R50/53 Winter beater? 190K mile MCS
Old Dec 15, 2011 | 07:08 PM
masternut's Avatar
masternut
They want 6K for a high mile MCS....what is it worth....and would you buy it?
Thanks in advance!
Old Dec 15, 2011 | 07:22 PM
ScottRiqui's Avatar
ScottRiqui
What model year? Pending a thorough inspection, including a compression test, I'd have no problem buying it if there were no glaring problems - high mileage on a modern car doesn't really scare me.
I'd pay particular attention to the clutch and the suspension bushings, though.
Old Dec 15, 2011 | 07:24 PM
masternut's Avatar
masternut
Sorry...2003 I think....I have a 2011....but I do not want to drive it through winter
Old Dec 15, 2011 | 07:42 PM
mckchr67's Avatar
mckchr67
Yeah I second compression test and check the suspension along with a slight low ball and that would make for a good winter ride.
Old Dec 16, 2011 | 02:08 AM
NightFlyR's Avatar
NightFlyR
has the SC been replaced?
Old Dec 16, 2011 | 11:02 AM
masternut's Avatar
masternut
I do not know...I bet the SC is a concern with high miles
Old Dec 16, 2011 | 11:08 AM
mdsbrain's Avatar
mdsbrain
Power steering fan?
Old Dec 16, 2011 | 11:09 AM
ScottRiqui's Avatar
ScottRiqui
Well, there are really only two common problems with the supercharger. The first is general wear, which will gradually increase the tolerances between the rotor vanes and the case. This will just cost you a little bit of boost. The other is if the "lifetime fill" oil in one of the two lubricant reservoirs leaks out. If it happens on the water pump end of the supercharger, it will chew up the PTO (Power Take Off) gearing and the water pump in fairly short order.
If the supercharger isn't making any grinding/rattling noises, the lubricant is probably fine, although it would be something I'd check and replace on general principle if I ended up buying an MCS with that many miles.
Old Dec 21, 2011 | 05:34 AM
quickcoop's Avatar
quickcoop
I just picked up a 190k MCS for $5500 and LOVE it. Totally worth the buy if it's been properly cared for & maintained
Old Dec 21, 2011 | 01:29 PM
essanvee's Avatar
essanvee
Wow, 190k... seems like a lot of risk, I would at least put $800 aside for something like SC or wheel bearing repair. I would think its value is more like $4500...
Old Dec 21, 2011 | 03:17 PM
masternut's Avatar
masternut
Was it the one on CL in Cincy?
It looked like a nice car
spec35
Aug 18, 2015 07:07 PM
massmini03
Aug 12, 2015 11:19 AM
clintmeister
Aug 12, 2015 11:11 AM
ludedude
Aug 10, 2015 07:16 PM
Dashdog
Aug 10, 2015 06:17 AM
