R50/53 GreekDrifter's R53
Old Feb 2, 2014 | 09:22 PM
  #376
Fir3Chi3f's Avatar
Fir3Chi3f
Finally sub your thread
Originally Posted by Stoker
"raised edge facing head? or raised edge facing manifold?"
That's what i asked Steve, he said it didn't matter cause they get crushed..
I put the raised edges "facing" the manifold, made more sense…
He showed me a trick, if you have a couple of ten mm bolts cut the head's off and use them in the two outermost bolt holes to align/hold the gasket in place, while your putting on the header. made life very easy since, the header is an awkward fit..
Could have used this info when I reinstalled my header. Good to know though
Old Feb 4, 2014 | 02:01 PM
  #377
GreekDrifter91's Avatar
GreekDrifter91
well good news is i think the bolt holes will line up with the ones on my head... i think i may slot the bottom middle two like the gasket just in case i need the room.
as for the ports i am undecided yet it i will grind it to a circle to match the runners. or match it to the gasket. i feel like i have some research to do and to ask the opinion of people who know better. i have a feeling it will not matter but its better to ask, measuer twice cut once right hahahahah
Old Feb 12, 2014 | 05:40 PM
  #378
GreekDrifter91
another update....
i put the stock injectors back in... my mpg was so bad i was at 21mpg and during cold start it would be real hard to drive until the car warmed up. then it was fine. other wise it was super rich at idle and at WOT. you could smell it was pretty smelly. at least i know they work and when i get the rest of my exhaust in ill put those guys in and get a tune.
also i can feel the lack in power at wot and in the higher rpm range like 4.5 to 7 it feels less beefy. below that its ok
i was to lazy to go get new orings, so i used the ones off my 380s. The ones on my stock injectors were torn.
Old Feb 12, 2014 | 05:42 PM
  #379
Stoker's Avatar
Stoker
What was the AFR at Idle?
Old Feb 12, 2014 | 08:00 PM
  #380
GreekDrifter91
dont have a wide band thats going in when i change my exhaust system.... but i could smell it being really rich even when the car was warmed up.
Old Feb 15, 2014 | 06:49 PM
  #381
GreekDrifter91
so after a long awaited drop off i finally got my injector adapters in ( USPS fault)
pretty fancy, maybe these will work better than the other ones i had. which were a little loose.
Old Feb 15, 2014 | 07:47 PM
  #382
Stoker's Avatar
Stoker
Loose? do you think that was why you were getting miss-fire's?
Old Feb 16, 2014 | 09:15 AM
  #383
GreekDrifter91
yes, im willing to bet it was those adapters. they were a bit loose. after loading them up with dielectric grease the didnt wiggle as much and they went away except for one cylinder would literally miss once in a blue moon, but it would always be at the most inopportune times.
Old Feb 26, 2014 | 03:50 PM
  #384
GreekDrifter91
so i finaly got around to open up those ports tonight. looks like the runners and or flange are a bit off. I may grind down those small areas where the black marker is still. but beveled because im already grinding into the runner side wall i don't want to go more. and it still needs a bit of cleaning up
Also i maybe picking up a new project car soon. so this car will probably go on hold. money i was going to use on ceramic coating, cat-back, tune, and a catalytic converter will go into buy a car to turn into a race car.
Old Mar 17, 2014 | 05:35 PM
  #385
GreekDrifter91
UPDATE!!!
Sold my header to a friend i just did not want to have put it in, im feeling way to lazy.
New things i bought, and waiting for them to come in.
-EBC Red Stuff Pads all around
-New Oem wipers for the front and rear
-a brake power bleeder
-a liter of power steering fluid. im running dangerously low. im glad i caught it.
- a new gates belt tensioner assembly off of amazon
- a belt tool
Things to be bought but need some $$$$ and that should be it for this car!
- Alta cat-back
- Slotted rotors, my oem rotors are pretty done, the ebc green stuff pads chewed right through them.
- Tune
- Rear sway bar.
also PSA make sure to check your brakes. my rear brakes were seized again and were probably dragging all winter long. only saw it because i change to my summer tires all ready.
i have a feeling it was beacuse of the "brake stiffeners" i have had them seize up alot. so i just put in the OEM rubber slider holder things back in. now to just sit and wait to see if they seize again. i dont think so though. i have never had a problem with the front brakes so i left those in. and i put in a spare set of pads i had when i first bought the car and change over to the ebc green stuff pads.
there is like a 1/16 left of material left on that pad. both sides are cracked chipping away and or falling apart.
Old Mar 25, 2014 | 01:14 PM
  #386
GreekDrifter91
Murphy's Law never ceases to amaze me.
my Exhaust system fell of its hangers. and cracked the down pipe area after the collector on the header. and i don't have a another header to fix it with because i sold my Megan header to a buddy. So I ordered a OBX header and a Maganflow Cat those will hopefully be in soon. in the mean time because the crack was getting bigger. i used a bunch a patching kits to hold it over for now. it worked great on monday but today not so much looks like it probably broke free a bit. so when its cold the patch will leak but when hot it wont.
in other notes lots of parts and tools came in.
