R50/53 2006 R53 no start help
Old May 21, 2019 | 08:57 AM
db21637's Avatar
db21637
I have an '06 CMS with 88k. I recently replaced the harmonic balancer and then drove the car for approx 10 miles. Now the car will not start. I have replaced the starter and tested the battery (good) but still no start. When I turn the key I can hear the starter relay click but nothing else happens. It is an auto and I have tried starting the car with brake pedal pressed and not pressed. There were no starting issues prior to this. Any suggestions? Any and all welcome.
Old May 21, 2019 | 11:24 AM
gumbedamit's Avatar
gumbedamit
Does it crank and it won't start?
Old May 21, 2019 | 11:37 AM
aboveliquidice's Avatar
aboveliquidice
Recheck all of the electrical plugs you may have touched during the balancer install. Crank and cam sensors, distributor and spark plugs.
Check to see if any code is being thrown via OBDII.
Clicks but no crank sounds like something wasn't plugged back in. What guide / reference did you follow?
Old May 21, 2019 | 01:27 PM
bansasn's Avatar
bansasn
Did you try to jump start?
Old May 21, 2019 | 02:49 PM
db21637's Avatar
db21637
gumbedamit - No, click only. Not turning.
aboveliquidice - I have checked all plugs touched and not touched. Checked all other plugs I could get my hands on. No OBD II codes, engine won't get far enough to log codes. I used ModMini YT video as go-by for harmonic repair.
bansasn - Jump does not change symptoms.
UPDATE: Replaced starter just to be sure, no change. Key off 0V to starter, key on 9.5V on small wire to starter, key to start 0.5V on battery wire to starter. Cleaned and tightened every ground point I could find. Battery load tested and checked OK.
Old May 21, 2019 | 05:22 PM
db21637's Avatar
db21637
IT'S A MIRACLE!!!!!!
I put the car in service mode and began checking every nut, bolt, plug, and connector. I removed and re-installed the alternator, starter, A/C compressor (kept A/C lines connected), and rad fan shroud.Checked the belt and tensioner. Did not find anything loose or unplugged or not connected. Then I put everything back together. AND, the car started.
No check engine light, no OBD II codes. Runs smooth, normal 4banger vibrations, good throttle response.
I'm befuddled.
Old May 22, 2019 | 07:15 PM
Tgriffithjr's Avatar
Tgriffithjr
Probably just a loose ground or connection that was coincidental to the work you did prior.
Idoitforthegas
Aug 30, 2018 12:03 PM
5879
Nov 30, 2016 05:47 PM
Alanberto
Sep 22, 2015 07:30 AM
Mini SUV
May 16, 2013 04:42 AM
ericmakkar
May 20, 2011 05:16 PM
