R55 D.I.Y oil change
Old May 20, 2014 | 04:48 PM
roach_juts's Avatar
roach_juts
D.I.Y oil change
Hi
for sure lots of us ask this already
buy is there a step by step or video
DIY how to change oil ???
Old May 20, 2014 | 05:56 PM
AZdsrt's Avatar
AZdsrt
It's in the 'How to' forum -
https://www.northamericanmotoring.co...-pictures.html
Old May 20, 2014 | 09:35 PM
roach_juts's Avatar
roach_juts
Thanks Azdsrt....
i saw that link already, just was not sure, because the car in not a S model,
but i guess both engine have the same way how to oil change it
Thanks again
Old May 20, 2014 | 11:44 PM
Fly'n Brick's Avatar
Fly'n Brick
Here's another resource, not quite as detailed as the previous. This one is on the R56. Don't know much about the 2nd Gen if R56 translates to R55 when it comes to the mechanics involved. The pictures are on post #1 thru 4.
BTW, the NAM search engine works really good.
https://www.northamericanmotoring.co...th-pics-5.html
Old May 21, 2014 | 06:39 AM
jcauseyfd's Avatar
jcauseyfd
On an S model you will need to move the coolant expansion tank out of the way. It is only held in place by a single bolt on top. Main thing is to be easy moving it around so you do not loosen the tube connection on the bottom.
I'd recommend after removing the oil pan plug, remove the fill cap, crack open the oil filter housing and then let everything sit for 15-20 minutes so it can drain. This will help avoid spills when you finally do pull the oil filter housing off.
Didn't realize the how-to's for the N14s were just posts instead of documents or videos. May have to catch a video if I ever get my pair of Google Glass. Maybe some images as well and put together a PDF. Unfortunately, I'm still around 7,000 miles away from my next oil change, so it will be later this summer before I change again.
Old May 21, 2014 | 12:14 PM
roach_juts's Avatar
roach_juts
Cheers !!
thanks for all reply
Old May 22, 2014 | 11:56 AM
daddyandmadi's Avatar
daddyandmadi
Did my first one on the Mini today. Very standard. Just need to move the coolant tank. 30 min all in.
One question, why would my old filter's ribs be bent?
Old May 22, 2014 | 01:45 PM
Fly'n Brick
Probably from a ham handed MINI oil filter installation engineer and a lousy judge of good beer.
Old May 22, 2014 | 02:41 PM
Capt_bj's Avatar
Capt_bj
huh?
Old May 22, 2014 | 10:15 PM
Fly'n Brick
That's Glendale, CA, skipper. They're mostly judges of fine wine around there or at least they like to act like it.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
