R50/53 GreekDrifter's R53
Old Mar 26, 2013 | 10:17 AM
  #101
GreekDrifter91's Avatar
GreekDrifter91
Well Found my problem! now lets hope i can fix it.
this is the selector for the 5th/6th fork and as you can see it is broken i found the broken part on the magnet. now all that's left to do is find a replacement or have a machine shop weld on material and cut it down. or have them make me a brand new part.
as i was playing with it to watch what was going on with the cover off the finger would go into the slot but when you went to turn the relay shaft it would just slide right out of the slot, so that's why i could not select 6th and why 5th would be troublesome some times.
Old Mar 26, 2013 | 10:39 AM
  #102
Braminator's Avatar
Braminator
WOW. Good luck.
Old Mar 26, 2013 | 11:11 AM
  #103
minibx's Avatar
minibx
You are a brave man!!!!!!! Good luck with the fix
Old Mar 26, 2013 | 11:34 AM
  #104
GreekDrifter91
WOW. Good luck.
believe me this is a hell of a lot nicer and eaiser trans than the 5spd i had in my jetta, that thing was a nightmare...
thanks for the wishes
Old Mar 26, 2013 | 12:29 PM
  #105
jpinkerton's Avatar
jpinkerton
There is some serious work going on with your Mini.. Good luck with the repair! You seem to have it under control
Old Mar 27, 2013 | 03:05 PM
  #106
GreekDrifter91
Good news! i found a great deal and im getting a re-manufactured gearbox off someone cool for, $500 never used still in its box. its got 52k on it. It will be here, i really really hope, by tomorrow so i can install it either tomorrow night or friday morning. Im still going to try and fix my old box and ill put it on the side just in case. i need it down the road.
So today was a long day but got a lot done. ill put some pics up when i get a chance. i know yuo guys love pics..... so do I
installed new
- rear main seal
- clutch/ pressure plate
- Lower control arm bushings
- Steering rack bushing
- Gear box mount inserts
- lower enigne mount inserts
so whats left is
- oem belt
- upper engine mount inserts
- install gear box
- plug everything back in and hope it works.
Old Mar 27, 2013 | 03:16 PM
  #107
Kahnfucious's Avatar
Kahnfucious
installed new
- rear main seal
so whats left is
- oem belt
- install gear box
I don't think I replied but please replace that guide tube. Even if you have to buy it at the dealer...you don't want to do this again for a 35 dollar part
Old Mar 27, 2013 | 06:09 PM
  #108
GreekDrifter91
well hopefully this re-manufactured box has a new guide tube and seals.
Old Mar 31, 2013 | 03:53 PM
  #109
GreekDrifter91
little update..... so everything looks to be in good working order rplaced things that needed to be replaced. the trans is in, sub frame is in driver side axle and everything is hooked up where its supposed to be last thing left is to put in passengers side axle and engine mount.
and becasue murphy seems to be revolveing around me this whole time my dip stick broke so i ordered a craven speeed one should be here tomorrow, and got a ultra gauge. oh and i messed up my passenger side cv berraing going to see if i can fix it or get a new one. dont know if i lost all the rollers inside the bearing. oh and brake lines need to be done too.
Old Apr 1, 2013 | 10:17 AM
  #110
GreekDrifter91
and they arrived... now off to school.
fancy packaging for a dipstick...
Old Apr 4, 2013 | 04:53 PM
  #111
uromini's Avatar
uromini
You'll like the Ultragage.. its not the quickest refresh rate but its good.. have one in my daily Camry.. probably end up in the r53... lol
Old Apr 4, 2013 | 05:53 PM
  #112
GreekDrifter91
just tried it out tonight cuz i just put together the mini.
i read on the web site you can make the refreh much faster, im gonna look at the maual tonight and see but so far i like it
Old Apr 4, 2013 | 07:55 PM
  #113
GreekDrifter91
yea so all you have to do is go into the gauge page menu and go to refresh and change the rate to 0.3 sec. i think that's plenty fast and shows everything i want perfectly.
