R50/53 03 r53 driving light question
Old Feb 17, 2016 | 07:49 PM
Aethir's Avatar
Aethir
Hey all, when you turn the light switch on the steering column to the first selection (second one is the headlights) which lights turn on? Cause mine does absolutely nothing
Old Feb 17, 2016 | 07:56 PM
joshua stowe's Avatar
joshua stowe
Mine keeps my drl on but turns on rear lights and allows fogs to be turned on
Old Feb 17, 2016 | 07:57 PM
Aethir's Avatar
Aethir
What is the DRLs? Cause mine won't let my fogs turn on and the dash doesn't light up. I forgot to check the rear lights
Old Feb 17, 2016 | 08:07 PM
joshua stowe
Driving lights.
Old Feb 17, 2016 | 08:09 PM
Aethir's Avatar
Aethir
Driving lights.
I know that. I'm trying to figure out WHICH lights are the DRLs
Old Feb 17, 2016 | 09:15 PM
Eric_Rowland's Avatar
Eric_Rowland
DRL - Daytime Running Lights - low powered headlamps
Driving Lights - mounted in front grill, turn on only when high beams are on and DL switch is activated (little green light on switch will light up)
First detent is parking lights - front yellow lights in bumper, and rear red markers in tail lights
Old Feb 17, 2016 | 09:56 PM
GrabPatch's Avatar
GrabPatch
IIRC: From top to bottom - headlights, driving lights(DRL)/turn signal light, fog lights
Old Feb 18, 2016 | 04:33 AM
otto_my_way's Avatar
otto_my_way
Does the 03 MCS even have DRLs? If so, how are they activated? Not that I really need to know, I think that if you want your lights on you should turn them on, not have the car decide when they should be on... Just my $0.02 worth.
Old Feb 18, 2016 | 05:09 AM
sevin's Avatar
sevin
The 2nd switch turns on parking lights, which are the side indicators and low brake lights IIRC. The DRLs are actually the high-beam headlights running on low voltage.
Old Feb 18, 2016 | 10:51 AM
+1 the factory DRL are in the headlights on the high beam.
They will have to be activated by the dealership to turn them on or you can do it with some third party programming software coders.
List of other options
https://www.northamericanmotoring.co...ng-lights.html
Old Feb 18, 2016 | 11:48 AM
sevin's Avatar
sevin
You taught me that.
Old Feb 18, 2016 | 12:05 PM
I know,
Yep. Good to spread the knowledge and help other owners out like myself.
Old May 14, 2017 | 10:04 PM
BlackLabel's Avatar
BlackLabel
I can't seem to my driving lights to turn on. I just recently bought an 08 MC Clubman and are still learning how to work it.
My little green button doesn't light up.
Old May 15, 2017 | 08:32 AM
Your in the Gen 1 MINI land. On Gen 2 ( MINI Clubman R55)
https://www.northamericanmotoring.co...t-working.html
The rally lights *aka additional driving lights have a button on the dash on the left hand side.
They only come on with the high beam by the program.
Old May 15, 2017 | 09:56 AM
BlackLabel's Avatar
BlackLabel
I don't know how to determine which Gen my mini is.
and yes, I have the "Rally Lights" as well as that button on the left of my dash.
Old May 15, 2017 | 09:59 AM
Your MINI is a Gen 2 R55 MINI Clubman:
That link above should help you and this link you will find the R55 section: https://www.northamericanmotoring.co...talk-2008-168/
Post up your question there and I can help you out.
Rock944t
Apr 4, 2020 10:22 AM
goneFXcrazy
27
Mar 8, 2017 05:22 PM
jaep1911
Feb 24, 2016 02:20 PM
sam355
Feb 17, 2016 09:52 AM
tlmease
Feb 14, 2016 01:22 PM
