R50/53 Cooling Fan Problems
Old Sep 12, 2011 | 06:46 AM
bgblk1968's Avatar
bgblk1968
My daughter has an 02 Mini, non turbo automatic, which at first we thought was battery problems. After checking battery was good and the cooling fan will continue to run after car is shut off. Not for 10-15 minutes, but till it runs battery down. What is the problem...stuck relay or what? HELP!!!!!!!!
Old Sep 12, 2011 | 07:13 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
It might be the power steering pump.
here are a few links that might help.
https://www.northamericanmotoring.co...d-battery.html
https://www.northamericanmotoring.co...tantly-on.html
Old Sep 12, 2011 | 07:27 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by bgblk1968
...the cooling fan will continue to run after car is shut off. Not for 10-15 minutes, but till it runs battery down. What is the problem...stuck relay or what? HELP!!!!!!!!
Yes. Stuck relay. Unfortunately it is mounted on the fan assemble in a small plastic enclosure on the back side of the fan assembly. What I used to do before I replaced the fan was to tap the relay with a long extension and the fan will shut off. The relay is on the left side of the assembly on the fan side. There is no way to fix it without taking out the assembly.
Although you can replace the relay it is most likely that your low speed resister is also and bad and that cannot be fixed without replacing the assembly on an 2002.
Rich
Old Sep 14, 2011 | 07:38 AM
bgblk1968's Avatar
bgblk1968
Ok tapped on the relay and fan shut off. What is the best repair? Replace the fan assy? Thanks
Old Sep 14, 2011 | 08:19 AM
BlwnAway's Avatar
BlwnAway
Search "low speed fan relay" there is a less expensive fix but it is a mod, at least you would have a choice.
Old Sep 14, 2011 | 08:51 PM
Rich.Wolfson
Yes. The fan assembly has to come out. Then you can choose to replace just the relay (under 10 bucks) or go for the whole assembly. The Dorman has an upgraded resister so that is what I would do as the labor to remove the fan is more than the part. The OEM part will eventually fail again.
On the 2002 there is no option for an external resister. Those only work for the one-plug assemblies with the external relay.
All this said, I kept a long 3/8s extension next to my seat for over 6 months before I replaced the assembly. I could tap that relay in complete darkness.
Rich
Old Sep 14, 2011 | 11:24 PM
BlwnAway's Avatar
BlwnAway
Rich
Any idea on this part # or where I can find the part #, was going to do the external mod for this ('05) but since the car is coming apart anyway I'd rather go this route.
Old Sep 15, 2011 | 08:12 PM
Rich.Wolfson
Rock Auto will give you choices. The current favorite seems to be the Dorman as it has a redesigned low speed resister.
Rich
Old Sep 15, 2011 | 10:45 PM
BlwnAway's Avatar
BlwnAway
iggi
18
Feb 9, 2026 01:00 AM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Manny_cooper
Sep 10, 2015 11:09 AM
David.R53
Sep 1, 2015 06:51 PM
