R50/53 i cleaned my UNI foam filter using the K&N cleaning kit...wrong?
thinking that the cleaning kit for foam filters & K&N filters are the same, i used the K&N cleaning kit on my UNI filter 2 days ago and so far i've done about 150kms since the cleaning. i followed the instructions on the K&N cleaning kit (yes, including oiling the filter)
so should i be worried screwing up the MAF sensor or anything because i used the K&N cleaning kit on a foam filter?
UNI filters and K&N use a different cleaner AND viscosity of oil. The K&N oil is thinner and can run thru the foam filter and cause damage. Also the K&N cleaner is basically a degreaser type fluid and can degrade the foam and make it fall apart.
ALTA_Jarid: what kind of fluid is the cleaner for foam filters then? FWIW, i only applied the cleaner & oil to the outer surface of the UNI filter so if any physical damage was done, i hope it will be only limited to the outer portion of the filter
molala
Oct 2, 2015 01:53 PM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 4, 2015 09:10 AM
