R55 Slight Hesitation
Old Jun 24, 2015 | 12:27 PM
Titleist76's Avatar
Titleist76
Slight Hesitation
Anyone else get a slight hesitation when cruising and then stepping on it (say to pass)? I've noticed it in 4th, 5th, and 6th gear. This is a manual S clubman.
Old Jun 27, 2015 | 12:29 PM
PParker74's Avatar
PParker74
My Clubman also has a slight hesitation in the higher gears. For the most part I believe it to be turbo lag. I believe the gas pedal is also part to blame because it is sometimes slow to respond. Thought about getting a Sprint Booster to solve that. I've owned 2 turbo Minis and they have all driven very similar. If your problem worsens and have higher mileage you might want consider having the fuel system cleaned. This could be the signs of carbon build up. Good luck.
Old Jun 29, 2015 | 09:21 AM
Titleist76's Avatar
Titleist76
Thanks for the reply. It doesn't feel like turbo lag. I've had lots of turbo'd cars and I've felt turbo lag. This is more like hit the gas... hmmm.... let's think about this for a second or two and then it gradually accepts that I'm not taking my foot off the gas. Turbo lag to me has always felt like "Woooooosh! Okay, let's go!"
My car is right at 50k, so not high mileage at all.
Old Jun 29, 2015 | 09:53 AM
RobertJ's Avatar
RobertJ
Have you ever had the intake valves cleaned? I do not have this issue at all. You might be due a walnut blasting.
Old Jun 29, 2015 | 10:25 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Have you kept up with the basic maintenance needs? Spark plugs, fluid changes, filters, etc? Dong a cleaning, as suggested above, may be a good idea as well.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 29, 2015 | 10:28 AM
Titleist76's Avatar
Titleist76
The car has been maintained. Looks like I'll look into the walnut blasting if this keeps up. I always hoped an Italian Tuneup would be enough. I guess not.
Old Jun 29, 2015 | 01:31 PM
RobertJ's Avatar
RobertJ
Unfortunately, with these direct injection motors the Italian tune up method is not enough. You're at the mileage for an intake valve cleaning anyway, so it's not a bad idea to get one. Make sure it's of the walnut blasting variety. They seem to run from $350 to around $600 depending upon location.
Old Jul 13, 2015 | 06:35 PM
donniedarko's Avatar
donniedarko
seafoam.
Old Aug 14, 2015 | 11:57 AM
Titleist76's Avatar
Titleist76
So, I initially starting having this hesitation at around 48,000 miles. At my last oil change the service tech mentioned new spark plugs at around 55-60k. I decided to order the parts and just do them myself (saving a shop hour of labor). I finally got around to it last night at 51,000 miles. It totally cleared any hesitation. The car feels brand new again. No seafoam or walnut blasting needed (knock on wood), yet. W00T!!!!
Old Aug 14, 2015 | 12:06 PM
donniedarko
What kind of plugs? Brisk or OE spec?
Old Aug 14, 2015 | 12:08 PM
Titleist76's Avatar
Titleist76
I bought OE from ECS Tuning. They came gapped - I checked them. The Service Writer said they've seen blown engines using non-oem plugs. I laughed, but still... it's not worth testing my warranty.
Old Aug 14, 2015 | 12:37 PM
Titleist76's Avatar
Titleist76
-Luccia
Looking back at this, I should say "thanks". The plugs weren't due yet, but they made a hellaova difference.
Old Aug 14, 2015 | 01:31 PM
Thanks for the order and if you need anything else , let me know.
Old Aug 14, 2015 | 01:40 PM
Titleist76's Avatar
Titleist76
I can always think of a ton. But, my wallet decides it's better not to. Though I do need some basic stuff. I'll have to set up another basket.
drrigg
May 27, 2022 03:31 AM
scottselk
Jul 20, 2019 06:43 AM
RobbyD
Jan 29, 2019 01:22 PM
TunedGP
Oct 1, 2015 04:18 PM
eliseo1981
Sep 30, 2015 07:57 PM
