R50/53 2003 On board computer not responding
Old Jun 29, 2021 | 10:20 AM
analyte's Avatar
analyte
On my 2003, the OBC is not responding. I do have the S550 option and the turn signal lever with the button. That said, the screen under the tach is blank and pushing the button has no effect.
Shouldn't the LCD screen show something even if the button on the stalk was non functional? Not sure if it being blank means the screen is out, bad fuse, or something else.
Thanks!
Old Jul 11, 2021 | 06:01 PM
analyte's Avatar
analyte
I pulled apart the column to verify the plugs were in tight, and all was good. I put things back together and tried again.
With the key turned prior to atarting, all the lights on the tach work. Even the hood ajar at the lower LCD even comes on. But is rest of the lower LCD is blank and pushing the OBC button on the turn signal lever does nothing.
Think my OBC button is bad? Should the screen show at least the last item selected rather than staying blank? Out of ideas and I don't want to waste money swapping parts just guessing.
Old Jul 12, 2021 | 05:59 PM
jjcsnlynn's Avatar
jjcsnlynn
Just curious. What is is the S550 option?
Old Jul 12, 2021 | 06:17 PM
analyte's Avatar
analyte
As noted on my build sheet, it's the option code for "On-board Computer".
Old Jul 14, 2021 | 07:42 AM
adriancl's Avatar
adriancl
Post a picture of LCD with ignition On please.
Maybe just need to be recoded.
Old Jul 14, 2021 | 08:54 AM
analyte's Avatar
analyte
Is this what you needed?
Old Jul 14, 2021 | 10:43 AM
adriancl's Avatar
adriancl
yes.LCD is dead, can swap with one from a dismantled car.
Old Jul 14, 2021 | 02:40 PM
analyte's Avatar
analyte
It's weird that the fault lights work on it, but the lcd is bad. Figures.....
​​​​​​At least it shouldn't need coding since I already have the option...lol
Thanks!
jeffster06
Sep 5, 2010 07:55 PM
bakerjam
Mar 23, 2009 07:58 AM
MINI-RACER 03
Electrical
Jun 16, 2008 12:32 PM
drno
Apr 29, 2008 07:38 AM
DPCooperS
Dec 8, 2005 06:45 AM
