R50/53 Creaky doors - solutions?
Old 06-22-2019, 07:29 AM
2ndof2's Avatar
2ndof2
2ndof2 is offline
My 06 R53 hatchback has the world’s most creaky doors! Every time I open or close them they sound like a crotchety old man (I’m also becoming one because of it so eventually won’t be able to tell if it’s the doors or me!) Anybody have the same issue and a possible solution? The Indy repair shop owner that I go to who is all about minis said there is no solution. I just don’t think he’s come across the solution is all.
Old 06-22-2019, 09:02 AM
Tgriffithjr's Avatar
Tgriffithjr
Tgriffithjr is offline
Spray the hinges and the door stops with lithium grease. Worked for mine.
Old 06-22-2019, 11:50 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
deleted
Old 06-22-2019, 02:13 PM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
That little black hinge thingie mid door is the culprit. Pull out the rubber boot guide and fire a shot of liquid wrench in the hole then work the door back an fourth a few times. Mine's starting to need another treatment as well.
2ndof2 (06-28-2019)
Old 06-22-2019, 08:20 PM
alconk's Avatar
alconk
alconk is offline
I just replaced both my door brakes. Problem solved.
Old 06-28-2019, 07:24 AM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
Spray some WD-40 on the hinges....easy fix.
Old 06-28-2019, 08:14 AM
ItsmeWayne's Avatar
ItsmeWayne
ItsmeWayne is offline
Originally Posted by tgriffithjr
spray the hinges and the door stops with lithium grease. Worked for mine.
x2
Old 06-28-2019, 03:07 PM
2ndof2's Avatar
2ndof2
2ndof2 is offline
I believe that’s where noise is coming from. It’s not the metal hinges so this sounds like the solution. Next creak to solve after that is (I think) my rear Eibach sway bar.
Old 07-01-2019, 07:17 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
Just talked about this here: https://www.northamericanmotoring.co...-checkers.html
speedbird_1
12-22-2021 02:23 PM
Benibiker
R60 :: Countryman Talk (2010-2015)
07-12-2017 10:18 AM
KiLO
03-02-2004 10:46 PM
Calvin77
04-25-2003 06:20 AM
amagnetta
11-15-2002 04:51 AM
Quick Reply: R50/53 Creaky doors - solutions?
