JCW Anyone dyno their stock JCW?
Old Sep 3, 2015 | 09:05 PM
USA-RET's Avatar
USA-RET
Curious if any has dyno tested their stock JCW to get an accurate HP and torque rating?
Most agree that the MCS and particularly the JCW produce better than their stated numbers.
Old Sep 4, 2015 | 06:37 AM
Helix13mini's Avatar
Helix13mini
Chassis dynos are fickle tools. They are excellent at measuring differences in torque output on same-day, same-car tests, but because of calibration variances and settings, getting absolute numbers is difficult. If used correctly, they can show close-to-factory horsepower outputs, but a drive train loss estimation is employed. When we calibrate our MD-250 dyno, we actually use accepted drivetrain loss calculations and then set the dyno parameters to reflect the stated factory output of cars.
Old Sep 4, 2015 | 07:00 AM
Ryephile's Avatar
Ryephile
Eric, Good post as always.
Put a different way, the only careful way to get repeatable numbers is to use the engine in an engine dyno cell where all aspects (coolant, ambient air, etc.) are very tightly controlled. Even then, the accuracy comes down to the calibration, which will always have a tolerance. OEM's and their development partners will have very accurately calibrated engine dyno's, and as a rule most fly-by-night aftermarket shops will barely be able to afford hand-me-down dynos that haven't been calibrated in years. That doesn't mean they won't be accurate, but there's rarely an opportunity to prove it one way or another.
In the aftermarket on an engine with a known BSFC, you can fairly accurately calculate the power based on the amount of fuel being injected vs. Lambda, however OEM ECU's don't simply output injection pulsewidth data over OBDII. That's where standalone ECU's like Megasquirt and AEM start to show their value, but neither of them are applicable for the very advanced F56 powertrain. We can however make inferences based on MAF and Lambda, so there's still hope for datalog-backed dyno figures.
I just passed 1200 miles on my JCW. Now that it's well beyond it's primary break-in, I'm planning on taking my JCW to a local Dynapack in the next few weeks. It's the same dyno I've measured many of my recent cars on, so there will be good comparisons across platforms. Please be patient, you can be sure I'll post the dyno and datalogging when I do it.
Old Sep 4, 2015 | 07:40 AM
USA-RET's Avatar
USA-RET
Thanks, I can't hardly wait to see what the results.
I've read a few threads where JCW kits have been added to MCS cars with Dyno numbers after three or four runs showing HP to be at or near the published JCW HP level.
Assuming those dyno numbers to be factual on an MCS with the JCW kit, (kit only having exhaust and a control module remap not the other extras included in the JCW motor), one would believe the base JCW HP factory numbers are considerately under-rated from the factory. Some manufacturers have been known to be very conservative with published HP ratings.
Again, thanks for the information and the upcoming results.
Old Sep 4, 2015 | 08:26 AM
Ryephile's Avatar
Ryephile
It's somewhat more common recently for OEM's to publish their numbers either strictly SAE J1349 or a seemingly vague conservative figures where the intent is to achieve advertised power even in unusual circumstances [e.g. top of Pikes Peak] to avoid any potential class-action lawsuits of the engine producing less-than-advertised power. The side effect is the engines generally make lots more power anywhere near standard temp and pressure.
Old Sep 4, 2015 | 07:38 PM
mct's Avatar
mct
Ryan I still need to get you my DashCommand data of my Dyno run. Need to figure out how to export it for you. Private message me your email and I will send you what I have.
Old Sep 4, 2015 | 07:40 PM
mct's Avatar
mct
Actually looks like I can export it as csv or lgf file format. Let me know which you want.
Old Nov 8, 2015 | 06:57 PM
mct's Avatar
mct
We had a factory F56 JCW at our dyno day yesterday and it exceeded the published numbers
Details here:
http://www.motoringfun.com/2015/11/0...dyno-day-2015/
Old Nov 8, 2015 | 07:29 PM
Marioalex24's Avatar
Marioalex24
Details here:
So if im reading it right, the F56 MCS with the jcw tuning kit makes more power than the stock F56 JCW? Man this sucks lol
Old Nov 8, 2015 | 07:41 PM
mct's Avatar
mct
Well the factory F56 JCW had more horsepower when compared to the Cooper S with JCW tuning kit, but the NM Engineering power module definitely took the power to a whole other level, eclipsing the factory JCW for sure! I am working on some comparison graphs from the raw data and will be posting them later this week.
