R50/53 Went into limp mode at 6000 RPM's
Old Feb 25, 2013 | 11:40 PM
Mark97xp's Avatar
Mark97xp
So i was getting on it in 3rd gear and as soon as it got to around 6K it went into limp mode with all the dummy lights on. Turned engine off and started again, runs fine except SEL still on. Any ideas? 03 MCS 42k
Old Feb 26, 2013 | 02:10 AM
BlwnAway's Avatar
BlwnAway
Look at your belt / tensioner / crank pulley, a simple belt slip & sudden loss of boost could cause this. If not any of these things and it does it again, try and pull a code.
Old Feb 26, 2013 | 05:39 AM
Braminator's Avatar
Braminator
The only real way to answer this is to pull the codes from the CEL.
Old Feb 26, 2013 | 06:29 AM
speedracerchick1's Avatar
speedracerchick1
My R53 did this the second day I had it with a rev match downshift on the highway because of a semi cutting me off. It was the Valve stuck open on the supercharger. Replaced, no other issues since.
Old Feb 26, 2013 | 07:17 AM
Braminator's Avatar
Braminator
Hey speedracer. Do you do your own work or does someone like your girlfriend, boyfriend or husband help? Don't shoot me just curious.
Old Feb 26, 2013 | 07:23 AM
speedracerchick1
I do the work on my vehicles, but when it came to the mini I haven't worked on one yet. (soon with the pulley and ect.) I took it in for a warranty fix
Old Feb 26, 2013 | 08:39 AM
Braminator's Avatar
Braminator
So the Z28 you did the work yourself? Who took the leg up pic?
Old Feb 26, 2013 | 12:02 PM
Mark97xp's Avatar
Mark97xp
Thanks for the responses guys. Went out to start this morning and CEL was gone! Went to Autozone for a free code read and it showed P1688. What does this tell me?
Old Feb 26, 2013 | 12:26 PM
Braminator's Avatar
Braminator
This is either the crank pulley or the bypass valve. Check them.
Old Feb 26, 2013 | 03:37 PM
speedracerchick1
Z28 is my other halts car when I let him drive it. She will be getting some fixes this spring. I could list the 18 different cars i've modded, raced, or built. Sargent_Sh!tbag on here is my other half. He posted in the intro section also.
Old Feb 26, 2013 | 06:51 PM
ACallahan's Avatar
ACallahan
I am with Braminator on this and leaning strongly toward crank pulley.You do have low mileage though, please definately post up outcome.
Old Feb 26, 2013 | 06:55 PM
Mark97xp's Avatar
Mark97xp
Taking it in to mechanic monday. Discussed it with him a little on the phone about it and he thinks it could be crank pulley too. I will post up later thanks.
Old Mar 4, 2013 | 10:13 AM
Mark97xp's Avatar
Mark97xp
Verdict is in, broken spring in Bypass valve. Could i also blame my poor throttle response on the Bp valve?
Old Mar 4, 2013 | 10:32 AM
GreekDrifter91's Avatar
GreekDrifter91
maybe but throttle response is a little slugish the pedal signals a bit slow hahaha, kinda wish they still made cable driven throttles.
D1 spec ($100) or sprint booster($300) will fix that.
Old Mar 4, 2013 | 12:30 PM
ZippyNH's Avatar
ZippyNH
My bet is the crank damper.....the bypass valve will not usually throw a code...could be stuck too though...they fail to seal as they age or the vacuum diagram goes bad...
The crank damper (OEM) is two metal parts with a rubber part filling in the space between them....it tends to fatigue, and let go...slipping a bit at first...then more...then totally, resulting in an immobile car....no waterpump, SC, alternator, etc.
The fix is a new OEM, or IMO the better, longer lasting, route, a ATI superdamper or the cheaper than OEM PRW (or PRI?) gel damper....both have had good results from folks using them.
Old Mar 5, 2013 | 12:55 PM
Mark97xp's Avatar
Mark97xp
Ordered up the Detroit tuned bypass valve and will get it installed friday. Hope to get the same results i keep reading about compared to OEM.
Old Mar 5, 2013 | 01:11 PM
ZippyNH's Avatar
ZippyNH
All bypass vales made after 2005 had a bit of a stiffer spring....made things better...
The DT one has a STIFFER spring yet...
some like it, some don't..it snaps shut, making the car a bit harder to drive with fineness....
Tip....you can ZIP-TIE the old one closed, and test it...
you will loose a bit of MPG cause it will not bypass the SC boost at very low/idle rpms, reducing engine load, but easy test to see of you get a code...some valves DO have the vacuum actuator/cylinder that opens/closes it fail, or the seating ring wear that forms the seal...all easy to look for.
Old Mar 5, 2013 | 03:32 PM
Mark97xp's Avatar
Mark97xp
All the positive posts ive read about the DT BPV seem to be on the 02-04's. Something about the Yo-yo affect on these Mini's.
wildwestrider
11
Jan 29, 2016 05:06 PM
potterstein
Oct 2, 2015 09:30 AM
MINI Stupor
Oct 1, 2015 11:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
