R50/53 Total miles your MINI has right now
Old Aug 10, 2016 | 08:11 AM
  #1376
xsmini's Avatar
xsmini
Originally Posted by MiniMusician
10 years - 43K miles WOOHOO!
:( thats sad.....
Old Aug 10, 2016 | 09:40 AM
  #1377
JasonB's Avatar
JasonB
06 S turned 204,300 last night. Took it off the lot with 27 miles.
Old Aug 10, 2016 | 09:44 AM
  #1378
sherman89's Avatar
sherman89
A friend of mine has a 2005 copper 5spd with 195,000 and other than oil and oil filter changes the car has nor been touched and he bought it new.
Old Aug 10, 2016 | 09:46 AM
  #1379
wpgmini's Avatar
wpgmini
From today:
Old Aug 11, 2016 | 08:43 AM
  #1380
CooperSAZ's Avatar
CooperSAZ
Old Aug 11, 2016 | 09:32 PM
  #1381
KDKid's Avatar
KDKid
Just broke 170k kms
Just replaced my alternator and added a 15% pulley to my supercharger. Best car I've ever owned.
Old Aug 21, 2016 | 10:45 PM
  #1382
princeofwaldo's Avatar
princeofwaldo
My 2006 MC just turned 10 years-old the other day, and now has 139,000 miles on it with virtually no problems the entire time I have owned it. An engine mount failed early on, a bad oxygen sensor at 100k and the middle brake light about the same time are the only failures I have had so far. Without question the best car I have ever owned
Old Aug 29, 2016 | 09:14 AM
  #1383
xsmini's Avatar
xsmini
Old pic - couple weeks ago, so its a thousand or so shy of the current milage.
Nik
Old Aug 30, 2016 | 07:24 AM
  #1384
Mudhen's Avatar
Mudhen
Looking good, XSMINI!
Mine is barely ticking up at all lately. Hit this last night:
Seems like when I was commuting with it I'd go 10s of thousands of miles without touching it. Now I barely drive it...mainly just, ahem...rallyx...and there's always something to do! Just did the crank pulley, coolant jug, and motor mount - each for the first time. Guess I've been lucky!
Old Aug 30, 2016 | 02:14 PM
  #1385
Mini Mania's Avatar
Mileage
Just turned to 80,000 on my '04 R53
Old Aug 30, 2016 | 05:16 PM
  #1386
foo's Avatar
foo
56789 on my 04 R53
Old Aug 31, 2016 | 10:36 AM
  #1387
morfeeis's Avatar
morfeeis
Originally Posted by Loyal242
Hit 170k with my '05 MCS yesterday. Running strong!
Mind if i ask what major failures you have had and at what mileage, i was lead to believe that no way in hell would any part last so long on this car. you're post makes me very optimistic...
Old Aug 31, 2016 | 10:54 AM
  #1388
MiniTigger's Avatar
MiniTigger
06 R53 - 80k here.
Old Aug 31, 2016 | 11:01 AM
  #1389
Captain Jeff's Avatar
Captain Jeff
Hit 94,500 on my 05 R50. No issues so far knock on wood!
Old Sep 1, 2016 | 04:48 AM
  #1390
mister.t's Avatar
mister.t
Ticked over this milestone yesterday
Being 1 of 3 cars in my possession and now using nasty public transport for work, it's not increasing at a rate I'm happy with!
September 2002 Cooper S
Old Sep 4, 2016 | 02:31 AM
  #1391
pepperwhitejcw's Avatar
pepperwhitejcw
Hit 70k 2 weeks ago (2004) on the way to home after picking up the car (8hr drive) - currently car sits at 70,4xx
Attached Thumbnails Total miles your MINI has right now-image-2476120406.jpg
Old Sep 8, 2016 | 06:41 AM
  #1392
06supercooper's Avatar
06supercooper
Originally Posted by foo
56789 on my 04 R53
101k 06 R50
Old Oct 11, 2016 | 08:05 PM
  #1393
tmors424's Avatar
tmors424
90k miles of smiles😎.
Just clicked the 90k milestone. 2005 R53 refreshed model original owner here. Kicked around selling it but, decided to keep her till the wheels fall off. Ok you high mileage 1st gen owners, what maintenance did you do at 90k? Looking to love her long term.
