R50/53 R53 CV axle replacement question
Old Mar 31, 2019 | 08:02 AM
doomi's Avatar
doomi
I'm helping a buddy with a couple of things on his R53 Cooper S.
2005 with manual transmission.
While working we saw a huge tear in his inner CV boot on the passenger side. He's only keeping the car for 6 more months or so and we are thinking about dropping in a reman from O'Reilly for simplicity sake.
I see two options listed. 35mm or 40mm inboard seal diameter (axle seal?). Any idea how to tell which I have without pulling everything and measuring with calipers?
Any help is greatly appreciated.
Old Mar 31, 2019 | 08:29 AM
JAB 67's Avatar
JAB 67
check a www.realoem.com site or a RockAuto site. When I replaced the passenger side axle in my 2004 R53 there was only one choice but I do not know what the seal diameter it was.
Old Mar 31, 2019 | 08:45 AM
Tgriffithjr's Avatar
Tgriffithjr
I wouldn’t buy an axle from oreilly.
Old Mar 31, 2019 | 12:57 PM
TX-Mini05's Avatar
TX-Mini05
+1, I would just get a new boot and grease and clean up the old axle.
Old Apr 2, 2019 | 11:37 AM
doomi's Avatar
doomi
Thanks for the replies. After considering the options I'm going to go ahead and reboot the axle instead of replacing.
The only reason I was considering the alternative is because he doesn't intend to keep the car for long at all.
Old Apr 4, 2019 | 07:28 PM
doomi's Avatar
doomi
Well, things didn't go as planned. The bearing on the tripod hub somehow disassembled itself. I can't find a source for a replacement in the US unless I'm missing something.
Looks like we may be looking at the whole axle if I can't find anything.
Edit: No year listed for this, but I think it should work?
https://www.pelicanparts.com/More_Info/8950628.htm?pn=89-50-628-M60&gclid=Cj0KCQjw1pblBRDSARIsACfUG13xT660SHmY8d5t eTcFEVNh8zaRSo3IysyKTN820Y-qhjjTJ4HjgdQaAoEZEALw_wcB
Old Apr 5, 2019 | 04:34 AM
Tgriffithjr
You can’t buy individual parts you have to buy the axle.
Old Apr 5, 2019 | 04:39 AM
TX-Mini05's Avatar
TX-Mini05
What side is that? I have a spare axle. Only thing that is wrong is the part that slides into tranny is rounded off. But the bearing should be fine
Old Apr 5, 2019 | 07:43 AM
iwashmycar's Avatar
iwashmycar
Dont those bearing things just slide back on?
Old Apr 5, 2019 | 07:46 AM
TX-Mini05's Avatar
TX-Mini05
Yes they do. I have had some come off before. But if you loose one it’s game over.
Old Apr 5, 2019 | 12:21 PM
doomi's Avatar
doomi
Its passenger side inner CV. If you do have one I'd love to buy it from you.
They do, but now that it came off I can't get the collar to hold it back on. It just slips on and off. I have all of the rollers.
Old Apr 5, 2019 | 12:28 PM
TX-Mini05's Avatar
TX-Mini05
[QUOTE=doomi;4461581]Its passenger side inner CV. If you do have one I'd love to buy it from you.
I have the driver side only. Where are you located? There is a mini junk yard here in ft worth Texas. RPM mini parts. Might call them and see if they ship. If not I’ll get it for you and ship it. Way cheaper. I got my oem axle for around 55$
Old Apr 5, 2019 | 02:52 PM
doomi's Avatar
doomi
[QUOTE=TX-Mini05;4461584]
This is great info. I'll reach out to them tomorrow morning.
Thanks for the replies everyone.
Old Apr 7, 2019 | 08:41 AM
Tgriffithjr
Here is a company in Fort Worth that rebuilds axles and rack and pinion. They have been around for years and are highly rated. I used them once years ago and they were very reasonable then and probably still. Might help you if you’re in FW or maybe you can ship to them.
Old Apr 7, 2019 | 07:47 PM
Tyler747's Avatar
Tyler747
just buy a new one
While rockauto isn't OEM quality, they are good enough to last a few years at a minimum. For the cost and relative ease of putting one in I would just buy a new one from there, or actually thats what I did and I don't regret it. My two cents.
Old Apr 8, 2019 | 05:56 AM
iwashmycar's Avatar
iwashmycar
Could probably still use it...once it is in the 'tulip' cup they shouldnt be able to come off.
jetsr6
Jun 2, 2021 08:19 PM
nasomi
Sep 20, 2018 09:45 PM
ramjet77
Oct 10, 2016 08:02 AM
pmfranke
Jul 19, 2012 01:33 PM
Keep Up
Cooper (non S)
Jul 9, 2008 02:41 PM
