R50/53 Front marker light replacement?
Old 12-24-2015, 07:18 PM
sevin's Avatar
sevin
sevin is offline
I have an 08/2003 R53 and I now have a set of Ziza LED front marker bulbs. I'm looking to replace the standard yellow bulbs with these but I can't quite figure out how to remove the old ones. I figure they're #5 in this diagram...
... but I can't figure out how to remove the socket. My Bentley manual does not seem to include the marker bulbs, only the turn signal bulbs, and those instructions are not very clear.
Old 12-28-2015, 08:55 AM
ECSTuning is online now
Received 1,973 Likes on 1,772 Posts
Some help here:
https://www.northamericanmotoring.co...leds-sale.html
Twist the base unit out ( Black base ) quarter turn #3 , Then take the stock wedge bulb out #5 . Then replace with the Ziza bulb. If they dont light up at first test, pull out and swap 180 degrees as they are polarity sensitive.
Old 12-28-2015, 09:23 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
We go over the replacement of the side marker bulb, side turn indicators, etc in our Replacing Lenses and Bulbs DIY.
888.280.7799 | 6am - 5pm PST
Old 12-29-2015, 04:31 PM
sevin's Avatar
sevin
sevin is offline
Pelican, I'm talking about the front market bulbs, the DRLs.
ECS, that's what I've been trying to do, it just seems like the black base won't twist out. I have removed the wiring harness, but the #3 black base refuses to turn.
Old 12-30-2015, 06:10 AM
Been there , done that.
Its stuck a little , they can get dirt on that and be pretty tight to get out. Turn to the left , first grab it with your thumb and index finger. Some silicone spray between the socket and the light fixture gap will help. Then twist out which pushing in a hair.
Old 12-30-2015, 11:59 AM
sevin's Avatar
sevin
sevin is offline
Okay, finally got the thing unfastened and replaced. Thanks for the help! Comparison pics tomorrow in my build thread.
Old 12-30-2015, 12:08 PM
Great, yea, it takes a bit of force on any of those plug types if they have never been turned.
Old 01-02-2016, 09:06 PM
Andrew Riley's Avatar
Andrew Riley
Andrew Riley is offline
WD-40 works wonders... Especially on that "years old" brittle plastic.
Old 01-04-2016, 08:59 AM
+1 that also will work, good point, just make sure not to get it on the bulbs itself.
CountryS
R60 :: Countryman Talk (2010-2015)
11-20-2015 02:59 PM
Rennfahrer555
11-18-2015 03:31 PM
flredmini
11-17-2015 04:08 PM
WhinyR53
11-09-2015 09:13 AM
AvianMan
11-03-2015 11:00 AM
Quick Reply: R50/53 Front marker light replacement?
