R50/53 2004 MC Temp/Speed on tachometer
Old Jul 2, 2007 | 06:56 PM
chava007's Avatar
chava007
Do ALL 04 coopers are able to read the Speed on the tachometer? Mine right now shows the temp.. I think there is supposed to be a button on the same stick that has all the lights options, but I dont think mine has one that can't be right.. can it? also I noticed I don't have the rear power outlet, just a plastic round thing over where it should be... is mine a lower end 04 or something? I thought it was weird because it comes equipped with sunroof, alarm, cd changer, etc ... any thoughs on this? and maybe a reference of where this button to toggle between these two options is supposed to be? Ive examined the thing 360 and I dont think its there
Thanks in advance!! :-)
Old Jul 2, 2007 | 07:15 PM
chpsk8's Avatar
chpsk8
Button is on the top of the turn signal stalk. Small like a Tic-Tac. Push it and it will rotate through the options.
Old Jul 2, 2007 | 07:17 PM
chava007's Avatar
chava007
I looked at some pictures on the manual.. its just not there... :(
Old Jul 2, 2007 | 08:38 PM
MiniTron's Avatar
MiniTron
Not all of the MINIs came with the OBC option. If you don't have the little button on the top side of the turn signal stalk then you don't have the IBC, and what you see is what you get.
Old Jul 2, 2007 | 08:43 PM
chava007's Avatar
chava007
Sorry i'm a bit acronym impaired when it comes to cars (Computer acronyms thats a whole different story haha) OBC - on board computer? IBC is? It is weird though because the manual says that cars without the OBC can still switch between temp and speed...
I checked the option 1.4 in the menu... it says.. 4303 ... whats that week 43 of 03??
Old Jul 3, 2007 | 06:25 AM
Qksquirt's Avatar
Qksquirt
More than likely if you see a temp read out you have an OBC, you should be able to toogle all the different read outs by depressing the little button on top of your light switch. Did you pull the little plastic cover off the 12VDC outlet and see if there is what looks like a lighter plug in behind it? The cover is there to keep junk out that would possibly short out the plug. Get you VIN number to the dealer and they can pretty much tell you everything you want to know about your MINI.
Old Jul 3, 2007 | 06:34 AM
chava007's Avatar
chava007
I havent tried pulling the cover off... I just compared the picture with the 03 models and it seemed the same type of cover so I assumed it was not there, from what i've seen in pictures in other cars you can see the outlet sticking out. And I just cheked and there isnt a button on my lights :-( I am really puzzled by this.. i think my production date matches an 04, and car paper work says 04... im just wondering if I still got 03 production parts or something like that
Old Jul 3, 2007 | 07:11 AM
geowit's Avatar
geowit
I have an early model '04, like 09/03 production without OBC and I have the ability to toggle the display between outside temp and speed. It's just a button on the turn signal stalk.
Old Jul 3, 2007 | 08:47 AM
chava007's Avatar
chava007
Yupp I dont have that button, ive noticed on pictures that is a little bump on the top of it... but i dont have it... mine is a 9/03 also apparently. still puzzled by this.
Old Jul 3, 2007 | 10:40 PM
Thrilhouse's Avatar
Thrilhouse
Mine is a 9/03 build and I have the temp/speed display, with button on the turn signal stalk.
Old Jul 3, 2007 | 10:47 PM
chava007's Avatar
chava007
HUmm... i wonder if production changes were the same around the world.... mine doesnt have it :-( and neither the back outlet... so it seems like a 03, eventhough all paperwork says 04
Old Jul 4, 2007 | 01:54 PM
chava007's Avatar
chava007
I just noticed that my tachometer has only round "information" spaces.... while there are others that have a center square and the rest are all round... I am refering to the round things that light up on the tachometer to show information.... what is the diff. between the two?
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
mni928
Oct 11, 2015 07:37 PM
bahman
Sep 30, 2015 01:59 PM
