R50/53 The Official MC40 Owners Club
Old Dec 29, 2017 | 11:45 AM
  #501
You have to make sure when you do this its free and not locked too much, also you need to make sure the internal lock is ok and not just failed.
Most likely you did not mess it up but the ignition part might be bad.
Ignition Switch Part #61326913965
https://www.northamericanmotoring.co...on-switch.html
Old Dec 29, 2017 | 01:22 PM
  #502
rockridge's Avatar
rockridge
I would like to replace my R90 wheels with new ones, but the price these days is pretty steep. Over $1400. Going to see if Rim Pro can remove the corrosion when I get the JCW tune installed.
Old Dec 29, 2017 | 01:25 PM
  #503
You can do that. Just like web spokes:
https://www.northamericanmotoring.co...-question.html
If you did not have 4 pot JCW brakes on the front you could run 16" R90. Which are 51% off. 36116775855 Also have all the r90's there.
https://www.ecstuning.com/Search/SiteSearch/R90_Mini/
Old Jan 2, 2018 | 01:13 PM
  #504
JABowders's Avatar
JABowders
Veteran: Army
Saved another... just picked up #81 (I think) Lots of work to do, but with luck in a month or two it will be running again.
Old Jan 2, 2018 | 01:22 PM
  #505
Congrats on the JCW version. They are rare, but i have seen a lot of MC40 JCWs
Old Jan 5, 2018 | 09:31 AM
  #506
rockridge's Avatar
rockridge
The JCW update is going to be expensive, cost me $4300 for the kit, then I need to have it installed. The good news, is I will get a new supercharger as part of the upgrade. Considering if I should have water pump replaced at the time of installation...
Old Jan 5, 2018 | 10:59 AM
  #507
JackMac's Avatar
JackMac
Definitely do the water pump, it’s basically free labor.
Old Jan 8, 2018 | 11:53 AM
  #508
+1 i would do the waterpump at the same time and check out that black off plate also.
Old Jan 17, 2018 | 09:30 AM
  #509
rockridge's Avatar
rockridge
Work scheduled for next week. Getting Clear bra installed on whole front end on Friday. Only driven the car twice. been nasty here in New Hampshire
Old Jan 20, 2018 | 03:18 PM
  #510
rockridge's Avatar
rockridge
Got replacement decals installed, and new XPEL self-healing clear bra installed. Car looks brand new!
Old Jan 24, 2018 | 11:35 AM
  #511
kaywh97's Avatar
kaywh97
Missing Commemorative Plate
Hey! I've got it in my head today that I MUST find out the number out of 1000 that mine is. The number plate is missing and unfortunately in the MC40 registry, it's not sorted by VIN. When I bought her and realized it was an MC40, we ran a car fax. I know she's stayed in GA and AL her whole life. I'm in the process of reaching out to dealerships about her. I thought maybe, just maybe, I might have some luck asking here. The VIN is WMWRE33404TD88845. Thanks!
EDIT: I got ahold of MINI of Kennesaw and confirmed that my Veronica is #911 out of 1000!!
Old Jan 25, 2018 | 07:49 AM
  #512
JABowders's Avatar
JABowders
Veteran: Army
Nice find, great looking car.
Motor On!
Old Jan 28, 2018 | 05:38 PM
  #513
rockridge's Avatar
rockridge
I like the number 911. Good to hear you found the number.
Old Jan 29, 2018 | 03:59 AM
  #514
JackMac's Avatar
JackMac
How did it go? Curious to hear your before/after impression.
Old Feb 1, 2018 | 05:10 AM
  #515
rockridge's Avatar
rockridge
Everything went fine. See my earlier post for Picts. Its the 3rd car that I have had the front end wrapped with XPEL. Stuff is amazing. I love to detail my car, and make it look brand new. With the XPEL, you never need to buff or polish the front end again.
Old Feb 1, 2018 | 06:16 AM
  #516
Cincy_jro's Avatar
Cincy_jro
Guys and gals...
Looking to gauge interest in my MC40. I've put a lot of time into the maintenance recently but just had the flywheel come apart. Wife says it needs to go before I try and start putting more money into it.
2nd owner since 16k miles. Now has 143k ish. R90's are in need of a refresh (paint on lips peeling) and new tires. The clutch/trans needs maintenance. This MC40 has all its bits (shift ****, floor mats, number plate on console (#807), carbon dash with JCW logo...)
