R50/53 R50,52,53 xenon headlight lens source?
Old Mar 5, 2022 | 09:18 PM
Ken Garchow's Avatar
Ken Garchow
has anyone here found a source for new replacement lenses for the headlight lens on the facelift xenons?
thanks
ken
Old Mar 6, 2022 | 05:35 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I haven't.
Although I have a pre-facelift '04 R53 - I was searching for lens replacements in the last few years. To no avail; I wound up successfully polishing the original lenses, by hand, back to 95% original clarity with
3M Rubbing Compound 03900. 3M Rubbing Compound 03900.
The results are a tremendous improvement. However, I'm still hoping that replacement lenses will eventually become available.
Old Mar 6, 2022 | 08:15 AM
Ken Garchow
better lens
thanks for reply
its interesting my lenses look fine or the most part but when look at from an angle they have many small cracks in them, like crazed. this won't sand out
Old Mar 6, 2022 | 10:43 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I guess I am somewhat fortunate. My lenses appear to have no crazing. I have the washer feature.They are perfectly clear but with very, very slight yellowing compared to new. Not strikingly noticeable. It is not unsightly.
I looked on Ebay "pre owned" @ $180ea - $250ea. Some Pics looked good but received no response from sellers for further inquiry regarding crazing.
I frequent salvage yards (headlight assbly $50ea), and always look for a clean garage kept R53 with washers. They can be hard to come by. Even if I luck out + having a heat gun, almost seems to be more work to swap out lenses successfully.
Then there's this aftermarket example:
Mini Cooper 2002-2005 pair headlight assembly. Mini Cooper 2002-2005 pair headlight assembly.
.....compared to the cost for a new OEM replacement assembly.....
Old Mar 6, 2022 | 08:36 PM
scf's Avatar
scf
You can use halogen lenses on xenons.
Old Mar 7, 2022 | 05:25 AM
AcidK1's Avatar
AcidK1
They don't have the cut out for the washer jet do they?
Old Mar 7, 2022 | 08:12 AM
Ken Garchow
i have heard they aren't the same lens but if just the cutout for the washer, could we grind that area out for the washer? u guys may be on to something here?
Old Mar 7, 2022 | 10:02 AM
AcidK1's Avatar
AcidK1
Maybe if your handy with tools, but I don't think you would ever get it sealed properly so would probably fog up inside. :/
Old Mar 12, 2022 | 10:54 AM
cut7's Avatar
cut7
Originally Posted by Here2Go
I haven't.
Although I have a pre-facelift '04 R53 - I was searching for lens replacements in the last few years. To no avail; I wound up successfully polishing the original lenses, by hand, back to 95% original clarity with 3M Rubbing Compound 03900.
I used this
3M kit 3M kit
. I would say Here2Go is correct; the polish kit & less than an hour's work gets the lenses back to about 95% of original clarity. I did mine 2 years ago, & they're still pretty clear. Make sure you tape off the chrome ring really well. Take your time & you'll be pleased with the results.
Old Dec 21, 2024 | 05:37 AM
androghost's Avatar
androghost
hello. have you tried it yourself? Does it make difference if they are pro or after facelift?
FerrariMX5
Sep 10, 2011 09:19 PM
dr_phatcity
11
Nov 12, 2008 07:05 PM
dcsmd007
Feb 10, 2004 10:09 PM
m3ster
15
Nov 11, 2003 05:29 AM
