R50/53 My r53s progress thus far
Old Aug 21, 2016 | 10:25 AM
  #401
bavmotors's Avatar
bavmotors
I've put about a 1,000 miles on my factory LSD, quite an improvement even just aggressively street driving. I do notice the tires slipping easier off a hard start.
Old Aug 21, 2016 | 06:05 PM
  #402
bavmotors's Avatar
bavmotors
Summer photo, hr springs with bilstiens coming soon.
Old Sep 5, 2016 | 05:10 AM
  #403
bavmotors's Avatar
bavmotors
Swapped out my torn strut mounts, used monroes I bought from a member for $20. I've read nothing but bad reviews on them so I'll see how long they last.
Old Oct 19, 2016 | 07:28 PM
  #404
bavmotors's Avatar
bavmotors
Well it's been a while since I've made any progress as life has just been hectic. So I've got a new set of sumitimo tires after reading a lot of good reviews on them. Cost was only $286 shipped to my door, hard to beat that. Shocks and springs are next to be replaced, the fronts are totally shot.
Old Oct 20, 2016 | 11:44 AM
  #405
Ol' Blue's Avatar
Ol' Blue
Good to see some progress. New tires are always fun. What spring/shock combo are you going with?
Old Nov 5, 2016 | 12:12 PM
  #406
bavmotors's Avatar
bavmotors
Slapped my summer wheels on temporarily while I get my tires mounted to my feathers. Tire profile isn't correct but otherwise should look decent when lowered. Going with TSW springs for a moderate drop and undecided on the shocks yet.
Old Nov 5, 2016 | 12:13 PM
  #407
bavmotors's Avatar
bavmotors
Quick driveway shot
Old Nov 5, 2016 | 06:00 PM
  #408
Ol' Blue's Avatar
Ol' Blue
TSWs with Koni yellows have my vote. They ride smooth and handles great.
Old Jan 7, 2017 | 09:57 PM
  #409
bavmotors's Avatar
bavmotors
Well my stock header broke at the cat, sounds like crap and has no power. Time for a Megan header and an angled o2 fitting. Hopeful that keeps the light from coming on. If not I'll be getting a cat welded in, stay tuned for sound videos.
Old Jan 8, 2017 | 10:54 AM
  #410
dw1's Avatar
dw1
@bavmotors: You should be fine, I had same pre cat breakage and replaced with an OBX header, no light + better performance so results were good. Good luck.
The pre cat seems to crack at a weld seam of the cone to the can, so it could be repaired if desired. I thought the header option would provide better results.
Old Jan 8, 2017 | 12:46 PM
  #411
bavmotors's Avatar
bavmotors
Yea I'll get it welded as a back up but I'm ready for a header anyways, I'd like a little more torque and sound.
Old Mar 14, 2017 | 04:33 PM
  #412
bavmotors's Avatar
bavmotors
Got a few parts in today, time to swap some parts out this weekend.
-front bilstein shocks
-Kyb strut mounts
- used oem header to replace my cracked header along with new gaskets
- all rear control arms that i received from a local member (in much better shape than mine)
Old Mar 25, 2017 | 09:55 PM
  #413
bavmotors's Avatar
bavmotors
So after a long day today, got the new bilsteins and mounts on, along with some whiteline end links, a rear wheel bearing and the replacement header. She's quiet and smooth as silk.
Old Mar 27, 2017 | 09:08 AM
  #414
bavmotors's Avatar
bavmotors
Every front suspension bushing is new now. Handling is excellent
Old Apr 9, 2017 | 06:25 PM
  #415
bavmotors's Avatar
bavmotors
ended up keeping the stock springs for now, she rides nicely but the fender gap is too much to stay this way. heres some spring weather shots
Old Apr 9, 2017 | 06:27 PM
  #416
bavmotors's Avatar
bavmotors
Clean and mean
Attached Thumbnails My r53s progress thus far-photo887.jpg   My r53s progress thus far-photo636.jpg   My r53s progress thus far-photo39.jpg   My r53s progress thus far-photo334.jpg
Old Apr 10, 2017 | 07:20 PM
  #417
bavmotors's Avatar
bavmotors
Replaced my positive crankcase valve, hoping my mpg gets better.
Old Apr 15, 2017 | 11:05 AM
  #418
bavmotors's Avatar
bavmotors
Mpgs have gone up since the pcv replacement!
My lower steering column took a sh*t, ordered a replacement, steering binds up and feels unsafe. Sprayed it with some lube like advised by others on the forum, it helped a little but it still needed a replacement. Hopefully the swap out won't be much of a pain.
Old Apr 18, 2017 | 07:59 AM
  #419
The spray on the double joint buys some time. Its not too bad on the replacement. Take the front wheel off and go in under and at the side. A lift helps. Its will feel so much smoother when it's replaced, and tight.
Old Apr 19, 2017 | 09:09 AM
  #420
bavmotors's Avatar
bavmotors
Yea I'm hoping it's an easy swap, I've replaced enough on this car. I need a break from the constant part failures.
Old Apr 22, 2017 | 12:38 PM
  #421
bavmotors's Avatar
bavmotors
Wow that steering shaft u joint was seized up! I can hold the weight of the longer end up by the joint without it pivoting. Glad it wasn't the power steering pump.
Old Apr 24, 2017 | 08:55 AM
  #422
Must have been bad from the salt and winter corrosion. I have seen them pretty nasty.
Old Apr 24, 2017 | 04:39 PM
  #423
bavmotors's Avatar
bavmotors
Must be, I'd strongly recommend to others to periodically grease the joint. It's pretty easy to access behind the wheel well cover. Mine went from slightly tighter, to very hard to steer within days.
rtk90
Aug 29, 2019 09:08 AM
Terry @ BMS
Dec 7, 2015 09:09 AM
Gremothra
Sep 9, 2015 08:42 PM
Filmy
Sep 7, 2015 08:27 PM
