R50/53 Passenger window regulator..diy??
Old Sep 14, 2012 | 07:04 AM
imncrxtc's Avatar
imncrxtc
Is there a DIY for replacing the window regulator? My passenger side stopped working...im assuming its the regulator. I can hear the noise when i hit the toggle switch.
Old Sep 14, 2012 | 07:07 AM
Cheerio44's Avatar
Cheerio44
I second this! my drivers window stopped working :\
Old Sep 14, 2012 | 06:26 PM
mikewitdaspike's Avatar
mikewitdaspike
More than likely it is your regulator, when mine went out you could hear it trying, but it wouldn't go anywhere. No idea on DIY though, I got shipped off to South Korea before I could get it fixed and my mom took it to the dealer
Old Sep 14, 2012 | 08:36 PM
buzzsaw's Avatar
buzzsaw
Found this on the site below--hope it helps: http://www.z50ak1.com/mini/default.htm
KMPSSBL's Avatar
KMPSSBL
I bought my car with the passenger side window not working. The previous owner had already ordered a new regulator (lucky me), so it came with the car.
I searched Google for how to replace the regulator, and found a fairly easy one to follow. It didn't have pictures, but my husband and I were able to walk ourselves through it and fix it Turns out the wire was being eaten up by the motor when it got stuck in the first place.
Here is a good one, with pictures and everything. Overall, it's a fairly easy fix. Should only take about an hour to MAYBE two hours. Good luck!
http://www.pelicanparts.com/techarti...eplacement.htm
EDIT: I think the link the person posted above me is the one I actually used lol. Either way, both good walk-throughs!
Old Sep 15, 2012 | 03:33 AM
JAB 67's Avatar
JAB 67
I did mine. Not the easiest DIY, but far from the hardest. Helps to have the 'special tool' to remove and reinstall the bolt that holds the glass to the regulator. I got it through 'SamstagSales.Com.'
Old Sep 20, 2012 | 04:28 AM
imncrxtc's Avatar
imncrxtc
how much was the tool JAB?
Old Oct 5, 2012 | 09:16 PM
chaseabryant's Avatar
chaseabryant
If you can't get your hands on the tool, you can always use an allen wrench; there is a hex head bolt in the middle of the "cog" that holds the glass in place.
You might try a good whack on the door panel, right above the large round speaker. This worked for me quite a few times before the regulator got too tangled to work. Like another person who commented, the one that I had to replace had its cable tangled.
-Chase
Old Oct 6, 2012 | 04:32 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by JAB 67
.......Helps to have the 'special tool' to remove and reinstall the bolt that holds the glass to the regulator. I got it through 'SamstagSales.Com.'
Good call. Without it 90% of the time the DIY'r ends up breaking the glass. Seen a few body shops do this.
Old Oct 6, 2012 | 04:40 AM
r34king's Avatar
r34king
Just remember that the "bolts" that hold the window are reverse thread from inside the door.
Old May 17, 2013 | 03:35 PM
atraain's Avatar
atraain
where can i get the SPECIAL TOOL for a good price? or does anyone have a item number for the SPECIAL TOOL?
Old May 20, 2013 | 11:45 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You can use a 5mm hex key to remove the pegs in place of the special tool.
Window Regulator Replacement
888.280.7799 | 6am - 5pm PST
Old May 20, 2013 | 11:52 AM
atraain's Avatar
atraain
I tried a 5mm hex key and the center of the peg got threaded, so i just ordered the tool from WAY.
I also read somewhere that to take off the pegs holding the window to the regulator you must spin the oposite way? Are they reversly threaded?
Old May 21, 2013 | 04:08 PM
PelicanParts.com
Vendor
Not that I am aware of.
Old May 22, 2013 | 06:48 PM
atraain's Avatar
atraain
where can i buy the white clips that hold the regulator cables up top? Mine broke
Old Apr 19, 2023 | 04:13 PM
mini_me123's Avatar
mini_me123
Attachment 157486
yeah, where?
Old Apr 20, 2023 | 08:05 AM
cooper48's Avatar
cooper48
You can remove (and retighten) the white gear holding the window with a flat screwdriver tapped with a hammer. The white cable holders are NLA individually but can be found in some (but not all) regulator kits (partsgeek.com).
Click to Enlarge
(Read Reviews)
SKP Window Regulator - Front Left
Part Number: 17988-02096641
Brand: SKP
Notes: Power Window Motor and Regulator Assembly -- Power Window Regulator With Motor
Old Apr 20, 2023 | 08:09 AM
cooper48's Avatar
cooper48
I did find this kit that also includes hardware for the regulator.
https://www.ecstuning.com/b-genuine-...r/51337031087/
TGlax38
Sep 16, 2015 07:26 AM
USA-RET
Sep 8, 2015 01:50 PM
Ntety
Sep 2, 2015 08:39 PM
hardy616
Sep 2, 2015 08:32 AM
