R50/53 Pooled oil - 2005 MCS
Old Aug 27, 2011 | 08:35 PM
Bradg33's Avatar
Bradg33
I looked at a 2005 MCS today that I'm considering buying. When I popped the hood to look around, I noticed what appeared to be some oil pooled below the oil dipstick. I could see it when I looked straight down from above the dipstick, and it appears to be pooled on the plastic "tray" under the engine. Any idea what this might be? If I decide to move forward on the car I will probably have a Mini dealer give it a look, but thought I would ask here too.
Old Aug 27, 2011 | 09:40 PM
quikmni's Avatar
quikmni
Could be black goo leaking out of the passenger side engine mount. That is a common problem with the 05 and 06 MCS. The engine mount is a metal canister near the passenger wheel well. Look around the bottom of it have black goo everywhere. If the engine mount is leaking it is usually easy to see.
If not the engine mount there are various places that could be leaking oil. The oil pans are a common oil leak area.
Old Aug 28, 2011 | 05:31 AM
Bradg33's Avatar
Bradg33
Is it something I should be concerned about/treat as a deal breaker?
Old Aug 28, 2011 | 06:27 AM
JAB 67's Avatar
JAB 67
Assuming that it is the passenger side engine mount, should not be a deal breaker. Part is $125 or thereabouts, relatively easy DIY to replace.
Old Aug 28, 2011 | 08:18 AM
ZippyNH's Avatar
ZippyNH
Is the engine really clean....it might have been washed down to make it look better or hide a leak....
touch the goo....see if it is the engine mount oil....or maybe engine oil...could be a leaking valve cover gasket....oils are different...
Old Aug 28, 2011 | 08:22 AM
ZippyNH's Avatar
ZippyNH
It is 90% the mount I bet...
About $90 for the part...plus an hour labour(min charge).
Isoproprol (rubbing) alchool will clean up the goo....
Old Aug 28, 2011 | 09:21 AM
quikmni's Avatar
quikmni
As others are saying, if it is the engine mount it is no big deal.
However, if it is an oil leak that can be much more expensive to fix due to the amount of labor it requires to correct most of the common oil leaks on a Mini. Even a valve cover leak, that is about the easiest oil leak to fit (replace $80 gasket), costs about $400+ at a dealership. An oil pan gasket is about $800 to replace at a dealership.
Old Aug 28, 2011 | 01:19 PM
Bradg33's Avatar
Bradg33
What should I expect to pay to take it to a Mini dealer for an inspection?
Old Aug 29, 2011 | 07:24 AM
quikmni's Avatar
quikmni
I would guess about an hour of labor, so about $125 depending on the shops hourly rate.
Old Aug 29, 2011 | 10:27 AM
Bradg33's Avatar
Bradg33
That's about what I expected. As such, you can imagine my shock when Mini of Manhattan (NYC) quoted me a whopping $400 for an inspection. They'd "check the fluids and tires" for a mere $180...what a sweet deal!!
Old Aug 29, 2011 | 10:28 AM
Bradg33's Avatar
Bradg33
Any easy way for me to tell if I'm looking at it on the dealer's lot?
Old Aug 29, 2011 | 11:25 AM
CalicoGal's Avatar
CalicoGal
$400 sounds like an "Inspection I" which first occurs at 30K miles
Old Aug 29, 2011 | 11:26 AM
Bradg33's Avatar
Bradg33
Who knows. I told them I wanted a pre-buy inspection, and that's what they quoted me. I guess that's just the NYC markup.
Old Aug 29, 2011 | 11:45 AM
quikmni's Avatar
quikmni
If the mount leaked and has not been replaced or the fliud cleaned up, it should be easy to spot from the engine compartment. The mount is on the passenger side of the engine near the wheel well.
Here is a NAM post with a picture of the engine mount and the black fluid that leaked out:
https://www.northamericanmotoring.co...yone-else.html
Here is a NAM thread on the issue:
https://www.northamericanmotoring.co...ount-leak.html
If you can reach the fluid at the car dealer, stick your finger in the fluid to see what if feels like. Is it just oil or more thick/goo including mount fluid? If oil try to pin-point where it is coming from but it will probably be hard to tell.
iggi
18
Feb 9, 2026 01:00 AM
woodstudio
Mar 15, 2020 08:28 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
mdutton11
14
Oct 26, 2015 01:47 PM
clintmeister
Aug 12, 2015 11:11 AM
