R50/53 My r53s progress thus far
Old Oct 3, 2015 | 10:58 AM
  #226
Drumsound's Avatar
Drumsound
Originally Posted by bavmotors
they were given to me by a friend, I believe they are just eBays. They are plug and play, however they are for 02-04 only because they have no reverse light, which i didn't know at the time of install so I've gotta swap them out.
Too bad, mine is an '06
Old Oct 10, 2015 | 03:57 PM
  #227
bavmotors's Avatar
bavmotors
So a couple months back my factory dipstick was starting to break so i ordered a new one and was able to swap it out before it broke. Two weeks later the new one broke inside the tube, ughh...son of a. So now its going to the dealer next Friday and getting the oil pan dropped. Since it leaks anyway i guess its a good thing. So now it will be getting a new oil pan gasket, crank position sensor, dip stick tube o-ring and a Cravenspeed dipstick. After that the new clutch will finally be going in.
Old Oct 11, 2015 | 06:13 PM
  #228
bavmotors's Avatar
bavmotors
Cleaned up my exhaust tips a bit, then snagged a couple shots of my newly acquired Alta intercooler diverter.
Attached Thumbnails My r53s progress thus far-image-124736653.jpg   My r53s progress thus far-image-2866536184.jpg   My r53s progress thus far-image-2742466292.jpg
Old Oct 12, 2015 | 10:31 AM
  #229
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
that engine bay is so clean 0.0
Old Oct 14, 2015 | 04:50 PM
  #230
bavmotors's Avatar
bavmotors
Swapped out my Megan intake for an Alta, I've wanted an Alta for awhile but I kinda liked my Megan better. The Alta makes too many air noises imo. My venair hose didn't fit worth squat over the Alta. Gonna need a bigger silicone hose for it to fit properly. Megan was so much easier to install and is up for sale.
Attached Thumbnails My r53s progress thus far-image-3813357018.jpg   My r53s progress thus far-image-221343985.jpg
Old Oct 14, 2015 | 05:42 PM
  #231
Spencer Roper's Avatar
Spencer Roper
Sorry to hear about the ALTA troubles but it does look smashing.
I was considering purchasing this unit when I started liking at minis but since I ended up with a JCW it seemed pointless. Now that I'm looking at another R53 non JCW I have a couple questions.
Other than the noise factor and install any other concerns with the unit?
Do you know if the stock hose had the same issues?
Is there any real advantage to this particular unit that made you want it so much?
Old Oct 14, 2015 | 05:56 PM
  #232
bavmotors's Avatar
bavmotors
Jcw is a great intake from what I've heard, I wanted the Alta because I like supercharger whine and I knew it was the loudest. Not much louder than my Megan setup tbh, but it does look nice. I believe the stock tube fits it but I could be wrong.
Old Oct 15, 2015 | 07:24 AM
  #233
Spencer Roper
I like my JCW intake on my JCW because I didn't have to pay for it separately I just got the whole package. The New R53 can benefit greatly from one of these lesser expensive units and I have no intention of buying another JCW intake haha.
Looks like I'll give the alta a shot. Since I don't like using silicone intake tubing I'm hoping that this install might be a bit easier. I guess since Alta and Madness are down the street from me I'll go in and have a look see.
Old Oct 15, 2015 | 04:04 PM
  #234
bavmotors's Avatar
bavmotors
Bought a cravenspeed dipstick, wow it's a lot more flexible than I expected. It has no stiffness whatsoever, it's just a floppy spring. I guess as long as it works.
Old Oct 16, 2015 | 11:18 AM
  #235
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Looks good. What did you use to clean your tips?
888.280.7799 | 6am - 5pm PST
Old Oct 16, 2015 | 11:30 AM
  #236
CravenSpeed's Avatar
CravenSpeed
Vendor
You will be pleasantly surprised, I think.
Old Oct 16, 2015 | 11:44 AM
  #237
bavmotors's Avatar
bavmotors
hey pelican, waiting on some parts from you. Thanks for the good prices. I used a wheel cleaner actually, seems to work ok.
  #238
bavmotors's Avatar
bavmotors
hey as long as it doesn't break and cost me another oil pan drop I'm happy
Old Oct 16, 2015 | 12:00 PM
  #239
PelicanParts.com
Vendor
Fabulous to hear and glad to be able to help with your progress. If you need anything don't hesitate to contact me. Next time, for the tips if you want to try something else out, I use this stuff called Never Dull. It really makes the tips shine like crazy! The material is basically like a giant cotton ball. You break it off into pieces and scrub the tip all around with it and I then take a paper towel to wipe the residue off.
Old Oct 16, 2015 | 12:17 PM
  #240
bavmotors's Avatar
bavmotors
Excellent I'll have to track some down, gotta keep the exhaust shinning!
Old Oct 19, 2015 | 02:58 PM
  #241
bavmotors's Avatar
bavmotors
Paired my Alta intake with silicone hose, the venair wouldn't even fit on the Alta intake without twisting the hose.
Last edited by bavmotors; Oct 19, 2015 at 05:03 PM. Reason: autocorrect spelling errors
Old Oct 21, 2015 | 09:40 AM
  #242
USNAE2's Avatar
USNAE2
Veteran: Navy
Used Neverdull all the time in the Navy! Works great on most metals.
Old Oct 22, 2015 | 01:01 PM
  #243
bavmotors's Avatar
bavmotors
Added some under the hood bling
Old Oct 24, 2015 | 10:58 AM
  #244
bavmotors's Avatar
bavmotors
Got my crank sensor replaced, oil pan gasket and installed my craven speed dipstick. Also had my airbag seat sensor replaced under recall. Cars getting closer to fully maintained.
Old Oct 24, 2015 | 12:35 PM
  #245
bavmotors's Avatar
bavmotors
Took some shots of her today since it was clean...
Attached Thumbnails My r53s progress thus far-image-3843164058.jpg   My r53s progress thus far-image-467283274.jpg   My r53s progress thus far-image-2122026468.jpg   My r53s progress thus far-image-1297860258.jpg   My r53s progress thus far-image-1824550962.jpg
Old Oct 26, 2015 | 09:12 AM
  #246
CRC's Avatar
CRC
Never-Dull: $5.47 @ WalMart.
Old Oct 26, 2015 | 03:28 PM
  #247
bavmotors's Avatar
bavmotors
thank you! I was looking on Amazon didn't expect Walmart to carry it.
Edit: just ordered some.
Old Nov 4, 2015 | 05:07 PM
  #248
bavmotors's Avatar
bavmotors
Gave the tips a quick polish again thanks to Pelican Parts
Attached Thumbnails My r53s progress thus far-image-2487122347.jpg   My r53s progress thus far-image-3197707065.jpg
Old Nov 5, 2015 | 06:46 AM
  #249
Drumsound's Avatar
Drumsound
Just the tip?
Old Nov 5, 2015 | 09:20 AM
  #250
bavmotors's Avatar
bavmotors
Originally Posted by Drumsound
Just the tip?
all ll i have is the tip.
