R50/53 The Official MC40 Owners Club
Old Jul 10, 2018 | 10:56 PM
  #576
Jason Youn's Avatar
Jason Youn
Photo of the custom exhaust on my 263.
Waaay louder than the previous JCW exhaust, but worth every penny :D
Old Jul 11, 2018 | 06:02 AM
  #577
JABowders's Avatar
JABowders
Veteran: Army
Ohhhhh sexy.
Did you weigh it? I wonder how much lighter it is than the JCW exhaust.
Motor On!
Old Jul 11, 2018 | 10:44 PM
  #578
Jason Youn's Avatar
Jason Youn
Originally Posted by JABowders
Ohhhhh sexy.
Motor On!
Unfortunately, I didn't get to weigh it :(
Old Jul 13, 2018 | 09:21 AM
  #579
cooper48's Avatar
cooper48
Fuel filter replacement
Hi, folks.
I just replaced the fuel filter in my 2004 MC40. I have the inspection plate off after installation to test for leaks (there are none visible, nor can I smell any fuel).
I've set the key in position 2 a couple of times to prime the pump (which I can hear working) but the car won't start. It's turning over fine and a couple of times while attempting to start it I've heard clicking coming from the fuel filter area (but not every time).
What did I do wrong? Should I simply wait and try again and is it possible that I've disconnected something during the replacement process? Thanks for your help.
Old Jul 13, 2018 | 10:04 AM
  #580
Cincy_jro's Avatar
Cincy_jro
I'd try priming it a few more times and let it sit for 30 min. Try again.
Check the connector on the coil pack. Might not be getting any spark at the plugs.
Old Jul 13, 2018 | 10:22 AM
  #581
Cincy_jro's Avatar
Cincy_jro
Scratch what I said about the coil pack unless you did work near it and had to unplug for some reason. My money is on the fuel needs more priming since you did the pump and filter. The lines may have bled out into the tank while you were pulling the pump. Keep a charge on the battery, prime a few times and try starting. Do the whole process a couple times. If it doesn't start after doing it 10 more times then it might be time to look somewhere else.
Old Jul 16, 2018 | 01:21 PM
  #582
megaDan's Avatar
megaDan
Took it out to C&C. Lots of positive comments.
Sorry, just so happy with how these wheels turned out. Why not bump the thread with a little MC40 ****?
Old Jul 17, 2018 | 09:41 AM
  #583
JABowders's Avatar
JABowders
Veteran: Army
RE: Replaced fuel filter and car won't start
I would crack the fuel line at the fuel rail and bled out the air... and if needed maybe use a spray bottle to atomize fuel into the intake to get the car started and see if I could run it past the air.
BUT ... this may not be the preferred method.
Best of luck
Motor On!
Old Jul 18, 2018 | 03:39 AM
  #584
minsanity's Avatar
minsanity
Originally Posted by cooper48
Hi, folks.
Read this carefully....
https://www.pelicanparts.com/techart...eplacement.htm
This particular paragraph:
"Take the upper cover and carefully line up the tabs on it (it can only go in one way) with the tabs on the lower filter housing. Take care to make sure the upper cover is directly seated on the filter element. If it isn't, THE CAR WON'T START. We found this out the hard way after re-assembling the fuel system. Once the upper cover is seated, rotate it clockwise until it stops. This will lock it in place."
Old Jul 25, 2018 | 04:40 PM
  #585
cooper48's Avatar
cooper48
Jason, slick exhaust. Was that aftermarket or custom-built? It would be interesting if you could post an audio file so we could all hear the difference.
Old Jul 25, 2018 | 11:13 PM
  #586
Jason Youn's Avatar
Jason Youn
It's a custom :D The audio was recorded with an iPhone mounted on the CD slot. It's probably not the optimal setup, but it gives you a rough idea of what it sounds like.
Old Jul 26, 2018 | 09:36 AM
  #587
cooper48's Avatar
cooper48
Way cool, Jason, love it! Did you have a muffler shop fab that? Willing to say what the cost was? Thanks.
Old Jul 26, 2018 | 10:05 PM
  #588
Jason Youn's Avatar
Jason Youn
Yeah custom from the local muffler shop. I ended up paying 700 for parts and labor :D
Old Aug 13, 2018 | 06:54 AM
  #589
JABowders's Avatar
JABowders
Veteran: Army
Well I just had to show off ... here are the three brothers ..
three brothers (left to right) 81, 211, and 24
Old Aug 15, 2018 | 09:17 PM
  #590
MC40Russ's Avatar
MC40Russ
Just picked up #840 from Wyoming
I just bought MC40 #840 a little over a week ago. Been cleaning it out, since the previous owner had it stored in his garage under a cover. It only had 33,500 miles on it, till I drove it back to Oregon. Getting the Supercharger pulley and intake done next Friday. Totally stock, the Racing numbers were missing, so I will need to get a set of those.
Old Aug 16, 2018 | 05:25 AM
  #591
JackMac's Avatar
JackMac
Nice find!
Old Aug 16, 2018 | 07:09 AM
  #592
Cincy_jro's Avatar
Cincy_jro
Jealous!!!!!
Old Aug 17, 2018 | 10:05 AM
  #593
Nice
Old Aug 18, 2018 | 05:45 AM
  #594
Akumazeto's Avatar
Akumazeto
Picking up a unknown numbered example this week in ND! Bringing it back to Wisconsin .
Old Aug 20, 2018 | 05:27 AM
  #595
Awesome, post up.
Old Aug 21, 2018 | 10:25 PM
  #596
MC40Russ's Avatar
MC40Russ
Any word? It's great that more are being found and taken care of...
Old Aug 22, 2018 | 06:15 AM
  #597
Akumazeto's Avatar
Akumazeto
I am leaving for ND on Friday I should have pics by Saturday.
Old Aug 31, 2018 | 07:03 PM
  #598
rockridge's Avatar
rockridge
thats awesome!!! you are the king of MC40'S
Old Aug 31, 2018 | 07:14 PM
  #599
rockridge's Avatar
rockridge
Added a sunshade to my MC40. It''s had been garaged all it's life, and now that I own it, it lives outside.
New Sunshade
Old Sep 4, 2018 | 06:33 PM
  #600
Akumazeto's Avatar
Akumazeto
Decals from sticky fingers will be here in morning
