R50/53 Stock or not?
Old Oct 4, 2013 | 03:36 AM
Husam Hammadi's Avatar
Husam Hammadi
Stock or not?
Hello NAM, i've just bought a 03 MCS last week and i wonder if my car is stock..
It has to what looks like stock exhaust, intake is stock yet i can clearly hear the supercharger whine above 3000 and it is loud!
Also, my exhaust pops when letting the gas out at 3000~ rpms, but i know that only 2005+ minis do that?
Does that mean it might have a pulley installed?
I tried a 0-60 test yesterday and got 7.9 twice, could go down to 7.5~ on a good road maybe, is that ok?
btw it has 106k miles
Old Oct 4, 2013 | 04:50 AM
yetti96's Avatar
yetti96
Picture of the pulley? It might be stock, we need pictures please.
Old Oct 4, 2013 | 12:52 PM
Husam Hammadi
I don't really know where is it/ if it can be seen without removing stuff
Anybody got a picture of where is it located?
Old Oct 4, 2013 | 01:59 PM
ZippyNH's Avatar
ZippyNH
Take pictures of the engine bay...look for the belt....you will see it...
Most aftermarket pulleys are shiny.... Lol..and have a few bolts...
OEM is hot pressed steel...looks very different...
Old Oct 4, 2013 | 02:08 PM
Skwerl's Avatar
Skwerl
Check if both your exhaust ***** are there.
Could be a dirty system too. Popping doesn't sound right. I'm new to mcs but not sure on popping. You could have a bad sensor somewhere. It does sound like you have a pulley. Mine doesn't whine till around 3500 and its not really loud.
Old Oct 4, 2013 | 05:11 PM
Husam Hammadi
Well i just checked it and the huge boxy exhaust thing in the left side has a leak, exactly in the middle of the box
Old Oct 4, 2013 | 11:13 PM
Skwerl's Avatar
Skwerl
Well. I would go to a pick and pull junk yard. Find a mini and pull that part. Cost you an hour and $25
Otherwise maybe you could jb-weld a small plate on it for now. Not the best fix. But would do the job for a couple weeks or so till you find a better fix.
Old Oct 4, 2013 | 11:17 PM
Skwerl's Avatar
Skwerl
Don't jb-weld. I guess the big name auto stores carry exhaust cement. Find some and patch your hole with it. Just dab it on till its covered. Let it harden. Follow the instructions. Bla bla bla. :-)
Old Oct 6, 2013 | 05:24 PM
Husam Hammadi
Will do that once the weather stops raining!
So, why am i getting 7.9 on 0-60?
Anybody know?
I launched it at around 3k rpms, released the clutch quickly but didn't dump it. Could be .3~sec faster if i shifted faster to 2nd but that's it
Also, elevation about 900ft
Edit: My car has no options at all! The only thing i can think of is heated front seats. No sunroof, no cruise control etc
Old Oct 6, 2013 | 10:53 PM
Skwerl's Avatar
Skwerl
7.4 seconds is stock. There are quite a bit of factors. 7.4 is probably ideal to sell the car. 7.9 with a hole in your exhaust, your lack of driver skills vs their professional driver and the wear on your tires, your weight. The slight elevation. The wind or barometric pressure where you are. The dirt in your air filter. The age of your engine and damage from abuse. The spark plugs are dirty and corroded so not firing 100% of the time... On and on.
Old Oct 7, 2013 | 02:28 AM
Husam Hammadi
Well thx for the info, i guessed that too..
I'll keep saving for maintenance hopefully installing a new belt, spark plugs, pulley, tensioner stop and maybe check the guides etc
is that all is should do or is there more preventive maintenance?
thx for your help
Colt45Magnus
Aug 27, 2024 05:03 AM
USA-RET
Nov 9, 2015 07:27 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
