R50/53 5-Speed lube to ease shifting?
Did a quick search and am not catching what I need to find out. With a 2004, my wife fiddles with the shifter getting it into reverse. I pull it down from first into second and then select reverse without any problem. Going from first to reverse seems that the syncros mess with you.
Some may have found a magic lube such as Redline gear oil that cures or makes shift selection better? Whats the voodoo here? Gotta help the wife out - her shifting technique makes me crazy.
That's because the reverse gear doesn't have synchro in the R50/R53. It does in the R56.
I don't know about the R50, but you are mistaken about R53. There is a syncro on Reverse gear on that car.
That explains why getting into reverse is so hit or miss. I'll try shifting into 2nd first.
I had my trans fluid changed at ~35000km to fix tough shift into 1st. It helped
IQRaceworks
53
Jun 28, 2024 07:29 AM
gnhovis
Sep 28, 2015 04:07 AM
