R50/53 Flat tire indicator light stays on.....
The flat tire light went on last evening. I checked and all the tires are fine. is there a way to reset it or is it malfunctioning and I need to bring it to the dealer ? thanks
The sensor(s) read wheel rotation, not tire pressure. Theoretically, if a tire is low on air it will turn slower than the rest - which will set off the warning light. Mine flukes on once in awhile too, but I just reset the light when it happens. My tire pressure might be low on one of them, which may be your issue as well.
Remember, to reset the light you have to push and hold that button for five (or so) seconds after turning the key on, but before you start rolling. Light should go out once you do roll.
I agree with Filmy. I had the light come on last week, and for me, it was a difference in the air pressure in one of the tires. Interestingly, the tire guy told me that all four were over-inflated, it was just that one was a lower than the rest.
And as a follow-up to my post above...
Just (finally) checked my tire pressure. Newer Pirelli conventional tires on all four corners. 43 lbs in three tires (WTF? - previous owner) and 20 lbs in the front right. There was my TPS problem.
Powershift
Aug 16, 2015 05:14 PM