Replaced:
Front ball joints (inner and outer both sides)
LCA bushings (powerflex)
Right upper engine mount (new stock unit)
New axle assemblies (both sides)
Replaced struts with used (low mile) units and refreshed the spring pads (rubber bits between spring and seats)
New coil pack, plugs and wires
M7 2% OD crank pulley
Cravenspeed 15% SC pulley
DDM intake with silicone intake pipe
DDM IC diverter
MINI Mania 22mm rear sway with poly bushings.
Replaced rear strut bearing on drivers side (pass side still needs replaced)
Replaced rear MC40 decals but never got around to installing the new bonnet decals.
New left front wheel bearing
Head replaced at 130k miles with used unit from Daveke (35k miles on replacement). Cylinder 2 plug shot out and stripped the threads. Helicoil wouldn't work so I replaced the whole head. During this I replaced:
Head gasket, supercharger inlet/outlet seals, throttle body gasket, BPV upgraded to facelift unit, replaced MAF sensors pre and post SC. emptied and replaced SC fluid, intake manifold and exhaust manifold gaskets, valve cover gasket and plug seals, replaced oil pump rings and seals, belt tensioner and idler pulley replaced, timing chain, chain guides, chain tensioner, cam gear, flushed oil coolant and steering fluid and refilled all with fresh.
I tried posting a while ago but interest was slim and offers were very low. I'd like to get about $2k for it as is. It starts and runs strong but no power gets from the crank to the transmission. Believe the flywheel is separated and needs replaced. I figured it would be best to see if anyone in here would be interested since we know the value of these MC40's.
Cross posting in the For Sale section but wanted to make sure you all appreciative MC40 owners get to see it first.
Attached Thumbnails The Official MC40 Owners Club-img_20171007_092521.jpg   The Official MC40 Owners Club-img_20171007_092512.jpg   The Official MC40 Owners Club-img_20171007_092459.jpg   The Official MC40 Owners Club-img_20171007_100020.jpg   The Official MC40 Owners Club-img_20171007_100059.jpg
Old Feb 1, 2018 | 05:53 PM
  #517
JackMac's Avatar
JackMac
Ah sorry, I meant to ask about the JCW Tuning kit install. Was that done?
Old Feb 2, 2018 | 04:08 PM
  #518
rockridge's Avatar
rockridge
So far so good. Like the extra pep and sounds much better. It might have been silly to spend the money on a 14 year old car, but now it will be more fun to drive in weekend Ralleys.
Old Mar 18, 2018 | 05:01 PM
  #519
rockridge's Avatar
rockridge
Wheeler Dealer TV show on Velocity will be featuring a Mini Cooper MC40 in new season that starts on April 11th. Not sure what episode it will be, but keep an eye open for it!
Here's Mine
Old Mar 20, 2018 | 07:16 AM
  #520
megaDan's Avatar
megaDan
Proud new owner of #807. Thanks Cincy_jro!
Looking forward to giving it some TLC and seeing where the road takes us!
Old Mar 20, 2018 | 07:20 AM
  #521
Cincy_jro's Avatar
Cincy_jro
Been a great MINI for the last 10 years. I hated to see her go but life keeps moving right? Keep us posted here! I'd love to see what the next phase is!
Old Mar 20, 2018 | 11:21 AM
  #522
JABowders's Avatar
JABowders
Veteran: Army
Paddy Hopkirk will be at Allentown MINI on Sept 6 prior to the Vintage Races up at Watkins Glen that weekend where he will be the Grand Marshal, MINI is the Marque of Celebration.
I'll be there with at least one of my MC40s...
Motor On!
Old Mar 20, 2018 | 12:44 PM
  #523
Thats awesome! I would get all three up there for a group shot!
Old Mar 24, 2018 | 06:44 AM
  #524
JackMac's Avatar
JackMac
"2004 Mini Cooper S MC40"
Velocity Premiere Wednesday, April 25 at 9 PM ET/PT
Mike tracks down one of only 1,000 MC40s ever produced, the 40th anniversary homage to the Monte Carlo rally-winning British icon. Ant tackles the dreaded 100,000 mile-service while restoring its original ride height and signature look.
Old Apr 8, 2018 | 10:22 AM
  #525
rockridge's Avatar
rockridge
One of my favorite picts
