Off-Topic :: Autos Interested in discussing other autos? This is the place!
Top Fuel/Funny Car facts
Old Feb 18, 2008 | 08:23 PM
hemiheaded18's Avatar
hemiheaded18
Ever wonder about the fastest accelerating piston driven vehicles on Earth? Here ya go:
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona.
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747 but with 4 times the energy volume.
* The supercharger takes more power to drive than a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting off its fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence.
Did you know …
… that the nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 7,000 horsepower, about 37 times that of the average street car?
… that one cylinder of the eight cylinders of a Top Fuel dragster or a Funny Car produces 750 horsepower, equaling the entire horsepower output of a NASCAR engine?
… that the gasoline-powered engines of NHRA Pro Stock cars produce about 1,200 horsepower, about eight times that of the average street car?
… that an NHRA Top Fuel dragster accelerates from 0 to 100 mph in less than .8-second, almost 11 seconds quicker than it takes a production Porsche 911 Turbo to reach the same speed?
… that an NHRA Top Fuel dragster leaves the starting line with a force nearly five times that of gravity, the same force of the space shuttle when it leaves the launching pad at Cape Canaveral?
… that an NHRA Funny Car is slowed by a reverse force more than seven times that of gravity when both parachutes deploy simultaneously?
… that NHRA Top Fuel dragsters and Funny Cars consume between four and five gallons of fuel during a quarter-mile run, which is equivalent to between 16 and 20 gallons per mile?
… that NHRA Top Fuel dragsters and Funny Cars use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run?
… that NHRA Top Fuel dragsters and Funny Cars travel the length of more than four football fields in less than five seconds?
… that NHRA Top Fuel dragsters can exceed 280 mph in just 660 feet?
… that from a standing start, NHRA Top Fuel dragsters accelerate faster than a jumbo jet, a fighter jet, and a Formula One race car?
… that a fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time?
… that the fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 pounds, about 20 times greater than the pressure on passenger-car fuel pumps?
… that depending on size and angle, the large rear wing on an NHRA Top Fuel dragster develops between 4,000 and 8,000 pounds of downforce?
… that the 17-inch rear tires used on NHRA Top Fuel dragsters and Funny Cars wear out after four to six runs, or about two miles? Some brands of passenger-car tires are guaranteed for 80,000 miles.
… that it takes just 15/100ths of a second for all 7,000 horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels?
… that it's desirable for an NHRA Top Fuel dragster to race with its front wheels inches off the ground for about the first 200 feet of the run? This ensures proper weight transfer to the rear wheels, a crucial part of a good launch and quick run.
… that the nitromethane used to power the engines of NHRA Top Fuel dragsters and Funny Cars costs about $30 per gallon?
Old Feb 20, 2008 | 06:31 AM
windsorlove's Avatar
windsorlove
i dont really have anything to say to that besides...wow
Old Feb 20, 2008 | 06:58 AM
Minidrivr's Avatar
Minidrivr
If you ever have a chance to see them run in person, do it. The vibration from the sound waves these animals produce is just amazing. Bring good ear plugs.
Old Feb 20, 2008 | 07:10 AM
windsorlove
i have never seen them run, but i have had the chance to get close to one. a local McDonalds had their funny car and a top fuel car one day. they are an amazing piece of engineering.
Old Feb 20, 2008 | 07:26 AM
Dan00Hawk's Avatar
Dan00Hawk
Yep, I agree. I was never that impressed watching them on TV. The first time I went to an NHRA event, it was an experience that I'll never forget.
Old Feb 20, 2008 | 09:32 AM
MINIdave's Avatar
MINIdave
If you never have, you MUST go see these things run at least once in your life - you have no idea what raw power is till you see hear and feel one of these things launch!
Old Feb 20, 2008 | 02:52 PM
kenchan's Avatar
kenchan
holy crap that's a lot of consumption.
Old Feb 20, 2008 | 02:59 PM
hemiheaded18
To anyone who's never experienced a single pass in person, it's like this. Get someone to slap you in the chest with every ounce of strength they have. Then have them do it non-stop for 4 1/2 seconds. The grandstands shake as they pass. Ear plugs and ear muffs only help a little. The sound causes them to vibrate off of your ears. Then after a pass, go watch a team fire one up in the pits. Bring a towel or be ready to pull your shirt over your eyes and nose. Nitro burns your eyes to the point you can't open them. Your nose runs and burns. You can tell who truly loves the sights, sounds and smells at a NHRA national event because they are the people who come out of the pits looking like they were just maced. Eyes are red, noses running, coughing, gagging and just about one of the biggest smiles you've ever seen. To give a slight idea, watch for the 2:30 mark for when they crack the throttle to set the clutch pack:
http://youtube.com/watch?v=XR7aF4hY9rU
It's what makes women scream, kids cry, and nitro junkies giggle.
Old Feb 20, 2008 | 04:52 PM
Rich.Wolfson's Avatar
Rich.Wolfson
The thrill of watching a top fueler or funny car in person rivals that of watching a shuttle launch or a jet being hurled of a carrier. I used to go to the Nationals here in NJ but haven't in years. But I do have a date with local kids and any new kids and dads (and the occasional mom) to go to the PC Richards Motorsports Spectacular this year on Wednesday July 9th at Raceway Park. They usually have a couple of Top Fuelers, a couple of Funny Cars, a Jet Dragster or two and Monster Trucks. With all that the star of the show for the kids was when Robosourus ate a car but who knows what will happen with that since I see the great monster was sold at the Barrett-Jackson auction.
It's GREAT for kids as you get close to the cars, they make lots of smoke and noise, belly busting burgers and fries and it's over by 10:00PM. What could be bad?
Rich
Old Feb 20, 2008 | 05:28 PM
hemiheaded18
^I've been to E-town a few times but never for the Nationals. It was always a Mopar show or the Night of Thrills like you mentioned (which is awesome). I'd say come to Maple Grove if you're within driving distance. It's cool sitting in what used to be a cow pasture watching the cars run. The best part is if you're up near the line, how you watch the cars disappear back into the woods right after the line. Although, I was able to buy this in Englishtown from Shirley herself.
File Type: jpg
Old Feb 20, 2008 | 06:40 PM
Rich.Wolfson
Originally Posted by hemiheaded18
...Although, I was able to buy this in Englishtown from Shirley herself.
There is a lady with *****! And Class! In the days she drove nitro cars each run took you life in your hands and she was fast. And a great role model as she always talked to the kids and autographed anything. I watched her pick a little girl up and put her in her seat while the team was thrashing her car between runs. And she beat Garlits in 2000 in a match race.
But then 220 was a good run. Now if you don't do 300 you ain't in the finals. Technology Motors On!
Rich
Old Feb 20, 2008 | 06:50 PM
hemiheaded18
When I saw her run a few years ago, she went 3 for 3 against Clay Millican in a grudge match.
Getrieben
Sep 12, 2024 07:03 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
emulajavi
Dec 24, 2018 09:15 AM
xpunisherx
Aug 10, 2015 10:50 PM
