R50/53 Shift cable boots (at end of cable on linkage)
Old Dec 5, 2025 | 06:56 AM
JustinR's Avatar
JustinR
Hey all when dropping my transmission and removing the shift cable connections to the linkage the rubber/plastic boots pretty much disintegrated, is it possible to replace these somehow without replacing the entire cable? are they needed for proper function if i just leave them as they are?
Old Dec 5, 2025 | 07:09 AM
ssoliman's Avatar
ssoliman
there are upgraded metal ones from the facelift models. i know that did not answer your question
Old Dec 5, 2025 | 08:32 AM
Scoobaru2010's Avatar
Scoobaru2010
@JustinR I believe your looking for this? https://www.bushingfix.com/mini-coop...ushing-repair/
edit: link the wrong one, https://www.bushingfix.com/mini-coop...ushing-repair/
Old Dec 5, 2025 | 08:58 AM
JustinR's Avatar
JustinR
Originally Posted by Scoobaru2010
While good to know for sure because the bushings themselves are a bit beat i was more curious about this part that crumbled circled in green.
Old Dec 5, 2025 | 09:00 AM
JustinR's Avatar
JustinR
honestly was thinking about putting on a spring around the cable there if it's needed for proper function.
Old Dec 5, 2025 | 09:03 AM
ssoliman's Avatar
ssoliman
shift cable might be your root cause in your other post / thread
Old Dec 5, 2025 | 10:39 AM
Here2Go's Avatar
Here2Go
NAM Community Team
May sound rediculous but - alternatively, you might consider a salvage yard? I've come across some junkers with fairly new or "garage kept" parts on them. I don't build/maintain or replace parts on my Mini with salvage parts - but somethings are unfortunately not sold or not intended to be manufactured = "planned obsolescence".
With consideration to replacing your shift cables - Beware/be advised - depending on when your Mini was built; early pre-facelift ('02-early'04), these cables can be difficult to source (I think there are three variants for the early models). If you have a Mini built after July '04, Your in luck. The facelift cables can be had....
Although, from your picture it appears that you have the early model Mini (?).
Contact@WayMotorWorks Way was able to source the cables for my pre-facelift '04.
Perhaps you might source Home Depot or McMaster Carr to improvise something? (small Vacuum cleaner hose, wire sheeting, a spring + shrink tubing?)...
Old Dec 5, 2025 | 10:59 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Edited above^^^
Ceck the McMaster-carr link above.
It might suit your improvised (bellows) needs.
Old Dec 5, 2025 | 06:44 PM
JustinR's Avatar
JustinR
Originally Posted by Here2Go
Edited above^^^
It's a 2005 but i agree the shift cables look like preface lift ones ive been seeing.
Old Dec 8, 2025 | 07:36 AM
ssoliman's Avatar
ssoliman
plug your vin into realoem to see your production date. then lookup your cable part number.
you could be production date right before the change as it were
Old Dec 8, 2025 | 10:41 AM
Dependent on model and year. We do have those of those cables in bremmen parts on sale. https://www.ecstuning.com/b-bremmen-...train-shifter/
Run your vin through realoem to double check and watch as some models dependent on year have variants. Condition "A" and Condition "B" and realoem will show a picture of your shifter base to match.
Xplct
May 2, 2023 02:33 PM
Patrick A. Peets
Aug 14, 2021 07:06 AM
trashmanbob
Jun 24, 2017 05:29 PM
Paul!
Electrical
Feb 15, 2015 07:05 PM
