R50/53 no idle, misfire
Old Feb 11, 2013 | 11:14 PM
limitedxj's Avatar
limitedxj
no idle, misfire
2005 mini cooper s, 15% and +2 balancer.
Mini cooper s drove in a rain storm from Atlanta to knoxville with no problems, in knoxville hit a large bump on the interstate immediately felt a vibration, all lights came on including the door open light. pulled over let off gas the mini died.
To start the car you have to give it gas and it will only run when throttle is depressed, let off it dies. codes were for a #4 misfire and O2 sensor.
Replaced the coil pack with extra, #4 and #3 were heavily corroded, replaced the wires, no help. Pulled the #4 spark plug, is wet with what smells like gas, replaced with stock plug, no change in running. check engine light flashes briefly, the traction control light comes on then the engine light stays on.
at a loss on what to look at next, the inability to even idle roughly on its own has me thinking its fuel related or vacuum, internet searches have not found anything that fits my issues fully.
any help will be appreciated
Old Feb 12, 2013 | 12:07 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Could you have damaged something underneath, crushed a pipe or similsr? I'd be getting it on a hoist for a real slow, good look round. Good to find the dirty terminals though, look for more.
Old Feb 12, 2013 | 06:50 PM
limitedxj's Avatar
limitedxj
upon further inspection today, the metal piece in the belt tensioner has broken off and the pully now rest against the balancer, don't know if this is the problem or a effect of the misfire which is violent. anyone with a similar story let me know.
Old Feb 12, 2013 | 08:01 PM
limitedxj's Avatar
limitedxj
took the tensioner and belt off, the tensioner is now in 2 pieces, tried to start it without belt to see if it would idle, no luck, still the same feeling.
Old Feb 14, 2013 | 12:05 PM
limitedxj's Avatar
limitedxj
Compression test revels no compression in #4, all other cylinders at 125. Here's hoping its just a valve spring and not a bent valve or cam issue
Old Feb 14, 2013 | 12:53 PM
SRICHS's Avatar
SRICHS
I've broken 2 valve springs in my 06 s. sounded like a john deere tractor while running. I've also sent cyl 2 piston through the block on an 02 s.. and the 02 actually sounded better running before AND after it happened...
valve springs in 2006 seem to be a bit more unstable. hoping for the best for you.
Old Feb 14, 2013 | 03:04 PM
limitedxj's Avatar
limitedxj
Did you repair yourself? Haven't looked at the internals of a mini head, my 6.7 stroker jeep has dropped a spring before, to much rpm and to much nitrous. It was as simple as removing the valve cover and blowing the lifter up with air. Anybody have experience with the mini head?
Old Feb 22, 2013 | 09:51 AM
limitedxj's Avatar
limitedxj
Intake valve #4 spring was broke but still together on the valve stem, replaced and replaced tensioner, all's well with the mini again. Thanks for the sparse replies.
Old Feb 22, 2013 | 11:14 AM
ZippyNH's Avatar
ZippyNH
Giving a thread 2 days during the winter when many folks check in weekly....
At least the reply did point you in the right direction....heck 75% of owners generally call for a tow if it involves the valvetrain! Good to hear it is back aok!
Old Feb 22, 2013 | 11:54 AM
limitedxj's Avatar
limitedxj
Am thankful for those that did reply, guess I'm use to my speed freaks forum. We tear down, break then modify everything. Dealerships are no help to us but parts.
Old Feb 22, 2013 | 11:56 AM
limitedxj's Avatar
limitedxj
By the way the process is as simple as a old push rod plus mini is nice enough to use a reusable valve gasket.
scfiveo
Sep 27, 2019 02:27 PM
Fordgt4
Oct 10, 2015 10:42 AM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
silence2-38554
Sep 28, 2015 12:19 PM
