R50/53 back shocks bottom out on bumps
Old Mar 20, 2025 | 02:50 PM
  #26
ssoliman's Avatar
ssoliman
Originally Posted by bump32
Rear motion ratio is around 0.87. Not sure if the front has a motion ratio.
Curb weight of 2,853 (with driver) and 62.7/37.3 % weight distribution.
I started to do the math on this but never finished. Let me know what you figure out.
Let me see if i can do the math. been some time since algebra classes
Old Mar 20, 2025 | 02:51 PM
  #27
ssoliman's Avatar
ssoliman
Anyone know what the front motion ratio is in the front (if there is one)?
Old Mar 24, 2025 | 06:43 AM
  #28
deepgrey's Avatar
deepgrey
Originally Posted by ssoliman
i think we are basically saying the same thing. although ive never heard that about the stock bump stops.
I'm looking for a spring rate that will not allow bottom out and a stop that will not fall apart.
KW says they will send me new ones for $9 each. But i'm hoping i can do better. I'm hoping someone has found a better way
Yeah, we probably are. Not that I’ve looked at bump stops on coilovers, well, ever, but I’m surprised those disintegrated that badly.
Old Mar 24, 2025 | 07:01 AM
  #29
Here2Go's Avatar
Here2Go
NAM Community Team
I can't remember wich or when; but I do recall ordering and replacing my bump stops with powerflex.
It might be something to consider?
Old Mar 24, 2025 | 03:25 PM
  #30
ssoliman's Avatar
ssoliman
thank you sir i will look at powerflex and see what options they have. I've had good luck with their stuff. i also ordered two new stops from kw just so i'm prepared once the coilovers are out
Old Mar 24, 2025 | 06:22 PM
  #31
ssoliman's Avatar
ssoliman
here are the powerflex stops. now I'm thinking these would fit the stock assembly but not sure about the fit on the KW coilovers.
https://www.powerflexusa.com/shop/pf...-2783#attr=209
Old Mar 24, 2025 | 06:37 PM
  #32
deepgrey's Avatar
deepgrey
Those go where the rear struts mount to the body. These are the bump stops for the stock setup.
Old Mar 24, 2025 | 06:49 PM
  #33
ssoliman's Avatar
ssoliman
did the math from these numbers and I get:
256.499938 lbs/in
4.580582 kg/mm
44.92 n/mm
thats for the rear. assuming the 2hz ride frequency (sporty ride).
so im at 200 lbs/in. which makes sense. a bit soft
Old Mar 24, 2025 | 06:54 PM
  #34
ssoliman's Avatar
ssoliman
KW confirmed that the springs on this kit are 200 lbs/in, not progressive. I think I said they were progressive earlier. that was wrong
Old Mar 24, 2025 | 07:09 PM
  #35
ssoliman's Avatar
ssoliman
hold on, I found these from powerflex. these look like they could work. I'll probably order them and have them as an option
https://www.powerflexusa.com/shop/bs...cover-kit-2575
Old Apr 7, 2025 | 01:56 PM
  #36
ssoliman's Avatar
ssoliman
received new bump stops from KW and PowerFlex. Which ones would yall use?
Old Apr 7, 2025 | 02:26 PM
  #37
bump32's Avatar
bump32
My guess: The Powerflex poly are going to be slightly stiffer when you hit the bump stop but will last longer. The KW ones will probably be a little softer but, like the last set you had, may break down quickly if you are bottoming out and hitting hard on the bump stops.
My 2 cents.
Old Apr 7, 2025 | 03:33 PM
  #38
Here2Go's Avatar
Here2Go
NAM Community Team
Personally - Powerflex.
Those KWS still look like the typical foam rubber ones that have a tendency to breakdown in a short amount of time.
Since your Mini is lowered, you may still have to cut the bumpstops down a bit. If you cut them both - You will automatically see the difference in density and material.
I'm impressed to see you're putting such effort into understanding and fine tuning your suspension.
Old Apr 8, 2025 | 11:04 AM
  #39
ssoliman's Avatar
ssoliman
thank you both. i think i will go with the PowerFlex ones. I'll probably cut to match the height of the KW's.
Will get back with results. might be a bit. the projects are stacking up
schreiber117
Suspension
Oct 19, 2013 06:00 PM
mini4tide
Suspension
Nov 17, 2011 07:54 PM
Londo
Sep 12, 2007 01:32 PM
koenner1
Suspension
Jun 12, 2005 12:27 PM
Detonate
Suspension
May 9, 2005 07:26 PM