Old Oct 11, 2016 | 08:14 PM
  #1394
MCSmoonshine's Avatar
MCSmoonshine
my 04 r53 is a few miles from 208000. Had its original clutch replaced at ~150k and has been cruising ever since.
Old Oct 12, 2016 | 08:54 AM
  #1395
Squirrel724's Avatar
Squirrel724
Just hit 139,000mi on my 2004 R50 Cooper on Friday. I fully plan on taking it well past 200,000mi during my ownership.
Old Oct 12, 2016 | 09:24 AM
  #1396
Mudhen's Avatar
Mudhen
You can see by the lack of responses...none! Just keep the right foot down...
Old Oct 12, 2016 | 01:25 PM
  #1397
Little over 264K now on the 2005 MCC.
Old Oct 12, 2016 | 02:56 PM
  #1398
CooperSAZ's Avatar
CooperSAZ
Keep in mind, at 90k I did a few revisions but I like being proactive about stuff as opposed to waiting until it goes.
This is my experience:
At 90k miles… I replaced the main radiator fan assembly, crankshaft position sensor o-ring, belt tensioner and the a/c clutch coil.
Listen to when you shut your MINI down, the motor will stop but the radiator fan is still spinning. Listen to it if you can. If the bearing is starting to go bad, you will hear a ticking sound until the fan stops.
At 100k miles, I would look at shoring up any oil leaks you might have: oil pan gasket, replace the crankshaft position sensor (on the front side of the motor on the engine block), replace the camshaft position sensor on the passenger side of the motor underneath the passenger side engine bracket and then replace the valve cover gasket. While you are in there, replace the dip stick o-ring to prevent any additional oil leaks. This should shore up any oil leaks you might have…
Overhaul the ignition system on the MINI. This includes the coil pack, wires, plugs, camshaft position sensor and crankshaft position sensor as list above. (oil leaks)
Check out and swap (if need be) the power steering lines that might be leaking P/S fluid. Inspect the fan assembly underneath as it may be time to replace due to age. If the fan dies, the P/S pump will fail shortly after.
When was the last time your engine mounts have been changed? There is a passenger side mount, the dog bone underneath and the transmission mount.
Front end suspension… Inspect your drive axles and look for torn boots. From my experience, the inner rubber boots tear before the outside boots (hub) go. Replace the inner and the outer ball joints.
Cooling system at 100k (for me anyway), swap out the radiator, thermostat, gasket and housing (plastic). Replace the top and bottom hoses and this is a good time to flush the coolant system fluid. Becareful over time, there is a T-Connector in back of the thermostat housing that likes to die due to age of the vehicle. A few folks have sourced a coolant leak from this T-Connector (myself included) when it fails. Working around the thermostat/housing can cause this connector to finally give up the ghost. It is in back of the motor near/underneath the air box/filter. The coolant line reaches the t-connection and a small hose runs to the expansion tank for adding/removing coolant.
As you replace your brake pads, if you are noticing uneven/accelerated wear (in back?), you need to replace the rubber bushings that hold the calipers in place. A lot of people only replace the rotors and pads and forget that the caliper guides are rubber and fail over time. I was getting about 36-38k miles on a rear set of pads and that came down to 16-18k miles for the rear pads before I figured out that the rubber guides were toast. You can replace these guides with the OEM rubber pieces or get steel collars that hold the calipers in place perfectly. Good and bad to each option.
If when the crank pulley decides to go/die, replace it with an aftermarket pulley that will not die on you. When replacing the crank pulley, make sure you replace the front main seal behind the crank pulley as well.
My random thoughts for you…
Old Oct 13, 2016 | 02:11 PM
  #1399
Mini Mania's Avatar
Maintenance
Great info CooperSAZ. Thanks for sharing.
I would add changing out the transmission fluid at 100,000 miles.
http://new.minimania.com/Mini_Cooper...for_Gen2_Minis
Old Oct 13, 2016 | 04:07 PM
  #1400
Mudhen's Avatar
Mudhen
x2 - great info. I just hope nobody reads this and thinks that stuff *has* to be done. Half that stuff I still haven't...at 209k...