NYXF56JCW's Avatar
NYXF56JCW
Its amazing to see how much they underrate the numbers from factory. Nice surprise.
Old Nov 9, 2015 | 03:46 AM
USA-RET's Avatar
USA-RET
Fabulous information mct. Thank very much. A shame no one showed up with an F56 MCS with the MINI installed JCW tuning kit only, just to see if the $2800 they charge is going to give a significant boost in power over the stock numbers for an MCS (which are quite impressive in their own right).
Quite honestly, My MCS auto (in sport mode) with the shift lever moved into the S/M position (but not shifted as a manual) is very quick w/ the more aggressive shift points using that selection. A stock JCW or your car would have to be a real neck snapper.
Old Nov 9, 2015 | 04:00 AM
USA-RET's Avatar
USA-RET
Well, remember the MCS you refer to had the MINI dealer installed JCW kit (exhaust) and then the aftermarket Berger tuning module.
One could extrapolate that that MCS with the better numbers than the stock 2016 JCW wouldn't fare so well with just the MINI installed JCW package ($24-2800 dealer installed).
Unfortunately there was no car tested with just that option installed. I'd imagine if there were, it would fall slightly above a stock MCS' numbers and considerably less than a factory 2016 JCW MCS results.
Would guess an F56 MCS w/ the just Berger module (no JCW dealer installed kit) would closely match the stock 2016 JCW numbers. Which for a $400 outlay is pretty amazing.
Great information.
Old Nov 9, 2015 | 04:30 AM
mct's Avatar
mct
Keep in mind - I ran my F56 S with just the dealer installed JCW tuning kit on that exact same Dyno in August...
http://www.motoringfun.com/2015/08/2...-dyno-results/
Old Nov 9, 2015 | 10:23 AM
USA-RET's Avatar
USA-RET
Yes, forgot about that. Maybe add those results to the latest results. I completely forgot about those early results.
Clark Dyno'd at 231HP and 267Lb Ft torque
vs. 210 256 For a stock F56 MCS Auto
+21 Hp +11 Lb ft torque Gains with the $24-$2800 factory kit. Big cash
Berger Mod is best bang for the buck IMO
Again thanks for sharing all this data with the community. Lets everyone know what we start with and what we can expect with upgrades and mods.
HUGE help
Old Nov 9, 2015 | 11:07 AM
mct's Avatar
mct
I will be posting some comparison graphs this week so you can easily see the differences
Old Nov 9, 2015 | 03:55 PM
mct's Avatar
mct
HUGE help
As you requested
Here are some comparison graphs of the factory F56 JCW and the stock F56 and the F56 with JCW tuning kit...
http://www.motoringfun.com/2015/11/0...cw-tuning-kit/
Old Nov 9, 2015 | 06:09 PM
mct's Avatar
mct
Also - while the regular price on the kit does hit $2800 like you said, our local MINI dealer is doing the JCW kit for $560 off! Not too shabby of a price in my opinion:
http://www.motoringfun.com/2015/11/1...ro-tuning-kit/
Old Nov 9, 2015 | 06:32 PM
NYXF56JCW's Avatar
NYXF56JCW
What exactly is included in the JCW Tuning kit? Just the exhaust?
Old Nov 9, 2015 | 06:34 PM
mct's Avatar
mct
You get the exhaust, JCW Pro software tune, JCW badge for rear of the car, JCW serial number badge for the engine cover. Chrome exhaust tips are the base option with a carbon fiber option available for more $$. If you already have a factory JCW, you don't get the software tune.
Old Nov 9, 2015 | 06:35 PM
NYXF56JCW's Avatar
NYXF56JCW
Ah gotcha. Thanks.
Old Nov 9, 2015 | 06:39 PM
mct's Avatar
mct
Oh yea - I forgot the best part lol. You get a Bluetooth 4.0 remote control for the exhaust that opens the baffle to make it basically a straight pipe exhaust lol
Old Nov 9, 2015 | 07:27 PM
Ryephile's Avatar
Ryephile
Thanks for posting all those dyno charts mct!
W0TM8
Dec 19, 2019 07:50 AM
sabjcw
Aug 14, 2015 07:40 AM
Minibeagle
Aug 13, 2015 10:00 AM
ASRman
Aug 13, 2015 09:33 AM
