R50/53 "Convenience Opening" --- Yay or Nay
Picked up my 05 MCS from the dealer today, who was suppposed to activate "convenience opening," which they forgot to do initially upon delivery. Well, turns out the mighty MINI sevice staff de-activated "auto-unlock" instead. Greeeaaat! It was too late to get that mistake reversed today, so I ended up talking to a MA about that feature, and he suggested that it might not be such a good idea to have it activated after all. Seems like the problem-ridden window motors experience even more stress that way, and the battery might get slowly drained as well (that one sounded pretty suspect).
Now -- I REALLY want that feature though. What are everyone's thoughts on this? Any bad experiences so far?
Thanks,
Thanks,
Is that the feature that allows you to open and close the windows with the key/fob?
If so, then: Yay!!
I love it on a hot day and definitely recommend it. And, having all the windows and roof close at the same time while you stand outside looks cool.
dan
If so, then: Yay!!
dan
I’ve never had a window motor go bad or loss of battery on my 02 MCS for any reason, let alone using the auto unlock feature. Living in Florida I use this feature constantly to lower the windows and release the hot stuffy air from my MINI before I get to the door.
Why would using the remote to do what you'll do with the switch inside make any difference to the motors? Sounds like MA BS to me.
I love the convenience opening feature.
I have it and think it's great. There is one thing to be careful of. There have been reports (and I have experienced....
) of peoeple accidentally opening their windows while inside their homes or offices. On the plus side, it seems that the remote is less sensitive on my '05 than it was on my '02.
If so, then: Yay!!
dan
If so, then: Yay!!
dan
Still, I give convenience opening 2 thumbs up, or one thumb up and the other one holding the button down
$.02 from Tatt
If you live in a place that's hot all the time, then yay.
If not, then no because your windows might accidentally open sometimes. If it's raining, and you put the key in your pocket. The button might be pressed and the windows will open. It only happen to me once, coming back to my car and the window is half open.
Get that feature! (it will be much unconvenient when you need to put the key in and do the open or close)... your MA just give you a bunch of BS. You paid full MSRP, and you deserved to get any setting you like. I never have problem with the convenient opening on both my MINI and Bimmer. Regards to battery drain, it won't drain until you use it, and the system is design for retaining power after the car shut off, it shouldn't be any problem with it.
If your MA give you more BS, tell him that you will give him the lowest rating when MINI call for evaluation.
Do what makes you happy of course, however I vote nay. I had mine deactivated after finding the car had opened the windows on its own a few times
Besides, I had the same feature on bimmers for years before and found I very rarely used it - sounded neater then it really was functional to me. Figured I'd rather be able to leave my Mini closed and find it that way when I get back and just use the key in the lock should I want to open up the two windows and roof simutaneously.
Scary what your MA told you since it either indicates that he is ridiculously uneducated about the car and its issues or he is lying/making something up to sway you from having them reprogram
*The odd thing about finding the windows open is that there was no way the key was pushed in the interim either...
Edit: I also do not find using the lock to be any less convenient then using the fob since you have to stand so close holding the fob to get it work anyway. I remember when I wanted to show this 'cool' feature to a friend a long time ago with the 3 series and in the end felt pretty silly standing near enough to the car and pressing the fob for as long as it took to finish the process when I coulda been in there with the AC blasting by then
*Besides, I had the same feature on bimmers for years before and found I very rarely used it - sounded neater then it really was functional to me. Figured I'd rather be able to leave my Mini closed and find it that way when I get back and just use the key in the lock should I want to open up the two windows and roof simutaneously.
Originally Posted by Riddler
That's not working right now either.
Even the some of the latest Japenese car already have that feature STANDARD.. I wonder what your's MA doing.... They should give you a check list about what feature to turn on before the delivery. I hope you are not like me (1 hrs away from the dealer), otherwise it is a pain for driving back an forward to have that thing done...
Range of the key is a bit weak usually, and some sides of the car get better distance than others...I find it usually helps to hold the end of the key to my chin as I hold the button down to get more range.
Looks funny walking across the parking lot, though.
I did get that checklist (after specifically requesting it, that is) before delivery, and checked the CO feature. Just never got around to bringing it back to the stealer (Schomp in Denver) until now. Most of the MAs that I've met there so far are arrogant p@nks. Most of them, not all of them.
I'll take it back tomorrow, and just wait around until they get it right, its not too far away.
I use mine almost every day. My remote is not that far, but I can walk to my car and the windows will at least be down a few seconds before I get in. When it is 90 plus degrees that helps a lot. When it is cooler out, the difference is even more dramatic.
Also, definitely make sure they enable auto unlock as well. Much better than having people tear your handles off.
