R50/53 R53 and hi everyone
Old Jan 31, 2022 | 02:15 PM
Majestic13's Avatar
Majestic13
R53 retrofit navi and hi everyone
Hello guys im new and hi everyone.
I have Mini Cooper S R53 2005/6 and i have 2 question im following this site for few years but i just registered. Ok i just switched from single gauge and central speedo to dual speedo and navi and EVERYTHING works great except i cannot get asc light on and of when i hit the switch anyone knows whats the problem?! And second i connected all wires from dvd/navi under the seat except one yellow with green line from red connector so can anyone tell me what that wire is for. Thanks a lot in advance.
Last edited by Majestic13; Feb 1, 2022 at 06:27 AM. Reason: for better understanding of theme
Old Feb 1, 2022 | 02:43 AM
adriancl's Avatar
adriancl
For ASC light must recode Instrument cluster.
Old Feb 1, 2022 | 05:13 AM
Majestic13's Avatar
Majestic13
i thought that too but was wondering how its possible that EVERYRHING else works perfect except asc only
Old Feb 1, 2022 | 11:57 AM
adriancl's Avatar
adriancl
Check for fault codes, will get the right answer.
Old Feb 1, 2022 | 04:00 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
do you still have the old cluster? You need to update the options in ncsexpert here's what I do. install old cluster, use ncsexpert to dump the settings and save them somewhere safe. Install the new cluster, use ncsexpert to dump the settings and go line by line
DSC has it's own section, you can also use ncsdummy to make it easier you probably have a nav from a ASC-T or T car
Old Feb 1, 2022 | 04:09 PM
Majestic13's Avatar
Majestic13
thank you mate will try... oh i need to take off both clusters and gauges or just cluster middle one the big one😩 i have asc too on my car
Old Feb 1, 2022 | 04:14 PM
MrBlah's Avatar
MrBlah
just the middle, you can try winging it and just go into ncsexpert and toggle to try, pretty sure it's one or a combo of these settings but it's been a LONG time
Old Feb 1, 2022 | 04:17 PM
MrBlah's Avatar
MrBlah
also check "ASC" setting in kombi
I went though the whole thing and transferred settings that made sense and it fixed my DSC errors. I went from a single tac stock speedo to a dual gauge + nav
Old Feb 1, 2022 | 04:21 PM
Majestic13's Avatar
Majestic13
really appreciate mate, i did the same
Old Feb 4, 2022 | 09:54 AM
Majestic13's Avatar
Majestic13
ive bought a k+dcan interface infa ncs expert and whenever i try to connect i get messaage chassis is faulty or Datei konnte nicht zum Lesen geöffnet werden. I am so fu*king tired of this car whatever i tried to do always find a fu*king deadend for **** sake
Old Feb 4, 2022 | 10:18 AM
MrBlah's Avatar
MrBlah
getting it to work is painful, sounds ilke a bad install make sure inpa works first
Old Feb 4, 2022 | 01:39 PM
Majestic13's Avatar
Majestic13
inpa doesnt work ever i tried reinstaling 20 damn times but had a little step forward i got chance to select ews but after i select ews i got this
Old Feb 4, 2022 | 01:51 PM
MrBlah's Avatar
MrBlah
Looks like it's not setup right
I found it difficult I now clone my Dell that's all setup for inpa or insta and sell them on Facebook
Old Feb 4, 2022 | 02:07 PM
adriancl's Avatar
adriancl
Check first if pin 7 and 8 are bridged.If have a small switch on INPA,try to connect to the car using first one switch position if not work, try in oposite position of switch.If not have a switch, than remove INPA cover and solder a bridge between pin 7 and 8.If not work, pm me and i'll install in 10 minutes by remote INPA working version for R53.
Old Feb 5, 2022 | 11:25 AM
Majestic13's Avatar
Majestic13
inpa doesnt work ever, whatever i tried 😑 ill try in a few days again cause i overheated my laptop last night and took him to service, i had some progress with ncs expert but still chassis error and inpa do not work. My friend will bring me xp and ill try with windows xp dunno what else
Old Feb 5, 2022 | 11:27 AM
Majestic13's Avatar
Majestic13
hey mate your inbox is full so i cannot send pm.
thanks a lot mate, i will do it in a few days, last night my laptop overheated i was trying all night and i take it to service will be done i 3,4 days they said. I had some progress like i got options when i click file but after that again Vin chassis error
Old Feb 5, 2022 | 11:28 AM
adriancl's Avatar
adriancl
solved inbox full
exocet
Jul 24, 2024 03:52 PM
Scot
Jul 7, 2019 11:33 PM
Kiwiflavored
Jun 6, 2016 01:16 AM
crankshaft
Oct 12, 2013 04:47 PM
J_'09s
Electrical
Jan 14, 2010 01:42 PM
