R50/53 while coolant tank replaced
Old Mar 15, 2018 | 07:58 PM
yyj3869's Avatar
yyj3869
today, i replaced coolant tank because of leaks. while i was replacing the tank, i noticed that the previous coolant was little thicker than water and color was kinda brown. I've seen this symptom before and i heard that it could be mixing with the oil and it could be head gasket leaks. I've check the oil cap if there is residue on cap but everything looked normal and i even checked the oil dipstick and it was normal as well. I don't know what else i need to check and what am i supposed to do with this.. Coolant flush? Please advise.
Attached Thumbnails while coolant tank replaced-img_5997.jpg   while coolant tank replaced-img_5998.jpg
Old Mar 16, 2018 | 12:36 AM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
Have you notice if there was more of an oil loss than normal ?
If the oil cap and dipstick is showing ok, I'd see if there was anything showing in the radiator by trying to drain a little coolant from the bottom.
Old Mar 16, 2018 | 04:37 AM
Whine not Walnuts's Avatar
Whine not Walnuts
If it walks like a duck, quacks like a duck . . . . .
Chocolate milk is not found in a car unless the coolant has mixed with the oil. Get a business car, put a drop or two of your milk on the card. Let lay flat for a couple of hours. If there oil in the mix, the oil will move/migrate outward from the center leaving the remaining materials in the middle. A single color stain, most likely no oil, two color stain with a darker center, chance are oil.
Old Mar 16, 2018 | 05:35 AM
My guess is to check the heat exchanger, they can leak oil into the coolant.
https://www.northamericanmotoring.co...il-cooler.html
Old Mar 16, 2018 | 06:33 AM
ItsmeWayne's Avatar
ItsmeWayne
2X ECSTuning
Old Mar 16, 2018 | 08:29 AM
yyj3869's Avatar
yyj3869
I guess i might have to check oil level when i get home today.
Old Mar 16, 2018 | 08:30 AM
yyj3869's Avatar
yyj3869
is it hard to install?
yyj3869's Avatar
yyj3869
Originally Posted by ItsmeWayne
2X ECSTuning
would it be hard to install DIY?
Old Mar 16, 2018 | 09:10 AM
A little bit of work but you can access from the one side.
https://www.northamericanmotoring.co...n-coolant.html
https://www.northamericanmotoring.co...in-an-r53.html
Old Mar 16, 2018 | 09:23 AM
ItsmeWayne's Avatar
ItsmeWayne
Except that it is in a bit of a difficult place, you can DIY.
Make sure to read this post:
Emincee1012
Jul 12, 2017 12:10 PM
AbsoluteAuto
May 22, 2014 05:08 PM
Mark97xp
11
Dec 4, 2013 03:06 PM
Gusting
Sep 11, 2013 12:50 PM
bunce
Aug 15, 2008 07:59 PM
