R50/53 Pre Purchase Question
Old Dec 8, 2013 | 08:19 AM
Sultan's Avatar
Sultan
I have done enough research to not ask if they are reliable.
I am looking at getting a 2005-2006 S and I am wondering how much the 100K service will be through the dealer. I most likely won't go to the dealer yet I would like to get an idea of what it would cost if I get car that is close to 100K.
Also is the 2007 worth a little bit more spend?
Any other thoughts or input is more than welcomed.
Thank you!
Old Dec 8, 2013 | 08:34 AM
Mib4840's Avatar
Mib4840
Your best bet is to call shops around your area. I know there is a difference in price where I am depending on what part of town the shop is in. Check out other shops other than just dealerships. Find your local MINI club and ask some of them who they use. There is a club finder in the Main Menu. That is your best bet. I have used a local shop in my area and they have been about half the price of the dealership and the work has been great so far. Good luck and hope you find what you are looking for.
Old Dec 8, 2013 | 08:40 AM
Sultan's Avatar
Sultan
MIB4840 I see you have a 2004. In your opinion how much "better" are the 2005 & 2006?
Thx!
Old Dec 8, 2013 | 12:02 PM
Mib4840's Avatar
Mib4840
I would say that the later the model year the better off you are due to the updates. I love my 04 R53 and have had very good luck with it. If you find a good 06 I would jump on that.
Old Dec 8, 2013 | 12:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Find an independent shop to do the maint. the dealer has high over head, only uses MINI brand parts, and therefore cost more.
for 100k I'd suggest doing your own service including:
Oil and filter change
Engine Air filter
A/C filter
Drive belt
plugs and wires
Fuel filter
Other repairs as a need only basis.
If you're trying to decide which MINI year, drive them all and decide for yourself. Everyone has their own loves and hates for each model. You're the only one going to drive it so choose what YOU like.
Old Dec 8, 2013 | 01:13 PM
ZippyNH's Avatar
ZippyNH
No such thing as a 100k service in a mini...
A "inspection" or service (oil change plus extra items) is done every 30,000 miles, with a small one, inspection 1, followed by a bigger one, inspection 2, 30,000 miles later...the inspection1 30,000 later etc...
Waymotorworks suggestion is good imo if the prior history is unknown.
Old Dec 10, 2013 | 04:27 PM
Sultan's Avatar
Sultan
Thank you all for your time and thoughts. I am going to go check this car linked below. It is an 2004 instead of a 2005 which is what I prefer due to the research I've done.
Beyond checking for typical used car stuff do you have any thoughts on this car?
I know it is priced above retail.
http://www.chaplins.com/used-cars/de..._MINI~Model_/9
Old Dec 10, 2013 | 04:52 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
FWIW, IMHO, a 2005 or 2006 MCS is preferred just for its better gear ratios (better driveability). Some even came with LSD and Chrono Gauge pkg. Unless you know that the vehicle in question had these done recently, I'd add to the maintenance list while its up on all fours: a change of coolant and tranny lube.
Old Dec 10, 2013 | 05:05 PM
Sultan's Avatar
Sultan
Mr. Trackrat,
Thanks for the input!
Old Dec 11, 2013 | 08:41 AM
Super Coop's Avatar
Super Coop
I've had an '05, '06, and now an '04. Bought the '04 in September due to very low (38K) miles for about the same money as the one you linked to. '05 had a mild "facelift" and had 5 more HP and better gearing. Most problems were sorted out by '04 but there were a few other minor improvements in '05. Big plus for '06 was factory option JCW w/ LSD and biggerr brakes. Motoringfiles has a nice buyers guide for R53 cars.
Old Dec 11, 2013 | 08:57 AM
buzzsaw's Avatar
buzzsaw
Touch base with www.psmini.org and they will help you. Our site has a large number of Indie shops listed in the Seattle area. The folks from psmini will have their recommendations. Good luck.
Old Dec 11, 2013 | 11:38 AM
Sultan's Avatar
Sultan
Thank you Supercoop. Your perspective is what I was looking for.
Buzzsaw I have tried to email PSMINI via the admin email as it is the only way I could find to reach out without applying for membership. Do you have any contact info you can share?
Old Dec 11, 2013 | 01:07 PM
Sultan's Avatar
Sultan
Supercoop thanks for the input. That is exactly what I needed to know.
buzzsaw I have reached out to PSMINI via the admin email link as it was the only way I could find to contact them without applying for membership. If you have contact info you can share then that would be great!
Thank you all.
Old Dec 11, 2013 | 04:21 PM
buzzsaw's Avatar
buzzsaw
[QUOTE=Sultan;3853198]Supercoop thanks for the input. That is exactly what I needed to know.
Thank you all.[/QUOTE
www.zahntech.com works with PSMINI members and was recommended.
Old Dec 11, 2013 | 04:22 PM
Sultan's Avatar
Sultan
Thanks. I will stop and talk to them.
Old Dec 12, 2013 | 09:19 PM
Sultan's Avatar
Sultan
So the 2004 I looked at was very rough. It even had a 4" section of bubbling rust on the hatchback and they couldn't get it to start......
W0TM8
Dec 19, 2019 07:50 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
smarsha11
Aug 24, 2015 06:03 AM
Mini'mon
Aug 16, 2015 04:15 PM
papawhiskey
Aug 10, 2015 09:31 PM
