R50/53 Timing Tool in Portland
Old May 1, 2018 | 12:31 PM
wojtek@pagacz.ca's Avatar
wojtek@pagacz.ca
Hey,
I just order a dominator cam from RMW and looking forward to installing it. Does anyone in the Portland are have a timing tool I could borrow. In return I will provide a 6 pack of your choice as a token of my appreciation.
Thanks!
Old May 1, 2018 | 12:44 PM
Thinker2112's Avatar
Thinker2112
You may want to check out the Portland Tool Library. One of them may have one, or Barbur Blvd Rentals. They rent everything.
I'll talk a 6er of Hop Valley's Citrus Mistrusts though... mmmmmm.... beer....
"To alcohol! The cause and solution to all of life's problems" - Homer Simpson.
Old May 2, 2018 | 07:10 AM
wojtek@pagacz.ca
Thanks. I check them out but I somehow doubt they have such a specialty tool.
Old May 2, 2018 | 09:07 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am at a lost as what timing tool is required to install a RMW cam or anyone else's.
This thread might help.
Old May 2, 2018 | 09:19 AM
wojtek@pagacz.ca
I read that you can do it without but it does seem easier to do it with the tool. If i can't find one locally i'll do it without. Tool:
Old May 2, 2018 | 09:26 AM
pnwR53S's Avatar
pnwR53S
I've never done a cam on Mini. But I am sure you can just improvise something to prevent the chain from slipping a link while you have the old one out. Installing the new one is just a matter of mechanical indexing, back to the same location as the old one you removed. Most use a bungie cord of sort.
Old May 2, 2018 | 10:41 AM
Thinker2112
Don't forget to make the dent in the spark plug tube as the RMW cam will rub on one of them making a bit a hole... which is bad... from what I understand.
Still waiting on that 6er of beer... just kidding. Though with the weather so nice today, may have to pick a 22oz and enjoy on my deck.
Old May 2, 2018 | 10:52 AM
pnwR53S's Avatar
pnwR53S
I think you only need to make the dent if warranted. I will wait until the cam is in and torqued to spec and then check for interference or close to. You never know with aftermarket parts.
Old May 3, 2018 | 08:23 AM
wojtek@pagacz.ca
I know about checking the clearance between the spark plug tubes and cam. However i am little confused about how that is done without pulling them. Can I just dent them with a cold chisel or punch without dissloging or bending them?
sharmadaven
Jan 31, 2018 07:35 AM
LFOXX3
Jul 16, 2015 01:50 PM
ronnie948
Factory JCW Talk (2009+)
Dec 3, 2008 03:43 PM
turnkey
Jun 30, 2007 09:27 AM
IsItElectric?
Mar 2, 2006 04:15 AM
