R50/53 Two Random Questions
Old Dec 11, 2009 | 02:08 PM
blacter's Avatar
blacter
Need help identifying a couple of items on my '02 Cooper.
First, this round thing on the top of the dash...
Second, there's a piece of black plastic that extends the whole width of the car below the front bumper. Mine is torn, so I'd like to replace it, but I can't find it in the RealOEM diagrams. Can one of you help with a part number. Thanks.
Old Dec 11, 2009 | 03:06 PM
STLMINI's Avatar
STLMINI
The round thing is the receiver for the keyless entry I believe. I'm not sure about the black piece. Maybe a picture would help.
Old Dec 11, 2009 | 03:15 PM
minicooperwill's Avatar
minicooperwill
The round thing is actually where the temperature sensor is for the automatic climate control. And I think you are referring to the scuff guard on the bottom. As far as part number, I have no idea. I'd just call a MINI dealership and get the number from them.
Crashton's Avatar
Crashton
That button deal on top of the dash is the sensor for the auto climate control.
Sorry I can't help the second question.
Old Dec 11, 2009 | 03:21 PM
ZippyNH's Avatar
ZippyNH
I was told once the black thingy is the automatic temperature control sensor....something to do with sensing the amount of sunlight or something....Might be wrong.
The Lip under the car is here I think
http://www.realoem.com/bmw/showparts...63&hg=51&fg=15
Old Dec 11, 2009 | 08:32 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
If you have your a/c set on auto, I think you can change it's output by blocking that sun sensor. Like, make your MINI think it is cloudy out, thus lowering the intensity of the a/c. When that sensor sees the sun, it makes the a/c try to counter the in-car green house effect.
As for the scuff air dam thing, it doesn't matter if it is split. I'm not even sure if it is an air dam or if it is just an early warning for hitting your lower bumper on something. This part on my car has been split and cracked and scuffed for probably more than 5 years.
Old Dec 11, 2009 | 08:40 PM
minicooperwill
Agreed. It probably isn't noticeable to anyone except you. So just leave it.
Old Dec 12, 2009 | 12:38 PM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
...or take some of the roughness off by wet sanding with water and 220 grit paper.
That is if it bothers you that much or is really noticeable.
Old Dec 12, 2009 | 07:12 PM
jcauseyfd's Avatar
jcauseyfd
Is this the part you are looking for?
http://new.minimania.com/web/item/NMX7608/InvDetail.cfm
It helps with the aerodynamics of the vehicle, though running with it damaged may not be noticeable.
Old Dec 17, 2009 | 12:47 PM
ntmid8r's Avatar
ntmid8r
I always thought the dash thing was the sensor for the auto headlights and the auto climate control sensors were the two little inserts in the front of the A/C control panel.
Never looked at any diagrams to confirm this though.
Old Dec 17, 2009 | 01:28 PM
Capt_bj's Avatar
Capt_bj
I didn't have auto headlights but did have auto a/c and did have this 'button'
it is the temp sensor for the auto a/c
iclancy82
Jan 2, 2021 08:59 PM
shorenetworks
Nov 4, 2019 06:18 PM
donniedarko
Oct 21, 2015 01:15 PM
rob&JCW
Sep 10, 2015 12:06 PM
Panik
Sep 9, 2015 08:36 AM