Power steering Fluid because i was running dangerously low.
Power Break Bleeder.
Gates belt tensioner assembly.
i bought a fire extinguisher at autozone
EBC red Stuff for front and rear. (these wont go in untill i buy new rotors)
Belt tensioner tool. because im sick of doing it the cheap way.
new wipers front and rear.
Old Mar 25, 2014 | 01:22 PM
  #387
heresmymind's Avatar
heresmymind
gabe you could of borrowed my belt tool. i also have a crank pulley tool. I also have EBC pads which are good for autox, but are a bit lacking for daily driving, I've tried hawks too, but stoptech have been my favorite so far. I will be borrowing some steering fluid though :-D. Can't wiat for the spring show
-B
Old Mar 25, 2014 | 01:37 PM
  #388
Fir3Chi3f's Avatar
Fir3Chi3f
I'd care to see how you mount the fire extinguisher. I bought one too, but I'm so hesitant to just drill self tapping screws into stuff.
Old Mar 25, 2014 | 01:45 PM
  #389
GreekDrifter91
at the moment it is smooshed behind the passenger seat and rear passenger foot area.
Old Mar 25, 2014 | 05:44 PM
  #390
Da_Ghost's Avatar
Da_Ghost
You'll love you Motive bleeder, I have the same I bought a fire extinguisher too this week Seeing the list of cars that burned down on here... as well as assisting a guy whose car was burning on the side of the highway (calling 911 as I didn't had a fire extinguisher...)
As for mounting, a lot of people use a custom bracket so it's bolted on the passenger seat frame.
Old Mar 25, 2014 | 05:51 PM
  #391
GreekDrifter91
yea i cant wait to use it i think i still have a bubble some where in the system. and i want to bleed the clutch line and im sure this will make it 1 million times easier.
i was considering the passenger seat mount but I'm worried about leg room/ leg foot position for the other person it might be awkward.
Old Mar 25, 2014 | 07:41 PM
  #392
Fir3Chi3f's Avatar
Fir3Chi3f
My primary concern was placing it somewhere that it could be grabbed while exiting the vehicle and the passenger seat is just not optimal for that. Also is the obvious mounting it away from air bags and in the way during regular use.
The seat option is also the most expensive by comparison:
http://www.outmotoring.com/mini-coop...ni_cooper.html
I liked the idea of mounting it in the trunk, but then again I don't like the idea of my access to the fire extinguisher being reliant on the car having power for the electric hatch release.
There is also the DIY option I found here, but it's again under the passenger seat
https://www.northamericanmotoring.co...r-bracket.html
Old Mar 26, 2014 | 02:56 PM
  #393
GreekDrifter91
well the exhaust is completely broke now, it lasted a good 3 days with the patch.... that patch wont hold the whole system up the middle hanger was broken and its being held up by one in the rear and the cross brace in the middle.
on the way to work this morning (6am) on the highway it was nice and quite then all of a sudden AAAAAAAHAAHHHHHHHHHH... and i new what happened
so i now have a Alta cat-back that i ordered and am waiting on the obx header and cat thats in the mail.
and video of me moving it around then the next one is driving it to red line just for the LOL'S ..... the video does not do the noise justice it was so unbelievably loud it was really not funny.
http://s228.photobucket.com/user/Gre...f8763.mp4.html
http://s228.photobucket.com/user/Gre...b6edc.mp4.html
Old Mar 26, 2014 | 03:00 PM
  #394
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Gonna love the Alta Cat back...sounds awesome on my JCW.
Old Mar 26, 2014 | 08:32 PM
  #395
Stoker's Avatar
Stoker
Let me get this straight. You sold your new header then, a week later the stock header broke? What are the chances of that? Thats some quantum string theory type of nuttiness...
Old Mar 26, 2014 | 08:42 PM
  #396
miniblucabrio's Avatar
miniblucabrio
Sounds like my kinda luck. That alta is going to be loud with the OBX!
Old Mar 27, 2014 | 02:24 PM
  #397
GreekDrifter91
the Magnaflow cat came in.... if you are interested in specs
PART#: 91036
INLET: 2.5in.
OUTLET: 2.5in.
CONFIGURATION: Center/Center
BODY SHAPE: Oval
BODY LENGTH: 9in.
WIDTH: 6.5in.
OVERALL LENGTH: 13in.
FEATURES: Small Oval; 4.2L/4500lbs. EPA; 13in. Overall; Single O2 port
Old Mar 27, 2014 | 04:27 PM
  #398
GreekDrifter91
are o2 sensors "readable" like spark plugs? what does this guy tell me?
its the pre-cat o2
Old Mar 28, 2014 | 07:57 AM
  #399
Stoker's Avatar
Stoker
That's what my AFR sensor looks like, I asked about the white residue, was told "it's normal"..
Old Mar 31, 2014 | 01:13 PM
  #400
GreekDrifter91
OBX header came in.... looks like im gonna spend some quality time grinding those ports even again... not as bad as the megan but its not even.
