same thing on my car.. I have been looking a Lowering springs and coil overs. I don't have the money to buy brand new stuff but wanted some inside thoughts on what to do. The car currently has 120k all stock. if I did the lowering springs do I really need the camber arms? does the sway bars really do anything? what if I got coil overs?
Another question is about the boost radio.. IT IS BAD. Anything I can do to make this better? didn't want to have to put a whole new system in. thought about putting a sub in the car but would that help? and I have seen a switch thing? no idea what it does or how it works or even if it does work but I saw it for sale and I'm clueless.
Thanks, Nathan !
Last edited by chav; Apr 6, 2016 at 08:18 PM. Reason: title is not complete sorry guys...
Old Apr 7, 2016 | 08:21 AM
Hello,
For springs MINI Clubman : https://www.ecstuning.com/Mini-2009-...nsion/Springs/
You will not need them unless your really drop it. Like on coilovers or air.
Radio improvements: : Front/Rear Channel Swap
https://www.northamericanmotoring.co...nnel-swap.html
Old Apr 9, 2016 | 10:35 PM
Mini Mania's Avatar
R55 Clubman Springs
Thanks, Nathan !
Hi Nathan! Here is an article that might answer your questions regarding lowering you R55 Clubman. http://new.minimania.com/MINI_Cooper_Lowering_Springs
Please note the final paragraph: "Lowering springs will add negative camber to the rear. For best results, you should add adjustable rear control arms to correct the rear camber after lowering your car. If you choose not to correct the rear camber, your rear tires will wear unevenly and require early replacement. The front camber is not affected. Install the rear adjustable control arms and have the alignment corrected."
Here is another article that can help:
http://new.minimania.com/Mini_Cooper...e_Control_Arms
Finally, a great Mini Cooper Performance Upgrade Guide!
http://new.minimania.com/Mini_Cooper..._for_your_Mini
Old Apr 10, 2016 | 09:44 AM
daddyandmadi's Avatar
daddyandmadi
Stereo wise, look up channel swap. The stock stereo has the bass switched front to back. I'm debating a small powered under seat sub to add a little bass. Look up integral audio for a good install guide. And I dream system.
Old Apr 10, 2016 | 03:32 PM
chav's Avatar
chav
great thanks! keep the good information coming!
Old Apr 11, 2016 | 03:36 PM
Mini Mania's Avatar
Welcome! Let us know if we can help!
Old Apr 11, 2016 | 08:05 PM
chav's Avatar
chav
Okay so after looking into the channel swap I see there is a diy but no photos I wouldn't mind trying it myself before giving in to the $60 channel swap. Also I have decided to go with some coilovers and depending on the camber I will be getting some control arms.
Old Apr 12, 2016 | 01:41 PM
Mini Mania's Avatar
R55 Coilovers, Control Arms
Sounds great! Please let us know if you need any help with selection. We have several available
http://new.minimania.com/Search_Resu...ilover/default
12% OFF. Excludes Sales items and Special Orders Parts
Promo Code: CelebrateApril
NYXF56JCW
Suspension
Apr 5, 2016 11:24 AM
dmyer
Apr 4, 2016 02:37 PM
jcrane82
Mar 7, 2016 11:05 AM
Greerj1987
Mar 3, 2016 06:36 PM
MidwayMountaineer
Feb 16, 2016 01:19 PM
