R50/53 Rear Wheel hub replacement
Old May 5, 2013 | 03:07 PM
ryanleeis's Avatar
ryanleeis
I have a 04 MCS .. While pulling off the back wheel.. one of the lug nuts Snapped Flush with the rotor.. to put a long story short.. i tried to drill out the broken piece that was still in the wheel hub.. I cannot seem to get it out.. and am at a loss now as to what to do?
Do I need to replace the wheel hub now?
Old May 5, 2013 | 04:09 PM
AlexQS's Avatar
AlexQS
I bet if you took the hub to the machine shop they may be able to do it,.. Not positive though. Call and see though.
Old May 5, 2013 | 04:14 PM
ryanleeis's Avatar
ryanleeis
is it hard to remove the hub
Old May 5, 2013 | 04:56 PM
AlexQS's Avatar
AlexQS
I was going to suggest that it would be a good time to inspect and repackage the real wheel bearings with fresh grease... However it looks like it may not be built that way. According to this, part #16 is the hub and bearing (as one sealed piece I assume)
You'll definitely need a torque wrench. Don't let the brake caliper hang on its hose, get an old coat hanger and make yourself a hook. But looks to me like you just remove the caliper, the disk, then the hub is right there.
Difficult for me to make suggestions, I've only had my MINI for a month. Remove and replace hub sure looks to be pretty straight forward from here, but I also bet that other things have rusted a bit. I'm guessing there will be a single flush mount screw that locates the brake rotor in the hub. If its a Phillips head, make sure you have the right size screw driver, unlike torx or hex heads, if there's a little play it can be easy to choose the wrong size screw driver, you wouldn't want to round it out.
Attached Thumbnails Rear Wheel hub replacement-image-878733768.jpg   Rear Wheel hub replacement-image-408277975.jpg   Rear Wheel hub replacement-image-2875367851.jpg
Old May 5, 2013 | 06:26 PM
AlexQS's Avatar
AlexQS
edit: repack rear wheel
.... Darn auto spell thing on my phone, LOL
Old May 5, 2013 | 06:42 PM
Danske's Avatar
Danske
I replaced the rear hub on my 2009 looks like the one pictured in AlexQS post. Simple change took about an hour to jack car, remove wheel, remove brake caliper then 4 bolts hold hub on and reassemble. New hub was a couple hundred bucks. If you have an 04 possibly high miles might as well change it. Bearings are sealed no repacking them.
Old May 5, 2013 | 07:37 PM
ryanleeis's Avatar
ryanleeis
thanks for all info ,,,I'm just gonna take it up to my mechanic.. is the wheel safe to drive on with 3 lugs
Old May 5, 2013 | 07:48 PM
AlexQS's Avatar
AlexQS
I would not advise anyone to drive their car with 3 lugs.... But I would take mine a short distance with only 3 lugs if I had to....being sure not to take any corners too hard.
The lip that the wheel rides on is very wide on a MINI. Not sure how to describe it, the wheel is like a sleeve that fits over a cylinder about 1/2 wide on the hub. I think that's what takes the weight of the car through the wheel, not the lugs.
Old May 5, 2013 | 07:50 PM
ryanleeis's Avatar
ryanleeis
thanks.. ya I just need to drive it about 3 km
wkp1219
Nov 13, 2015 07:52 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Minibeagle
Aug 13, 2015 10:00 AM
