R50/53 2006 R53 overheating questions
Old Jan 2, 2022 | 05:50 PM
BadMotoFo's Avatar
BadMotoFo
Long story short... The T-connector that connects the overflow tank to the rest of the coolant system broke while my daughter was driving the Mini. I was away at work so I told her let it cool all the way down and nurse it back home - 2 miles - and stop and let it cool when the temp gauge peaked. I realize now that trusting her to do this without extensive overheating may have caused head and/or cylinder damage. Thus, after replacing the T-connector the car has been having an overheating issue. Today, I attempted to bleed the system. I was able to bleed from the 8mm bolt but, as I ran the car for about 20 minutes with the front bleeder at the radiator removed I didn't see any coolant pass through until I turned the blower on - and the some coolant showed. I am thinking this might be caused by a bad thermostat. Does anyone have knowledge about what might cause minimal coolant to flow past the front radiator hose bleeder?
I then attempted to connect my Motive Products power bleeder to the reservoir to pressure test the system. Unfortunately, I could not get past a leak between the bleeder's cap and the reservoir - I'd like to be able to test the system to see if the pressure drops and possible if this motor is done.
Old Jan 2, 2022 | 09:56 PM
BlwnAway's Avatar
BlwnAway
Usually either a closed thermostat, low fluid level / air in the system.
FYI, in high overheat situations you're normally looking at a head gasket minimum, and quite often Head work from warping. (first gen Mini Heads are fairly soft and warp easily) But not normally any short block work.
Old Jan 3, 2022 | 02:59 AM
MVPeters's Avatar
MVPeters
Try topping the expansion tank full up & squeeze the top hose to 'pump' the coolant around while you bleed it.
Reset the tank coolant level once you're done.
Old Jan 3, 2022 | 07:18 AM
ssoliman's Avatar
ssoliman
I was able to rent (free) a presure tester at autozone
The bleed process is specific and can be found in TIS or Bentley
Old Jan 3, 2022 | 10:41 PM
BadMotoFo's Avatar
BadMotoFo
Thanks for the feedback. Thermostats are relatively cheap so I will replace. And I will check my local O'reily for a pressure tester. I'm hoping for the best but prepared for the worst…
Old Jan 24, 2022 | 06:35 PM
ghostwrench's Avatar
ghostwrench
Conclusion?
Have you resolved this issue yet?
I just experienced this on my way home from work tonight. I got away with an overheat issue (hose split open) 4 years ago with just replace that hose. I fear tonight's broken tee may mean head gasket and machine the head flat.
Old Jan 25, 2022 | 05:36 PM
BadMotoFo's Avatar
BadMotoFo
Work is busy so my rate of progress is very slow. I replaced the thermostat but that did not resolve the issue. However, when I removed the housing, I captured the coolant and upon pouring the contents through a strainer there was sediment and small pieces in the cloth I used. I spoke to a guy at Pelican Parts and he said he'd seen similar when a OEM water pump let go. I removed the water pump but the plastic rotor is completely intact. I will install the water pump and if still the overheating/no coolant coming out of the front bleed screw I believe I will have to swallow my pride and take it to a shop.
Old Jan 30, 2022 | 11:32 AM
ghostwrench
OK. Next Saturday (2/5) I will have my car in the shop to replace all (3) of those plastic tee's and most of the hoses. I pretty much ordered all the hoses and tee's for my car from FCP Euro since they are all original from 2003. I replaced my water pump, thermostat housing and radiator about a year ago when I replaced my supercharger.
I drove my Mini home about 3 hours after the overheat (it happened about a mile from home) and it drove fine. I have worked on cars that have overheated and they ran just fine until the engine got warm, so I'll road test my car once I replace the hoses, fill the coolant (I have a vacuum filler) and then pressure test the system before a road test of about 20 miles. If that road test is successful, I'll be cautiously optimistic that head work will be unnecessary.
Old Jan 30, 2022 | 04:52 PM
BlwnAway's Avatar
BlwnAway
Lol...
Now there's a phrase uttered by many a Mini owner...
A little luck never hurts, so good luck.....
chuckactor
Mar 21, 2025 01:24 PM
Oldboy Speedwell
Aug 31, 2018 01:35 PM
rosaymaan
Aug 22, 2017 05:36 AM
BernieCoop
Jul 30, 2015 04:02 PM
NC TRACKRAT
How to
16
Jun 7, 2013 02:15 PM
