R50/53 I Install Big Intercooler N' My R53.
Old Jun 12, 2014 | 12:48 PM
elchilo4ever's Avatar
elchilo4ever
The Question Is?
Before Install A Big Intercooler I Was Boosting 14.5 to 15 Lbs.
After The Install.
12 to 13Lbs.
My Question Is I Have The Same Power
With Less Lbs Because Is At Big Intercooler?
Or I'm Loosing power?
Click image for larger version
Old Jun 12, 2014 | 12:55 PM
Stoker's Avatar
Stoker
Originally Posted by elchilo4ever
The Question Is?
After The Install.
12 to 13Lbs.
Did you make sure the boots are tight? If they were a bit worn.. or cracked, you may have inadvertently caused a leak..
Old Jun 12, 2014 | 12:56 PM
thirdlobe's Avatar
thirdlobe
When you install a larger intercooler you will be filling up a larger area of mass which will make the current volume of air hold less pressure.
Larger intercooler = less PSI
Old Jun 12, 2014 | 12:57 PM
astroBlackMetallic_Mini's Avatar
is that one of those ebay ones?
Old Jun 13, 2014 | 05:44 AM
GreekDrifter91's Avatar
GreekDrifter91
kinda looks like the godspeed one....
anyway like said before. higher flow means less psi.
You cant have high flow and high psi with a given input. It is either one or the other. (high flow low psi, or high psi low flow)
Old Jun 13, 2014 | 06:25 AM
elchilo4ever
Thanks Guy's For All You Help!
Sorry For The Late Response.
N ' Yes Is The Goodspeed Intercooler.
Greek But I'm Loosing Power Because Pushing Less Lbs?
Or is The Same Power W/ Less Lbs?
N' I Put The Intercooler Because They Said The Supercharged Is Gonna Be More Cold N' The Power Was Gonna Be For Longer N' Also They Told Me I Was Gonna Feel I Little More Power........
But I Didn't Know I Was Gonna Loose Lbs?
But Like I Said If I'm Pushing The Same Power W/ Less Lbs? I'm Ok!
That's What I Know.
Anyway I'm Not Racing.
I Just Want To Have The Power if Sane Day I Need.
N' Thanks Again!
Old Jun 13, 2014 | 06:34 AM
cerenkov's Avatar
cerenkov
Larger intercoolers have more piping. More piping means more resistance. More resistance means larger pressure drop across the intercooler. This is the pressure drop that you are seeing.
EDIT: less pressure MAY MEAN less power. The sign of a good intercooler is a small pressure drop.
Old Jun 13, 2014 | 07:04 AM
GreekDrifter91
you are making the same power. with less lbs.
and no is not less pressure becasue of more piping. it less becasue there is more flow. the only thing that will change with "more piping" is the time it takes to pressurise all that tubing. thats why top mounts are very good for quick boosting in both turbo and SC applications. in Front mount applications there is a lag from the time the TB opens the turbo/Sc spools and pressureises the piping.
as for the pressure drop think of a garden hose with the tap all the way open. there is a lot of water coming out with not that much pressure, put your thumb in the way and you can make a stream go flying 50ft. but the flow is now down.
the stock ic is small (your thumb on the hose) the biger IC is now with your thumb half way covering the hose.
Makes sense yet?
Old Jun 13, 2014 | 07:09 AM
GreekDrifter91
Also generaly with a bigger IC you can run higher PSI becasue it will cool the air down better than a smaller IC intake air temps wont be as high.
lets say IAT stock is 150*f at 10 psi, with a bigger IC it will be 150*f at 15 psi if you were to up the boost. (numbers are not real just throughing them out there)
Old Jun 13, 2014 | 07:20 AM
elchilo4ever
Thanks Greek That Make More Sense.
Because I Just Looking For Extra Power Or To Have The Same Power W/ This Intercooler N'That Way The IC Is Gonna Be More Cold!
Because I Was Thinking If I'm Loosing Power I Just Put The Stock IC.
Like I Said I'm Not Racing Or anything Like That.
Just To Have Fune N'Feel The Power Same Time.
Old Jun 13, 2014 | 09:48 AM
cerenkov's Avatar
cerenkov
Makes sense yet?
It all depends on what "bigger" intercooler means. Are the flow channels larger, smaller or the same size in diameter? Are the flow channels longer in over length? The longer the path that the air flows through will increase the pressure drop.
Depending on how the intercooler is designed your garden hose analogy may not be appropriate. Are the inlet and outlet of the intercooler still the same size?
A well designed intercooler will minimize the flow restrictions (pressure drop).
Old Jun 13, 2014 | 10:02 AM
elchilo4ever
Cerenkov.
Yes Is The Same Size The Out N' Inn For The Intercooler.
They Fit Right N' The Same Way
The Stock Intercooler.
N' Yes The Intercooler Is Larger
Then The Stock.
Old Jun 13, 2014 | 10:23 AM
cerenkov's Avatar
cerenkov
Cerenkov.
Then The Stock.
Cooler air can also lead to lower pressures. There are multiple variables at play here. A before and after dyno is the best way to determine if you lost or gained power from any mod.
Old Jun 13, 2014 | 10:42 AM
elchilo4ever
Ok Thanks! Cerenkov
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
tr3y003
Oct 22, 2015 10:48 AM
squawSkiBum
Oct 2, 2015 09:21 AM
