R50/53 07 engine swap to an 03 MCS ?
Old Apr 5, 2022 | 07:05 AM
frankiev's Avatar
frankiev
My engine is done in my 03 MCS . I found an 07 with 68k miles from a convertable . I'm being told it's a supercharged engine but the info I found says 07 was turbo not supercharged. Will the 07 fit ok? . Is it SC or turbo ?. Any other differences? Thanks
Old Apr 5, 2022 | 07:19 AM
Thomas Burdek's Avatar
Thomas Burdek
The supercharged convertibles continued until 2008. The hatchback switched to turbos in 2007. If it is from a convertible then yes it is a supercharged one. I do believe the wiring harness will be different as it is a different ecu and the facelift engine. You would need a facelift ecu and getting everything working. Best would be contacting adriancl for all of the coding of switching from pre to post facelift.
Old Apr 5, 2022 | 08:16 AM
frankiev's Avatar
frankiev
Well that's not good . Is the harness different due to lights and the gauges ?
If I go with 03 to 05 engine I'm good with the harness etc?
Old Apr 5, 2022 | 10:26 AM
checkers's Avatar
checkers
Can't you rebuild yours?
Old Apr 5, 2022 | 12:19 PM
frankiev's Avatar
frankiev
Engine locked up , metal in the oil
Old Apr 5, 2022 | 02:22 PM
Thinker2112's Avatar
Thinker2112
Try contacting Way Motor Works and ask them if the 07 block will work. If anyone that will answer your question that will also know, WMW would.
Old Apr 6, 2022 | 08:31 AM
frankiev's Avatar
frankiev
From Way motor works " No you don't need to do anything with the ECU. Jus reuse your ECU and wiring harness, you can use the wiring from the 07 engine, but the ECU from the 07 won't work in your car. But no need to do that as your ECU will work fine as they are the same engine. "
Old Apr 6, 2022 | 09:34 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
With exception of a few sensor plugs not matching like crank and cam sensors , it's a direct drop in engine..newer year the sc has coated rotors if it's included but other than that nothing better about it or worse...your wire harness will be fine , just take off what sensors you might need from the bad engine to good engine..
Old Apr 8, 2022 | 10:45 AM
frankiev's Avatar
frankiev
As it turns out that engine was purchased before I could arrange it but I found an 04 with 80k .
Will any engine stand work with the mini ? Can anyone recommend a cheap one ?
Old Apr 8, 2022 | 11:29 AM
AngryScotsman's Avatar
AngryScotsman
Any engine stand will work. Harbor Freight is your friend for the cheapest one:
https://www.harborfreight.com/automo...and-69886.html
The standoffs on the rotating assembly of the engine stand can be rather long, so you may need longer bolts to mount the rotating assembly to the engine... but they can be found pretty easily at any hardware store.
Old Apr 8, 2022 | 11:40 AM
frankiev's Avatar
frankiev
Thank you
AlecIssigonis
Oct 5, 2021 09:25 PM
beckham23
Aug 15, 2006 11:48 PM
willymcd
Off-Topic :: Autos
19
Apr 19, 2006 05:53 AM
rcrogers
Aug 13, 2005 11:06 AM
chollomo
Jun 28, 2004 07:46 PM