SOooooo...... The Mini is back up and running and it is glorious! i did not install my SS brake lines or the upper engine mounts because i just wanted to get back into my car all ready. so ill leave those for a later date again.
so pics more tomorrow after i wash and wax. my car is so dirty.
I also have the ABS and Traction Control light on and the TPMS light. any ideas what could eb the problem? code reader doesn't say a thing. i might have to go to MINI and see what there computers can tell me.
Driver side LCA bushing
Gear Box Bushing
Passneger side LCA bushing
Lower Engine Mount Bushing
Old Apr 4, 2013 | 08:01 PM
  #114
Braminator's Avatar
Braminator
So how do all the bushing feel now?
Old Apr 4, 2013 | 08:10 PM
  #115
GreekDrifter91
Fantastic! the car is so smooth and tracks very well, steering is very posative and it feels like you actual know where the wheels are going.
cant wait to put the upper engine mounts in! at the moment at idle its very minimal vibration. but when you blip the gas from idle to about 1000-1100 rpms its a little harsh but under regular drive no vibrations at all. power gets to the wheels nicely.
Old Apr 8, 2013 | 11:58 AM
  #116
GreekDrifter91
Well my problem with my ABS DCS and TPMS light went away by its self. so maybe it was the stuck brake caliper i had. anyone know if it takes a certain amount of miles before the problems correct them selves? ABS definantly works i slamed on the brakes to make sure. and i tired a hard start and the DCS is as invasive as it was before no wheel spin and engine pwoer was cut hahaha. and TPMS light went out too.
and this all happend after i went to the dealer to make an apointmant; why i need an apointment for them to plug a computer into my car and tell me whats wrong is beyond me but what ever. myabe its just a coincidence that everything is fixed now that i made an apointment, or it was the $130 price tag to "diagnose" the car that scared my mini straight. :D
Old Apr 8, 2013 | 12:13 PM
  #117
Braminator's Avatar
Braminator
It can take a couple or a lot of drive cycles to clear the code from memory once a problem is properly fixed. One drive cycle is considered when the car starts and when the car is cold until it reaches operating temperature. I have seen them go off in a few miles to 40-50 miles before they have cleared themselves. This is just my opinion.
  #118
Mariano305's Avatar
Mariano305
I had the same problem it was the yaw speed sensor i replaced it and everything is fine now its located right behind the handbrake
  #119
Mariano305's Avatar
Mariano305
I'll send you a pic of the module
Old Apr 8, 2013 | 12:26 PM
  #120
GreekDrifter91
ok, now lets hope they dont come back. and now i have to cancel that apoinment. mini dealer isnt gonna get money form me hahahaha
ok cool, dont think its the yaw sensor but if it is pics would be great!
Old Apr 8, 2013 | 03:51 PM
  #121
GreekDrifter91
aaannnddd the lights are back and everything doesnt work again. FML
Old Apr 8, 2013 | 04:11 PM
  #122
ZippyNH's Avatar
ZippyNH
The trifecta (as it is often called) is USUALLY associated with a wheel speed sensor...
one in each hub....check the wires...you did so much work, one might have gotten damaged.
Old Apr 8, 2013 | 04:31 PM
  #123
Braminator's Avatar
Braminator
Greek, I am with him on this but I thought you already checked this. Did you miss it?
Old Apr 8, 2013 | 05:13 PM
  #124
GreekDrifter91
no i didnt check the wires but ill check them when i get a chance.
Old Apr 9, 2013 | 01:37 PM
  #125
GreekDrifter91
so i cleaned all the WSS's the front ones where covered in crud. the rears where perfectly clean. the lights did not go out, so went for a long drive. stopped got out went for a walk. came back started it up and lights are out and everything works. i drove a few miles and did the same thing again and lights still stayed out. so hopefully it was just dirty sensors and not a bad WSS or i hope its not the ABS module. but time will tell.....
