R50/53 ? re: radiator replacement
Old Aug 22, 2013 | 04:23 PM
JAB 67's Avatar
JAB 67
Replaced the radiator in my 2004 MCS today. Didn't realize that I will need to replace the foam rubber pieces that surround the radiator. Are they available from the dealer?
Also, how do I drain my engine of all existing coolant before adding the new? Obviously simply removing the lower radiator hose is not enough.
Old Aug 23, 2013 | 03:20 AM
mrbean's Avatar
mrbean
Yes, the dealer will have the foam rubber pieces. Alternatively, you can find the part number for these pieces.
My factory manual says that removing the lower radiator hose is sufficient enough for draining the coolant. You are correct that it won't drain 100% of it but it's apparently good enough.
Old Aug 23, 2013 | 05:15 AM
Here is the foam that goes around the radiator and the part numbers. For the Cooper S. I have seen these deteriorate and fall off over time some people don't even know they are missing them. They are peel and stick.
Diagram:
http://www.realoem.com/bmw/enUS/show...20#17107515479
#2 in the diagram
Upper Foam Seal Part # 17107515479
http://www.ecstuning.com/Search/SiteSearch/17107515479/
Lower Foam Seal Part # 17107515480 Diagram #3
http://www.ecstuning.com/Search/SiteSearch/17107515480/
Old Aug 23, 2013 | 05:59 AM
JAB 67's Avatar
JAB 67
Thanks. However, the side ones do not appear on any diagram; it appears that they are considered an inseparable part of the plastic modular front end (MFE) into which the radiator and fan assembly are mounted; correct?
Old Aug 23, 2013 | 06:06 AM
Thanks Jab,
They side ones I believe stick to the core support, thus on a different diagram. I have them here, thought you just needed the top and bottom. There on another diagram. Here is a shot of the front core support with the bumper removed from the Girls guide to front bumper thread.
https://www.northamericanmotoring.co...t-end-mfe.html
You can see the foam on the side and top, bottom one is hidden in the picture.
Here you go : In the diagram #3
http://www.realoem.com/bmw/enUS/show...64#51717042998
Gasket Front Panel Seal - Right Part # 51717042998
http://www.ecstuning.com/Search/SiteSearch/51717042998/
Gasket Front Panel Seal - Left Part # 51717042997
http://www.ecstuning.com/Search/SiteSearch/51717042997/ES128687/
Old Aug 23, 2013 | 07:11 AM
JAB 67's Avatar
JAB 67
Thanks; they are for the R53, correct? For some reason they didn't show up on my Realoem diagrams.
Old Aug 23, 2013 | 07:18 AM
Your welcome again.
Yea, they are for the R53 they are hidden in other diagrams, kind of hard to find. But I can find them for you.
Old Aug 23, 2013 | 07:21 AM
ZippyNH's Avatar
ZippyNH
Try home depot by the window ac install kits....the foam seems to be the same.
blackie
Jan 18, 2017 09:56 PM
tr3y003
Oct 22, 2015 10:48 AM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
BernieCoop
12
Aug 12, 2015 07:45 AM
