R50/53 SC Pulley Removal Tips
Old Apr 11, 2026 | 08:12 AM
jcampbell6768's Avatar
jcampbell6768
Hey Guys,
Are there any tips / tricks / ideas on how to remove the supercharger pulley?
I have the tool, and I’ve been able to lock it down pretty tight without slipping, but the pulley will not budge. I have sprayed some penetrating lube on it; just waiting to see if that helps.
Any ideas on how to make this go a bit more smoothly?
Old Apr 11, 2026 | 09:40 AM
Ngtphantom's Avatar
Ngtphantom
I have learned over time with these cars that all pulleys/bolts can be hard to remove .
Have you tried to heat the old pulley first then spraying the penetrating lube right before trying to remove it ?
usually penetrating lube is a patience game , having to spray it a couple of times and leaving it for quite a while between sprays
Old Apr 11, 2026 | 09:48 AM
jcampbell6768
I do have some patience when it comes to spraying the penetrant; I don’t have a way to heat the pulley though, although it would probably be a better (and faster) solution. Thx!
Old Apr 12, 2026 | 12:33 PM
BRGPA's Avatar
BRGPA
One thing I remember is when a group of us were removing a club member's pulley it was scary how close it came to the front "frame" member on the right side before it popped, and I mean released suddenly with no warning. It was tight to get it out afterwards, but we finished with no issues. I think heat could help, but don't go crazy with it, and don't pound on the shaft. Good luck!
Old Apr 12, 2026 | 08:05 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Heat - use with caution.
If I can remember correctly -There is a rubber seal behind the pulley in the snout of that shaft.
Old Apr 12, 2026 | 08:33 PM
jcampbell6768
Yea, it’s becoming a pain in the butt, and almost more of a headache than what it’s worth. I’m beginning to rethink my plan…
I’ve got the SC ready to install; did the oil service, and cleaned it up; looks brand new! Wanted to run the 15% reduction, but I’m tired of fooling around with it! HaHa!
Old Apr 13, 2026 | 04:35 AM
noodlesandsam's Avatar
noodlesandsam
I bought a used Dinan pulley on eBay. It came with a supercharger attached. Maybe this is why that happened.
Old Apr 13, 2026 | 05:42 AM
jcampbell6768
HaHa! That’s funny!
I’ll probably still try and mess with it later on; just a bit of frustration. I do have a friend in Daytona who may be able to help, whenever he has the time. He has is own shop and is a former MINI tech from Orlando. About an hour drive for me. May need to do a road trip…
Old Apr 13, 2026 | 06:02 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
"Patience is a virtue". A BERNZOMATIC propane torch from Walmart with piezo start will set you back less than $25. Also, have you tried KROIL? It's the best penetrating oil on the market. I believe ACE hardware stocks it.
Old Apr 13, 2026 | 03:11 PM
jcampbell6768
Never heard of KROIL…I’ll check it out!
Old Apr 13, 2026 | 04:58 PM
noodlesandsam
Kroil is good - smells funky
Old Apr 14, 2026 | 07:28 AM
JABowders's Avatar
JABowders
Veteran: Army
Old Apr 15, 2026 | 06:51 AM
phone_cover's Avatar
phone_cover
get you something like this to put around your puller. get that good and tight. then just crank the puller until it comes off.
Old Apr 15, 2026 | 09:42 AM
Here2Go's Avatar
Here2Go
NAM Community Team
^^^+1^^^
Watch the ModMini video if you haven't...
I purchased and used the same vice chain when R&R-ing my SC pulley. Made the task so much easier and without damage.
Some have also had success gripping the pulley/pulley tool using a good quality oil filter wrench.
Old May 11, 2026 | 12:40 PM
T0mmy's Avatar
T0mmy
kroil >> pblaster >> anything else
also, I like the smell lol
frankiev
May 29, 2022 01:18 PM
frankiev
May 12, 2022 02:19 PM
youloze
26
Oct 28, 2013 04:54 PM
chisss
Dec 3, 2007 08:40 AM
CustomAV
Dec 7, 2004 07:36 AM
