R50/53 Speed Calibration Issue, Need Help.
Old Mar 29, 2013 | 01:48 PM
ericmakkar's Avatar
ericmakkar
I went from 195/55/16's to 205/40(5?)/16's and now my speedometer is off(faster) by approx. 6-8 mph. It also seems to be adding mileage quicker because of the smaller tires. Correct me if i'm wrong but I believe I'm gonna need to re-calibrate my speedometer. Is this something I can do on my own, Is there a shop I can take it to around So-Cal or do I have to take it to the stealership? As always, any help would be greatly appreciate it.
Eric
Old Mar 29, 2013 | 04:21 PM
uromini's Avatar
uromini
My r53 is the same way.. speedo read 7-8 mph vs GPS Speedo.. I have 205\45r17s on mine.. in for some info
Old Mar 29, 2013 | 04:58 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
There should be no speedo error with 205/45x17 tires on 7x17 wheels. Suggest you find a good stretch of Interstate with 1/10 mile markers and do an odo check for 10 miles. As for ericmakkar, to my knowledge, there's nothing you can do to re-calibrate your speedo to the smaller diameter tires.
Old Mar 29, 2013 | 05:14 PM
mini coop's Avatar
mini coop
No recalibration available. The 195/55/16's were the wrong size tires. They should have been 195/60/16's for accuracy. And NC is right 205/45/17's are the OEM size. Even with this size though there is about a 5% speedo error according to my dealer.
This is common on BMW's. The only way to get more accurate is to get tires with a greater circumference.
Old Mar 29, 2013 | 05:31 PM
Braminator's Avatar
Braminator
If you run 215/45/17 your speedo will be accurate as many of us have found out. I compare it daily against my GPS and it is accurate as compared to the 205/45/17 that were 2-3 mph off.
Old Mar 30, 2013 | 01:14 AM
ericmakkar's Avatar
ericmakkar
Will this issue make my odometer become inaccurate?
Old Mar 30, 2013 | 03:52 AM
uromini's Avatar
uromini
Technically yes..
Old Mar 30, 2013 | 09:42 AM
ericmakkar's Avatar
ericmakkar
So then what do I do to fix this?
Old Mar 30, 2013 | 12:56 PM
Btwyx's Avatar
Btwyx
Run tires the size it was designed for. 205/40-16 is way too small for everyday use. 205/50-16 is closer to it, but still a little small. 205/55-16 actually makes the speedo pretty accurate.
Old Mar 30, 2013 | 02:46 PM
NC TRACKRAT
Veteran: Navy
Here....Play with this to see the speedo error created by using the wrong size tires:
http://www.miata.net/garage/tirecalc.html
Old Mar 30, 2013 | 06:35 PM
thulchatt's Avatar
thulchatt
Speedo and Odo don't always agree.
My speedo is spot on per GPS but my Odo records about 3% low, less miles than actual.
Old Jul 5, 2013 | 01:27 PM
drewffff's Avatar
drewffff
I've got 215 45 18 (yes 18) on mine and my 2005 mcs still reads 60 when I'm going 58.5 - 59 but the mileage odo reads 200 miles when I've gone 210 miles.
Bublik
Feb 18, 2023 11:09 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
kpl
Aug 11, 2015 04:52 AM
2manyhobbies
Aug 9, 2015 06:02 PM
