R50/53 Check your gas tank straps
I was poking around the bottom of my car today and found the right side of the gas tank strap has rusted and snapped. The paint looks ok and first glance, but peels off in sheets revealing more rust. I already have a new strap on order and sprayed all the bolts with Kroil. It’s pretty weird nothing else under the car is rusty.
There is a set for the pre 7/2004 Gen 1 MINIs and the post 7/2004 . Must easier to change out on a lift and they hold it up with a transmission jack. New straps comes with the screws which are held with a little circlip so its easier to install.
Fuel Tank Tension Strap R50 / R53 -7/2004 Part #16111500998
http://www.ecstuning.com/Search/SiteSearch/16111500998/
There are also little expansion rivets that you will need.
#3 in the diagram.
http://www.ecstuning.com/Search/SiteSearch/16136753087/ES2677304/
7/2004+ R50 R52 R53 They went to the two strap design.
Fuel Tank Tension Strap - Priced Each x 2 Part # 16136765008
http://www.ecstuning.com/Search/SiteSearch/16136765008/
#6 Expanding rivets
Thanks and I hope that helps.
#3 in the diagram.
#6 Expanding rivets
I tackled the project today. I’m happy to report everything went better than expected. The total time burden was 45 minutes.
A few items of note for the early cars:
1. The exhaust has to come off.
2. The heat shield has to come off.
3. The e-brake cables have to be removed off the calipers.
4. The positive cable has to be removed from the clips.
I can now see a reason why this part was redesigned. It looks like the later cars tank straps are a lot easier to replace.
This is a picture of what the old strap looked like after I was done. The only thing holding it together was rust and paint.
A quick solution for Gen1 fuel tank strap
[QUOTE=Nicefeet;3912361]I tackled the project today. I’m happy to report everything went better than expected. The total time burden was 45 minutes.
[What if I simply remove the cross section and use the side straps like the R56 model?]
Wow that looks great!!
dchang0
Aug 10, 2015 03:37 PM
bc219
Aug 10, 2015 11:22 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
