R50/53 Undercarrage Knock when shifting/accelerating
Old Dec 18, 2007 | 08:19 AM
cpayne's Avatar
cpayne
So have a new issue that I "think" might be the Ireland exhaust banging on the heat sheild from underneith the car. When I accelerate off the line everytime I shift under moderate or heavy acceleration I hear something knocking underneith the undercarrage. I "think" it is up around the Catalytic converter but not certain as very had to pin down the exact area. The motor mount looks good...any other mounts that are known to breakdown and cause more then normal engine movement?
Any other areas to look for?
Cheers
cp
Old Dec 18, 2007 | 08:32 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I may be the pipe rattling on the center mount, seen this alot. If you have a USS it will make the same noise as the cat rattles on it.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 18, 2007 | 09:02 AM
cpayne's Avatar
cpayne
The center pipe/resonator right? Wonder if have a torn exhaust hanger...will check there too..thx!
Old Dec 18, 2007 | 11:04 AM
minipooper02's Avatar
minipooper02
check your front left and right bushings on the suspension also.
Old Dec 18, 2007 | 07:09 PM
cpayne's Avatar
cpayne
Well doesnt appear to be the exhaust..but I can replicate in the driveway very easy by rocking the car back and forth w/ the clutch on the driveway slope. Also great test w/ parking brake on. Really does sound to be right under the shifter area...hmmm
Old Dec 18, 2007 | 07:33 PM
cpayne's Avatar
cpayne
FOUND IT!
Missing Bolt must have fallen out of motor mount:
https://www.northamericanmotoring.co.../P10100264.JPG
https://www.northamericanmotoring.co.../P10100274.JPG
How the heck did that happen? LocTite needed?!
Old Dec 18, 2007 | 07:50 PM
cpayne's Avatar
cpayne
Unbelievable...just found the bolt that fell out just sitting under the hole on a ledge under the motor mount where it fell out! Wow...she is back in and a touch of LocTite to hold it in!
Hope this post might help others
Cheers
cp
Old Mar 18, 2008 | 07:32 PM
ltz_mtr's Avatar
ltz_mtr
I had a similar issue with a milltek header and catback. I put Ireland Engineering bushings in engine top / bottom and transmission mount, and exhaust banging on the center exhaust mount is gone.
riff42
Sep 22, 2015 03:07 PM
NeonLed
Sep 15, 2015 02:48 PM
weaver9000
Sep 14, 2015 05:48 PM
tylewis
Sep 6, 2015 01:07 PM
MasterShaftner
Sep 4, 2015 03:52 PM
