R50/53 coil over removal
Old Mar 22, 2018 | 08:42 AM
bneer's Avatar
bneer
coil over removal
I'm going to remove the rear coil overs to tighten the top nut. Having cold weather rattle. I've installed trailing arm bushings, new lower control arms and H&R sway bar doesn't have that many miles on it. Will these coil overs drop out and back in without spring compression. I thought I read where they would by putting the jack under trailing arm and raising it slightly. wanted to double check before I start in.
Old Mar 22, 2018 | 09:13 AM
Zsm's Avatar
Zsm
Yep, you'll need a jack to lift the rear hub to line up the bolt hole of the shock. Just keep an eye on the ABS wires so that the coilovers don't snag on them.
Pelican's got a DIY article:
MINI Cooper Rear Shock and Spring Replacement
Old Mar 22, 2018 | 10:06 AM
gumbedamit's Avatar
gumbedamit
When I did my rears, I lifted both sides of the car, didn't need to put a jack under the trailing arm to lift it into place. I went to do the same thing you are about to do and lifted just one side, had a hard time getting it lined up to put the bolt through. Hope that helps.
Old Mar 22, 2018 | 10:27 AM
RogueMini's Avatar
RogueMini
yes, the shock/spring assy will come out without having to use spring compressors. as zsm says: be careful of the wires, they get caught on each coil when you lower it out. you can tighten the top nut and put the unit back in without messing with the spring.
Old Mar 22, 2018 | 11:23 AM
bneer's Avatar
bneer
coil over removal
Does it matter if tires and wheels are left on the car?
Old Mar 22, 2018 | 11:34 AM
gumbedamit's Avatar
gumbedamit
It's easier, but you can leave them on.
Old Mar 22, 2018 | 03:41 PM
Whine not Walnuts's Avatar
Whine not Walnuts
By jacking up both side the pressure on the swaybar is equalized. If you only jack up on side then the opposite side that is low is putting a lot of pressure on the jacked up side.
Old Mar 22, 2018 | 04:45 PM
bneer's Avatar
bneer
Coil over removal
I got the coil over off expecting to find the nut loose on top. But it was tight. The damper adjustment on top turned easily and so did serrated retainer below it. Assumed the metal retainer below adjustment should back up against it but I don’t know. And if these are loose would it cause the rattle?
Old Mar 22, 2018 | 05:13 PM
Zsm's Avatar
Zsm
The bottom ring is the lock. It supposed to be tight up against the ring right above it to keep the spring in position on the strut body.
Old Mar 22, 2018 | 05:18 PM
bneer's Avatar
bneer
Coil over removal
thanks for the response.
ridinDirty
May 14, 2021 07:15 PM
Longbowjake
Suspension
Jul 21, 2015 06:16 AM
mamiller9
Apr 17, 2010 07:35 AM
Morales
Suspension
Jul 6, 2007 10:55 AM
